查看: 2061|回復: 0
單片機利用外部中斷0實現計數(靜態數碼管顯示)程序
ID:954170 發表于 2021-7-19 18:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
char Duan_Code[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
uchar Count=0;
void SEG7_Static_Display(uchar);
void Ex0_Initial(void);
void Display(void);
int main()
        Ex0_Initial();
                Display();
void SEG7_Static_Display(uchar Num)
        P0=Duan_Code[Num];
        IT0=1;
        EA=1;
        EX0=1;
void Display(void)
        SEG7_Static_Display(Count);
        if(Count==10)
                Count=0;
void EX0_Int() interrupt 0
        Count++;
