最近在做超聲波模塊控制舵機轉(zhuǎn)向。利用這個的在我們生活中也比較常見,最常見的莫過于避障小車了 現(xiàn)在看一下源碼。
#include "HCSR04.h"
#include "sys.h"
#include "delay.h"
* 函數(shù)名:UltrasonicWave_Configuration
* 描述 :超聲波模塊的初始化
* 輸入 :無
* 輸出 :無
void UltrasonicWave_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //PC8接TRIG
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //設為推挽輸出模式
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化外設GPIO
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //PC9接ECH0
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //設為輸入
GPIO_Init(GPIOB,&GPIO_InitStructure);
* 函數(shù)名:UltrasonicWave_StartMeasure
* 描述 :開始測距,發(fā)送一個>10us的脈沖,然后測量返回的高電平時間
* 輸入 :無
* 輸出 :無
void UltrasonicWave_StartMeasure(void)
Trig = 1;
delay_us(15); //延時20US
Trig = 0;
#include "pwm.h"
#include "delay.h"
#include "sys.h"
//舵機模塊的PWM初始化
void PWM_Init()
GPIO_InitTypeDef GPIO_InitStructure; //聲明一個結(jié)構(gòu)體變量,用來初始化GPIO
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;//聲明一個結(jié)構(gòu)體變量,用來初始化定時器
TIM_OCInitTypeDef TIM_OCInitStructure;//根據(jù)TIM_OCInitStruct中指定的參數(shù)初始化外設TIMx
/* 開啟時鐘 */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
/* 配置GPIO的模式和IO口 */
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0;// PA1
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;//復用推挽輸出
GPIO_Init(GPIOA,&GPIO_InitStructure);
//TIM3定時器初始化
TIM_TimeBaseInitStructure.TIM_Period = 1999; //PWM 頻率=72000/(1999+1)=36Khz//設置自動重裝載寄存器周期的值
TIM_TimeBaseInitStructure.TIM_Prescaler = 719;//設置用來作為TIMx時鐘頻率預分頻值
TIM_TimeBaseInitStructure.TIM_ClockDivision = 0;//設置時鐘分割:TDTS = Tck_tim
TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上計數(shù)模式
TIM_TimeBaseInit(TIM2, & TIM_TimeBaseInitStructure);
// GPIO_PinRemapConfig(GPIO_FullRemap_TIM2,ENABLE);//改變指定管腳的映射 //pC6
//PWM初始化 //根據(jù)TIM_OCInitStruct中指定的參數(shù)初始化外設TIMx
TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;//PWM輸出使能
TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
TIM_OC1Init(TIM2,&TIM_OCInitStructure);
//注意此處初始化時TIM_OC1Init而不是TIM_OCInit,否則會出錯。因為固件庫的版本不一樣。
TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);//使能或者失能TIMx在CCR1上的預裝載寄存器
TIM_Cmd(TIM2,ENABLE);//使能或者失能TIMx外設
void pwm(void)
delay_ms(500);
TIM_SetCompare1(TIM2, 50);//0度
delay_ms(1000);
TIM_SetCompare1(TIM2, 100);//45度
delay_ms(1000);
TIM_SetCompare1(TIM2,150);//90度
delay_ms(1000);
TIM_SetCompare1(TIM2, 200);//135度
delay_ms(1000);
TIM_SetCompare1(TIM2, 250);//180度
delay_ms(100);
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "timer.h"
- #include "HCSR04.h"
- #include "led.h"
- #include "pwm.h"
- unsigned long S=0; //定義超聲數(shù)據(jù)
- extern unsigned long Clock_time;
- extern u8 TIM3CH1_CAPTURE_STA; //輸入捕獲狀態(tài)
- extern u16 TIM3CH1_CAPTURE_VAL; //輸入捕獲值
- void ceju()
- Trig=1;
- delay_us(20);
- Trig=0; //啟動信號
- S=0; //清零距離數(shù)據(jù)
- Clock_time=0;
- TIM_Cmd(TIM3, DISABLE); //關(guān)定時器,清零計時變量
- while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5)); //等待檢測到高電平
- Clock_time=0;
- TIM_Cmd(TIM3, ENABLE); //開定時器
- while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5)==1&&Clock_time<47058); //只要是高,一直算時間,如果時間計數(shù)超過 47058,所說有問題,直接跳過,47058不一定精確,是一個大概值,
- S=((Clock_time*2)*340/10000)/2; //時間變量是2us加一,乘以速度,因為時間是us,換成秒是除以1000000,保留兩位小數(shù),所以除以 10000,然后除以二得到單方面距離
- Clock_time=0; //清零數(shù)據(jù)
- GPIO_ResetBits(GPIOD,GPIO_Pin_2);//led 燈
- GPIO_ResetBits(GPIOA,GPIO_Pin_8);//led 燈
- int main(void)
- delay_init(); //延時函數(shù)初始化
- PWM_Init();
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優(yōu)先級,2位響應優(yōu)先級
- LED_Init(); //LED端口初始化
- UltrasonicWave_Configuration(); //初始化超聲IO
- TIM3_Cap_Init(1,72-1); //以1Mhz的頻率計數(shù),第一個選項,最小只能是1
- ceju();
- while(1)
- ceju();
- if(S<20)
- GPIO_SetBits(GPIOD,GPIO_Pin_2);
- // pwm();
- delay_ms(500);
- pwm();
- ceju();
- else
- GPIO_SetBits(GPIOA,GPIO_Pin_8);
- //pwm();
- delay_ms(500);
- ceju();
代碼下載:
超聲波控制舵機.7z
(189.64 KB, 下載次數(shù): 25)
2021-6-7 14:20 上傳
下載積分: 黑幣 -5
