查看: 3111|回復: 0
單片機IO口輸入輸出擴展(51單片機代碼+74hc595 proteus仿真)
ID:554500 發表于 2021-6-28 15:18 | 顯示全部樓層 |閱讀模式
  1. #include "REG52.H"
  2. #define u8 unsigned char
  3. #define u16 unsigned int
  4.
  5. //74hc165
  6. sbit DIN=P1^0;
  7. sbit SH =P1^1;
  8. sbit CLK=P1^2;
  9. //74hc595
  10. sbit STCP=P1^3;  //鎖存,上升沿有效
  11. sbit DAT =P1^4;  //數據
  12. sbit SHCP=P1^5;  //時鐘
  13. void delay(u16 x)
  14. {
  15.         while(x--);
  16. }
  17. u8 Read_74HC165D()
  18. {
  19.         u8 i,d=0;
  20.
  21.         DIN=1;
  22.         CLK=1;
  23.         SH =0;
  24.         SH =1;
  25.         for(i=0;i<8;i++)
  26.         {
  27.                 d<<=1;
  28.                 CLK=1;
  29.                 if(DIN)
  30.                         d++;
  31.                 delay(10);
  32.                 CLK=0;
  33.         }
  34.
  35.         return d;
  36. }
  37. void Send_74HC595(u8 byte)
  38. {
  39.         u8 i;
  40.         for(i=0;i<8;i++)
  41.         {
  42.                 if(byte&0x80)  //高位先發
  43.                         DAT=1;
  44.                 else
  45.                         DAT=0;
  46.                 delay(10);
  47.                 SHCP=0;
  48.                 delay(10);
  49.                 SHCP=1;
  50.
  51.                 byte<<=1;
  52.         }
  53.         STCP=0;
  54.         delay(10);
  55.         STCP=1;
  56. }
  57. void main()
  58. {
  59.         u8 dat;
  60.         //74hc165
  61.         DIN=1;
  62.         SH =1;
  63.         CLK=1;
  64.         //74hc595
  65.         STCP=1;  //鎖存,上升沿有效
  66.         DAT =1;  //數據
  67.         SHCP=1;  //時鐘
  68.         while(1)
  69.         {
  70.                 dat=Read_74HC165D();
  71.                 Send_74HC595(dat);
  72.                 P2=dat;
  73.                 delay(10000);
  74.         }
  75. }
單片機IO口輸入輸出擴展.zip (153.42 KB, 下載次數: 25)
