查看: 1327|回復: 0
普通的交通燈
ID:949622 發表于 2021-7-5 23:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit RED_A=P0^0;
sbit YELLOW_A=P0^1;
sbit GREEN_A=P0^2;
sbit RED_B=P0^3;
sbit YELLOW_B=P0^4;
sbit GREEN_B=P0^5;
uchar Flash_Count = 0;
Operation_Type = 1;
void DelayMS(uint x)
    uchar t;
    while(x--)
        for(t=120;t>0;t--);
void Traffic_lignt()
    switch(Operation_Type)
        case 1:
            RED_A=1;YELLOW_A=1;GREEN_A=0;
            RED_B=0;YELLOW_B=1;GREEN_B=1;
            DelayMS(2000);
            Operation_Type = 2;
            break;
        case 2:
            DelayMS(200);
            YELLOW_A=~YELLOW_A;
            if(++Flash_Count !=10)
                return;
            Flash_Count=0;
            Operation_Type = 3;
            break;
        case 3:
            RED_A=0;YELLOW_A=1;GREEN_A=1;
            RED_B=1;YELLOW_B=1;GREEN_B=0;
            DelayMS(2000);
            Operation_Type = 4;
            break;
        case 4:
            DelayMS(200);
            YELLOW_B=~YELLOW_B;
                return;
            Flash_Count=0;
            Operation_Type = 1;
            break;
        Traffic_lignt();
