查看: 1880|回復: 0
AT89單片機做的音樂分享給老鐵們
ID:766282 發表于 2021-7-2 17:03 | 顯示全部樓層 |閱讀模式
AT89C51 生日快樂!(^O^)y歌曲程序,仿真供學習制作
  1. /*******************************************/
  2. /* 音樂:生日快樂                          */
  3. /* 設計:OYT郭                             */
  4. /* 日期:2021夏天                          */
  5. /*******************************************/
  6. #include <REG51.H>
  7. #define uchar unsigned char
  8. sbit beepIO=P3^3;
  9. uchar m,n;
  10. uchar code T[49][2]={{0,0},
  11. {0xF8,0x8B},{0xF8,0xF2},{0xF9,0x5B},{0xF9,0xB7},{0xFA,0x14},{0xFA,0x66},{0xFA,0xB9},{0xFB,0x03},{0xFB,0x4A},{0xFB,0x8F},{0xFB,0xCF},{0xFC,0x0B},
  12. {0xFC,0x43},{0xFC,0x78},{0xFC,0xAB},{0xFC,0xDB},{0xFD,0x08},{0xFD,0x33},{0xFD,0x5B},{0xFD,0x81},{0xFD,0xA5},{0xFD,0xC7},{0xFD,0xE7},{0xFE,0x05},
  13. {0xFE,0x21},{0xFE,0x3C},{0xFE,0x55},{0xFE,0x6D},{0xFE,0x84},{0xFE,0x99},{0xFE,0xAD},{0xFE,0xC0},{0xFE,0x02},{0xFE,0xE3},{0xFE,0xF3},{0xFF,0x02},
  14. {0xFF,0x10},{0xFF,0x1D},{0xFF,0x2A},{0xFF,0x36},{0xFF,0x42},{0xFF,0x4C},{0xFF,0x56},{0xFF,0x60},{0xFF,0x69},{0xFF,0x71},{0xFF,0x79},{0xFF,0x81}
  15. };
  16. uchar code music[][2]={{0,4},
  17. {17,6},{17,2},{19,8},{17,8},{22,8},{21,16},
  18. {17,6},{17,2},{19,8},{17,8},{24,8},{22,16},{17,6},{17,2},{29,8},{26,8},{22,8},{21,8},{19,8},{27,6},{27,2},{26,8},{22,8},{24,8},{22,16},
  19. {0xFF,0xFF}};
  20. void delay(uchar p)
  21. {
  22.     uchar i,j;
  23.     for(;p>0;p--)
  24.     for(i=181;i>0;i--)
  25.     for(j=181;j>0;j--);
  26. }
  27. void pause()
  28. {
  29.     uchar i,j;
  30.     for(i=150;i>0;i--)
  31.     for(j=150;j>0;j--);
  32. }
  33. void T0_int() interrupt 1
  34. {
  35. beepIO=!beepIO;
  36. TH0=T[m][0]; TL0=T[m][1];
  37. }
  38. void main()
  39. {
  40. uchar i=0;
  41. TMOD=0x01;  EA=1; ET0=1;
  42. while(1)
  43.       {
  44.         m=music[i][0];n=music[i][1];
  45.            if(m==0x00)
  46.              {TR0=0;delay(n);i++;}
  47.            else if(m==0xFF)
  48.              {TR0=0;delay(30);i=0;}
  49.            else if(m==music[i+1][0])
  50.              {TR0=1;delay(n);TR0=0;pause();i++;}
  51.            else
  52.              {TR0=1;delay(n);i++;}
  53.       }
  54. }
以上程序和hex51hei提供下載:
AT89 生日快樂音樂.rar (982.33 KB, 下載次數: 6)
