分享學習,有問題交流哈
- //EDM12864B DRIVE//
- PAGEADD為頁地址起使
- TIERADD為行地址起使
- DIS_STARTADD為開始命令
- CTABLE為漢字字庫數組
- ETABLE為英文字庫數組
- #include <reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define High 1
- #define Low 0
- #define _nop {}
- #define PAGEADD 0xb8
- #define TIERADD 0x40
- #define DIS_STARADD 0xc0
- uint key_value;
- sbit DI=P1^4;
- sbit E=P1^2;
- sbit CS1=P1^1;
- sbit CS2=P1^0;
- sbit RW=P1^3;
- sbit cs=P1^7;
- sbit sclk=P1^6;
- sbit dout=P1^5;
- sbit I2C_SCL = P3^7;
- sbit I2C_SDA = P3^6;
- //uchar ntable[]={61,49,57,60,19,49,62,49,60,63,55,2,0,0,6,22,56,
- //63,68,61,49,57,60,17,51,63,61};//email:analog2006@hotmail.com
- uchar data voltage_display[8];
- 字符表
- 顯示"Welcome Use"
- uchar code table1[]={
- 0x00,0x3e,0x51,0x49,0x45,0x3e,0x00,0x00,//0(0)
- ...............余下內容詳見附件..................
- 0x40,0x40,0x40,0x57,0x55,0x55,0x55,0x7F,
- 0x55,0x55,0x55,0x57,0x50,0x40,0x40,0x00,//量(13)
- 顯示用的延時函數
- 延時長度有參數 n 決定
- Delay_nms(uchar n)
- { uchar a;
- for(;n>0;n--)
- for(a=0;a<100;a++)
- _nop;
- _nop;
- _nop;
- _nop;
- DEM12864B狀態檢測,從EDM12864B讀出數
- 據檢測標志位BF
- void LCD_Busy()
- uchar busy;
- E=Low;
- DI=Low;
- RW=High;
- while(1)
- E=High;
- _nop;
- _nop;
- busy=P2;//讀狀態標志寄存器
- _nop;
- E=Low;
- if((busy&0x90)==0)//檢測BF和RES位,兩者都為零時表示可進行寫入
- break;
- 寫指令
- void WRCommand_L(uchar command)
- CS1=High;
- CS2=Low;
- LCD_Busy();
- DI=Low;
- _nop;
- RW=Low;
- _nop;
- E=High;
- _nop;
- P2=command;
- _nop;
- E=Low;
- _nop;
- void WRCommand_R(uchar command)
- CS1=Low;
- CS2=High;
- LCD_Busy();
- DI=Low;
- _nop;
- RW=Low;
- _nop;
- E=High;
- _nop;
- P2=command;
- _nop;
- E=Low;
- _nop;
- 寫一個字節的顯示數據
- void WRdata_L(uchar ucdata)
- CS1=High;
- CS2=Low;
- LCD_Busy();
- DI=High;
- _nop;
- RW=Low;
- _nop;
- E=High;
- _nop;
- P2=ucdata;
- _nop;
- E=Low;
- _nop;
- void WRdata_R(uchar ucdata)
- CS1=Low;
- CS2=High;
- LCD_Busy();
- DI=High;
- _nop;
- RW=Low;
- _nop;
- E=High;
- _nop;
- P2=ucdata;
- _nop;
- E=Low;
- _nop;
- 讀顯示數據
- RDdata_L()
- uchar receiver;
- CS1=High;
- CS2=Low;
- LCD_Busy();
- DI=High;
- _nop;
- WR=High;
- _nop;
- E=High;
- _nop;
- receiver=P0;
- E=Low;
- return(receiver);
- RDdata_R()
- uchar receiver;
- CS1=Low;
- CS2=High;
- LCD_Busy();
- DI=High;
- _nop;
- WR=High;
- _nop;
- E=High;
- _nop;
- receiver=P0;
- E=Low;
- return(receiver);
- I2C時鐘時序要求的數據建立時間,
- nop_可以用其它短延時替代,比如喂狗
- I2C_delay()
- uchar n=5;
- while(n--)
- _nop;
- _nop;
- I2C的時鐘信號可發送和接收.
- 接收時通過判斷sample對寄存器的值加.
- 發送的時候只調用程序產生時序.
- bit I2C_clock(void)
- bit sample;
- I2C_delay();
- I2C_SCL=High;
- I2C_delay();
- sample=I2C_SDA;
- I2C_SCL=Low;
- I2C_delay();
- return(sample);
- I2C確定接收有效的應答信號Acknowledge
- I2C_ACK()
- I2C_SDA=Low;
- I2C_clock();
- I2C_SDA=High;
- I2C的非應答信號
- I2C_NACK()
- I2C_SDA=High;
- I2C_clock();
- I2C_SDA=High;
- I2C的開始信號.發送和接受數據時,必須先調用.
- I2C_start()
- I2C_SDA=High;
- I2C_delay();
- I2C_SCL=High;
- I2C_delay();
- I2C_SDA=Low;
- I2C_delay();
- I2C_SCL=Low;
- I2C_delay();
- I2C停止信號.發送和接受數據時結束時,需要調用.
- I2C_stop()
- I2C_SDA=Low;
- I2C_delay();
- I2C_SCL=High;
- I2C_delay();
- I2C_SDA=High;//產生停止控制信號,并且釋放數據線
- I2C_delay();
- I2C初始化.在main函數中必須先調用它.
- 進行初始化后才能調用其他函數.
- void I2C_init(void)
- I2C_SDA=High;
- I2C_SCL=High;
- I2C_delay();
- I2C_stop();
- I2C總線寫一個字節,即發送一個字節
- 發送結束后,需要返回一個檢測應答位
- bit I2C_send(uchar I2C_data)
- uchar a;
- for(a=0;a<8;a++)
- I2C_SDA=(bit)(I2C_data&0x80);
- I2C_data=I2C_data<<1;
- I2C_clock();
- I2C_SDA=High;
- I2C_delay();
- return(I2C_clock()); //返回應答信號
- I2C總線讀一個字節,即接收一個字節數據
- 接收結束后需要發送一個應答位acknowledge
- uchar I2C_receive()
- uchar a,receive_data;
- for(a=0;a<8;a++)
- receive_data=receive_data<<1;
- if(I2C_clock())
- receive_data++;
- //I2C_ACK();
- return(receive_data);
- DS1621_start()
- do
- I2C_start();
- while(I2C_send(0x90));//發送數據完地址字節的數據時,檢測從機的應答位
- if(I2C_send(0xee)==0)
- I2C_stop();
- return 1;
- else
- return 0;
- DS1621_stop()
- do
- I2C_start();
- //I2C_send(0x90);
- if(I2C_send(0x22)==0)
- I2C_stop();
- return 1;
- else
- return 0;
- char read_count_remain()
- char temp_remain=0;
- do
- I2C_start();
- while(I2C_send(0x90));//是否應答
- if(I2C_send(0xa8)==0)
- I2C_start();
- if(I2C_send(0x91)==0)
- temp_remain=I2C_receive();
- I2C_NACK();
- I2C_stop();
- return temp_remain;
- else
- return 0;
- else
- return 0;
- char read_count_c()
- char temp_c=0;
- do
- I2C_start();
- if(I2C_send(0xa9)==0)
- I2C_start();
- temp_c=I2C_receive();
- I2C_NACK();
- I2C_stop();
- return temp_c;
- else
- return 0;
- else
- return 0;
- bit read_temperature(char *point1)
- do
- I2C_start();
- if(I2C_send(0xaa)==0)
- do{
- I2C_start();
- while(I2C_send(0x91));
- (*point1)=I2C_receive();
- I2C_ACK();
- (*(point1+1))=I2C_receive();
- I2C_NACK();
- I2C_stop();
- return 1;
- else
- return 0;
- DS1621_state()
- do
- I2C_start();
- if(I2C_send(0xac)==0)
- do
- I2C_start();
- if(I2C_send(0x00)==0)
- //if(I2C_send(0x01)==0)
- I2C_stop();
- return 1;
- else
- return 0;
- else
- return 0;
- DS1621_th()
- DS1621_tl()
- DS1621_init()
- while(DS1621_stop()==0)
- while(DS1621_state()==0)
- DS1621_th();
- DS1621_tl();
- 字符為16*16顯示,分為兩個部分寫入32個字節
- 前16個字節寫入第一頁(16*8),后16個字節寫入
- 第二頁(16*8)
- 左側寫入"歡迎",右側寫入"使用"
- C_display_L(uchar C_Pagenum,uchar C_Tiernum,uchar C_Temp)
- uchar k;
- C_Pagenum=PAGEADD|C_Pagenum;
- C_Tiernum=TIERADD|C_Tiernum;
- WRCommand_L(C_Pagenum);
- WRCommand_L(C_Tiernum);
- for(k=0;k<16;k++)
- WRdata_L(table2[C_Temp*32+k]);
- C_Pagenum=C_Pagenum+1;
- for(k=0;k<16;k++)
- WRdata_L(table2[C_Temp*32+k+16]);
- C_display_R(uchar C_Pagenum,uchar C_Tiernum,uchar C_Temp)
- uchar k;
- WRCommand_R(C_Pagenum);
- WRCommand_R(C_Tiernum);
- for(k=0;k<16;k++)
- WRdata_R(table2[C_Temp*32+k]);
- for(k=0;k<16;k++)
- WRdata_R(table2[C_Temp*32+k+16]);
- 寫入西文字符,共11個字符,左側寫入6個
- 右側寫入5個,左側起始從16開始,右側從
- 0開始
- E_Display_L(uchar E_Pagenum,uchar E_Tiernum,uchar E_Temp)
- uchar k;
- WRCommand_L(PAGEADD|E_Pagenum);
- WRCommand_L(TIERADD|E_Tiernum);
- for(k=0;k<8;k++)
- WRdata_L(table1[E_Temp*8+k]);
- E_Display_R(uchar E_Pagenum,uchar E_Tiernum,uchar E_Temp)
- uchar k;
- WRCommand_R(PAGEADD|E_Pagenum);
- WRCommand_R(TIERADD|E_Tiernum);
- for(k=0;k<8;k++)
- WRdata_R(table1[E_Temp*8+k]);
- 清除所有顯示RAM內容
- CLR_DisplayRAM()
- uchar C_page,i,k;
- for(i=0;i<8;i++)
- C_page=PAGEADD|i;//清除起始頁為0
- WRCommand_L(C_page);//清除起始頁寫入
- WRCommand_L(TIERADD);//清除起始行地址寫入
- WRCommand_R(C_page);
- WRCommand_R(TIERADD);
- for(k=0;k<64;k++)
- WRdata_L(0x00);
- WRdata_R(0x00);//lcm的ram自動加一,只許循環64次即可
- 初始化 設置啟使行
- void Init_LCD(void)
- CLR_DisplayRAM();//清除所有顯示寄存器
- WRCommand_L(DIS_STARADD);
- WRCommand_R(DIS_STARADD);//設置顯示起始行地址
- WRCommand_L(0x3f);
- WRCommand_R(0x3f);//開顯示
- max1241讀轉換結果
- uint read_max1241()
- uint voltage_temp=0;
- uchar ucloop=12;
- cs=High;
- //dout=low;
- sclk=Low;
- cs=Low;
- while(dout==0);//EOC信號為高表示轉換結束
- sclk=High;
- sclk=Low;
- while(ucloop--)
- sclk=High;//上升沿數據穩定并讀出
- voltage_temp<<=1;
- if(dout==1)
- voltage_temp+=1;
- sclk=Low;
- //sclk=low;
- cs=High;
- return voltage_temp;
- main()
- uchar a=0,temp=0,b=0,number=0,pagenum=0;
- uchar etable[]={0,0,0,0,0,45,53,60,51,63,61,53,10,69,67,53};//Welcome use
- uchar ttable[]={42,57,61,53,19,10,2,0,0,6,18,1,1,18,0,7};//Time:2006/11/07
- char count_remain=0,count_c=0;
- bit flag=1;
- char temperature_buf[2]={0};
- uchar temperature_display[8]={0};
- //uchar voltage=0; //測試0831時使用
- double voltage=0;
- double temp_buffer=0;
- cs=High;
- sclk=High;
- Init_LCD();
- I2C_init();
- DS1621_init();//初始化
- DS1621_start();//開始溫度采集
- 利用開機顯示時間(大概三秒)空讀一次DS1621
- for(b=0;b<2;b++)
- for(number=0;number<20;number++)
- //中文顯示:歡迎使用液晶模塊
- pagenum=1;//在第二行開始顯示
- for(a=0;a<4;a++)
- C_display_L(pagenum,a*16,a);
- C_display_R(pagenum,a*16,a+4);
- //英文顯示:Welcome use
- pagenum=5;//在第六行顯示
- for(a=0;a<3;a++)
- E_Display_L(pagenum,(a+5)*8,etable[a+5]);
- for(a=0;a<8;a++)
- E_Display_R(pagenum,a*8,etable[a+8]);
- //顯示制作時間:Time:2006/11/07
- pagenum=7;//在第八行顯示
- for(a=0;a<8;a++)
- E_Display_L(pagenum,a*8,ttable[a]);
- E_Display_R(pagenum,a*8,ttable[a+8]);
- Delay_nms(100);
- if(flag)
- read_temperature(temperature_buf);//在轉到下一個顯示界面之前空讀一次
- read_count_remain();
- read_count_c();
- DS1621_start();
- flag=0;
- WRCommand_L(0x3e);
- WRCommand_R(0x3e);
- CLR_DisplayRAM(); //清除顯示ram
- while(1)
- while(read_temperature(temperature_buf)==0);//讀溫度值(兩字節有符數),并檢測應答位,只使用第一字節
- count_remain=read_count_remain();//讀斜率
- count_c=read_count_c();//讀計數器
- temp_buffer = temperature_buf[0] -0.75 + (count_c-count_remain) / (double)count_c;
- DS1621_start();//讀完數據后,重新開始一次溫度轉化
- temperature_display[0]=19;
- if(temp_buffer<0)
- temperature_display[1]=16;//顯示負號
- temperature_display[2]=(-temp_buffer)/10;//十位
- temperature_display[3]=((uchar)(-temp_buffer))%10;
- temperature_display[4]=17;//小數點
- temperature_display[5]=(int)((-temp_buffer)*10)%10;
- temperature_display[6]=(int)((-temp_buffer)*100)%10;//小數點后兩位
- else
- temperature_display[1]=temp_buffer/100;//百位
- temperature_display[2]=((uchar)temp_buffer)/10%10;
- temperature_display[3]=((uchar)temp_buffer)%10;
- temperature_display[5]=((int)(temp_buffer*10))%10;
- temperature_display[6]=((int)(temp_buffer*100))%10;//小數點后兩位
- // 測試從max1241讀出的原始數據
- //pagenum=3;
- voltage=read_max1241();
- voltage_display[0]=19;
- voltage_display[1]= voltage/1000;
- voltage_display[2]=(voltage/100)%10;
- voltage_display[3]=(voltage/10)%10;
- voltage_display[4]= voltage%10;
- //LCD顯示第二部分
- for(b=0;b<40;b++)
- //更新max1241顯示值
- voltage=(double)read_max1241();
- voltage=5000*voltage/4095;
- voltage_display[5]=(uint)voltage %10;//個位
- voltage_display[2]=17;
- voltage_display[4]=(uint)(voltage/10)%10;//小數點后1位
- voltage_display[3]=(uchar)(voltage/100)%10;//小數點后2位
- voltage_display[1]=(uchar)(voltage/1000)%10;//小數點后3位
- //顯示文字:電壓測量
- pagenum=2;
- for(a=0;a<2;a++)
- C_display_L(pagenum,a*16,a+8);
- for(a=0;a<2;a++)
- C_display_L(pagenum,(a+2)*16,a+12);
- //顯示文字:溫度測量
- pagenum=5;
- for(a=0;a<2;a++)
- C_display_L(pagenum,a*16,a+10);
- for(a=0;a<2;a++)
- //顯示1241采樣值
- pagenum=3;
- for(a=0;a<6;a++)
- E_Display_R(pagenum,a*8,voltage_display[a]);
- //顯示ds1621采樣值
- pagenum=6;
- for(a=0;a<7;a++)
- E_Display_R(pagenum,a*8,temperature_display[a]);
復制代碼 全部資料51hei下載地址:
12位1621與12864.7z
(62.21 KB, 下載次數: 53)
2021-7-1 16:23 上傳
