查看: 2279|回復: 0
STM32單片機的PID算法實現程序無法編譯,求指導
  1. #include "System_init.h"
  2. extern int U_Set;
  3. extern u16 CCR1_Val;
  4. /*====================================================================================================
  5. PID Function
  6. The PID (比例、積分、微分) function is used in mainly
  7. control applications. PIDCalc performs one iteration of the PID
  8. algorithm.
  9. While the PID function works, main is just a dummy program showing
  10. a typical usage.
  11. =====================================================================================================*/
  12. typedef struct PID {
  13.         float SetPoint; // 設定目標Desired value
  14.         float Proportion; // 比例常數Proportional Const
  15.         float Integral; // 積分常數Integral Const
  16.         float Derivative; // 微分常數Derivative Const
  17.         float LastError; // Error[-1]
  18.         float PrevError; // Error[-2]
  19.         float SumError; // Sums of Errors
  20. } PID;
  21. /*====================================================================================================/
  22. PID計算部分
  23. =====================================================================================================*/
  24. PID   vPID={0,0.1,0.001,0.001,0,0,0};
  25. float PIDCalc( PID *pp, float NextPoint )
  26. {
  27.         float dError,
  28.         Error;
  29.         Error = pp->SetPoint - NextPoint; // 偏差
  30.         pp->SumError += Error; // 積分
  31.         dError = pp->LastError - pp->PrevError; // 當前微分
  32.         pp->PrevError = pp->LastError;
  33.         pp->LastError = Error;
  34.     if(pp->SumError>900)  pp->SumError=900;
  35.     else if(pp->SumError<-900)          pp->SumError=-900;
  36.         return (pp->Proportion * Error // 比例項
  37.         + pp->Integral * pp->SumError // 積分項
  38.         + pp->Derivative * dError // 微分項
  39.         );
  40. }
  41. float Vol(int vSet,int v3){
  42.         float vOut; // PID Response (Output)
  43.         float vIn; // PID Feedback (Input)
  44.         vPID.SetPoint = vSet; // Set PID Setpoint
  45.         vIn = (float)v3; // Read Input
  46.         vOut = PIDCalc ( &vPID,vIn ); // Perform PID Interation
  47.         return vOut;
  48. }
代碼: STM32單片機的PID算法實例.zip (729.66 KB, 下載次數: 12)
