查看: 2751|回復: 0
基于stc15f104w單片機的軟件iic oled顯示iic.h oled.h頭文件下載
ID:442609 發表于 2021-6-18 12:55 | 顯示全部樓層 |閱讀模式
  1. void oled_init(void)//初始化ssd1306
  2. {
  3.         delay_ms(500);//延時(必須有)
  4.         oled_wr_byte(0xAE,0);//關閉oled面板
  5.         oled_wr_byte(0x00,0);//設置低位列地址
  6.         oled_wr_byte(0x10,0);//設置高位列地址
  7.         oled_wr_byte(0x40,0);//設置起始行地址設置映射RAM顯示起始行(0x00~0x3F)
  8.         oled_wr_byte(0x81,0);//--設置對比度控制寄存器
  9.         oled_wr_byte(0xCF,0);//設置SEG輸出電流亮度
  10.         oled_wr_byte(0xA1,0);//設置分段/列映射0xa0左右反置 0xa1型正常
  11.         oled_wr_byte(0xC8,0);//設置COM/行掃描方向0xc0上下反置 0xc8型正常
  12.         oled_wr_byte(0xA6,0);//設置正常顯示
  13.         oled_wr_byte(0xA8,0);//設置復用比(1到64)
  14.         oled_wr_byte(0x3F,0);//1/64負載
  15.         oled_wr_byte(0xD3,0);//設置顯示偏移映射RAM計數器(0x00~0x3F)
  16.         oled_wr_byte(0x00,0);//不補償
  17.         oled_wr_byte(0xD5,0);//設置顯示時鐘分頻比/振蕩器頻率
  18.         oled_wr_byte(0x80,0);//設置分頻比,將時鐘設置為100幀/秒
  19.         oled_wr_byte(0xD8,0);
  20.         oled_wr_byte(0x05,0);
  21.         oled_wr_byte(0xD9,0);//設置預充電時間
  22.         oled_wr_byte(0xF1,0);//將預充電設置為15個時鐘,放電設置為1個時鐘
  23.         oled_wr_byte(0xDA,0);//設置com引腳硬件配置
  24.         oled_wr_byte(0x12,0);//
  25.         oled_wr_byte(0xDB,0);//設置vcomh
  26.         oled_wr_byte(0x40,0);//設置VCOM取消選擇級別
  27.         oled_wr_byte(0x20,0);//設置頁面尋址模式(0x00/0x01/0x02)
  28.         oled_wr_byte(0x02,0);//
  29.         oled_wr_byte(0x8D,0);//設置電荷泵啟用/禁用
  30.         oled_wr_byte(0x14,0);//設置(0x10)禁用
  31.         oled_wr_byte(0xA4,0);//禁用整個顯示打開(0xa4/0xa5)
  32.         oled_wr_byte(0xA6,0);//禁用反轉顯示打開(0xa6/a7)
  33.         oled_wr_byte(0xAF,0);//打開oled面板
  34.         fill_picture(0x00);//初始清屏
  35.         oled_set_pos(0,0);//初始光標
  36. }
  1. #include"iic.h"
  2. int main()
  3. {
  4.         oled_init();//初始化
  5.         oled_showchinese(0,0,1);//顯示漢字
  6.         oled_showchinese(16,0,0);
  7.         oled_showchinese(32,0,2);
  8.         oled_showchinese(48,0,2);
  9.         oled_showchinese(64,0,3);
  10.         oled_showchinese(80,0,4);
  11.         oled_showchinese(112,0,5);
  12.   delay_ms(3000);
  13.         oled_showstring(0,2,"Presented by",32);//顯示字符串
  14.         oled_showstring(0,3,"DarkStar244",32);
  15.         oled_showstring(0,4,"114514",16);
  16.         oled_wr_byte(0x2e,0);//關滾動
  17.         oled_wr_byte(0x29,0);//方向,29右,2a左
  18.         oled_wr_byte(0x00,0);//空字節
  19.   oled_wr_byte(0x04,0);//水平起始頁
  20.         oled_wr_byte(0x0cf,0);//水平滾動速度
  21.         oled_wr_byte(0x01,0);//水平結束頁
  22.         oled_wr_byte(0x00,0);//每次垂直滾動位移
  23.         oled_wr_byte(0x2f,0);//開滾動
  24.   while (1){;}
  25. }
下載:
iic.rar (5.06 KB, 下載次數: 42)
參與人數 1黑幣 +40 收起 理由
admin + 40 共享資料的黑幣獎勵!
