查看: 2924|回復: 0
基于單片機CC1101的433M無線通信系統
ID:600744 發表于 2021-7-14 17:24 | 顯示全部樓層 |閱讀模式
1、 完成硬件電路的設計,其中包括單片機和CC1101模塊的設計;
2、完成無線通信模塊的程序設計與實現;
部分關鍵代碼:
#include "main.h"    //main.h 中含有TX/RX選擇配置選項
const char *g_Ashining = "433Mtest";
uint8_t g_TxMode = 0, g_UartRxFlag = 0;
uint8_t g_UartRxBuffer[100] = { 0 };
uint8_t g_RF24L01RxBuffer[32] = { 0 };
  * @brief :主函數
  * @param :無
  * @note  :無
  * @retval:無
int main(void)
    uint8_t i = 0;
    //串口初始化
    drv_uart_init();
    //LED初始化
    drv_led_init();
    //SPI初始化
    drv_spi_init();
    //CC1101初始化
    CC1101_Init();
    for (i = 0; i < 6; i++)
        led_red_flashing();
        led_green_flashing();
        drv_delay_ms(500);
#ifdef    __CC1101_TX_TEST__
        //按鍵初始化
    drv_button_init();
    while (1)
        //模式切換
        if (BUTOTN_PRESS_DOWN == drv_button_check())
            g_TxMode = 1 - g_TxMode;        //模式會在 TX_MODE_1( 0 ),TX_MODE_2( 1 )之間切換
            //狀態顯示清零
            led_green_off();
            led_red_off();
            if (TX_MODE_1 == g_TxMode)
                    led_red_flashing();    //固定發送模式,紅燈閃爍3次
                    drv_delay_ms(500);
                    led_green_flashing();    //串口發送模式,綠燈閃爍3次
                    drv_delay_ms(500);
        //模式切換
        //發送
            CC1101_Tx_Packet((uint8_t *)g_Ashining, 8, ADDRESS_CHECK);    //模式1發送固定字符,1S一包
            drv_delay_ms(1000);
            led_red_flashing();
            //查詢串口數據
            i = drv_uart_rx_bytes(g_UartRxBuffer);
            if (0 != i)
                CC1101_Tx_Packet(g_UartRxBuffer, i, ADDRESS_CHECK);
                led_red_flashing();
#else
接收
    while (1)
        CC1101_Clear_RxBuffer();
        CC1101_Set_Mode(RX_MODE);
        while (0 != CC1101_GET_GDO0_STATUS());
        while (0 == CC1101_GET_GDO0_STATUS());
        i = CC1101_Rx_Packet(g_RF24L01RxBuffer);        //接收字節
        if (0 != i)
            drv_uart_tx_bytes(g_RF24L01RxBuffer, i);    //輸出接收到的字節
#endif
