(1) 起始狀態時,8個燈處于同頻率“呼吸”狀態。 (2) 按鍵1按下時,1號到8號依次由亮到暗“呼吸”。 (3) 按鍵2按下時,1號到8號依次由暗到亮“呼吸”。 (4)按鍵3按下時,恢復起始亮法。 由于是在仿真中,需要加入驅動電路才能看出來“呼吸”的效果,否則只能看到燈在閃爍。 做實物時不需要加驅動電路,直接連接單片機就可以看出來那種效果。
- #include <reg51.h>
- #define MAX 0x40 //定時上限定義
- #define MIN 0x00 //定時下限定義
- #define TIMELINE 10 //時間分頻常數
- #define TRUE 1
- #define FALSE 0 //標志位常數
- sbit s1 = P2^0;
- sbit s2 = P2^1;
- sbit s3 = P2^2;
- unsigned int TimeCounter;
- bit ArrowFlg = 0; //方向標志位
- unsigned char upCounter,downCounter; //增加計數器和減少計數器
- unsigned char table1[] = {0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff} ;
- unsigned char table2[] = {0xff,0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00} ;
- unsigned char k=0,j=-1;
- char key1,key=3;
- char keyscan()
- if(s1==0){while(!s1);key=1;}
- if(s2==0){while(!s2);key=2;}
- if(s3==0){while(!s3);key=3;}
- return key;
- //T0的中斷服務子函數
- void T0Deal() interrupt 1
- TH0=0xf1;
- TL0=0xf1;
- TR0=1;
- TimeCounter++; //定時計數器增加
- if(TimeCounter == TIMELINE)
- if(key1==1)
- upCounter++;
- downCounter--;
- if((upCounter == MAX)&&(downCounter == MIN))
- upCounter = MIN;
- downCounter = MAX; //計數器初始化
- k++;if(k>=9)k=0;
- if(key1==2)
- upCounter--;
- downCounter++;
- if((upCounter == MIN)&&(downCounter == MAX))
- upCounter = MAX;
- downCounter = MIN; //計數器初始化
- j++;if(j>=9)j=0;
- if(key==3)
- if((upCounter == MAX)&&(downCounter == MIN)) //計數方向標志位切換
- ArrowFlg = FALSE;
- ArrowFlg= TRUE;
- if(ArrowFlg == 1) //如果是增加計數
- upCounter++;
- downCounter--;
- else //如果是減少計數
- upCounter--;
- downCounter++;
- TimeCounter=0;
- //延時函數
- void Delay(unsigned int i)
- unsigned int j;
- while(i--)
- for(j=0;j<32;j++); //延時
- void main()
- upCounter = MIN;
- TMOD = 0x01; //設置定時器工作方式1
- TH0 = 0xF0;
- TL0 = 0xF0; //T0初始化值
- EA = 1;
- ET0 = 1; //開中斷
- TR0 = 1; //啟動T0
- while(1)
- key1=keyscan();
- if(key1==1){P1= table1[k-1];Delay(downCounter);P1=table1[k]; Delay(upCounter);}
- if(key1==2){P1=table2[j]; Delay(downCounter);P1=table2[j-1]; Delay(upCounter); }
- if(key1==3){P1=0x00; Delay(downCounter);P1=0xff; Delay(upCounter);}
七彩呼吸燈.zip
(118.5 KB, 下載次數: 127)
2021-7-10 09:44 上傳
