void IO_KeyScan(void)
u8 j;
j = IO_KeyState1; //保存上一次狀態
P7 = 0xf0; //X低,讀Y
IO_KeyDelay();
IO_KeyState1 = P7 & 0xf0;
P7 = 0x0f; //Y低,讀X
IO_KeyDelay();
IO_KeyState1 |= (P7 & 0x0f);
IO_KeyState1 ^= 0xff; //取反
if(j == IO_KeyState1) //連續兩次讀相等
j = IO_KeyState;
IO_KeyState = IO_KeyState1;
if(IO_KeyState != 0) //有鍵按下
F0 = 0;
if(j == 0) F0 = 1; //第一次按下
else if(j == IO_KeyState)
if(++IO_KeyHoldCnt >= 20) //1秒后重鍵
IO_KeyHoldCnt = 18;
28
F0 = 1;
if(F0)
j = T_KeyTable[IO_KeyState >> 4];
if((j != 0) && (T_KeyTable[IO_KeyState& 0x0f] != 0))
KeyCode = (u8)(((j - 1) * 4 )+ (T_KeyTable[IO_KeyState &
0x0f]) ); //計算鍵碼,17~32 + 16
else IO_KeyHoldCnt = 0;
P7 = 0xff;
2、主函數
void main(void)
IO_init(); //IO口初始化
LCD_Init();//液晶屏初始化
delay1ms(10);
LCD_Clear(WHITE);//清屏白底
UartInit(); //串口初始化
UartSendStr("按鍵測試\r\n");
KeyCode = 0; //給用戶使用的鍵碼, 1~16有效
IO_KeyState = 0;
IO_KeyState1 = 0;
IO_KeyHoldCnt = 0;
Gui_StrCenter(0,16,RED,BLUE,"KEY 測試程序",16,1);//居中顯示
Show_Str(20,56,BLUE,YELLOW,"KeyCode:",16,0);
//循環
IO_KeyScan();
if(KeyCode>0)
UartSendStr("pressed");
LCD_ShowNum(100,56,KeyCode,2,16);
KeyCode=0;
delay1ms(100);
