查看: 4238|回復: 5
單片機+24c02存儲+繼電器的電子密碼鎖代碼Proteus仿真圖
  1. /*密碼鎖是8位,密碼可改,10s自鎖,雙色燈顯示,三次輸錯報警 */
  2. //包含頭文件
  3. #include <REG51.h>
  4. #include<intrins.h>
  5. //宏定義
  6. #define LCM_Data  P0                  //將P0口定義為LCM_Data
  7. #define uchar unsigned char
  8. #define uint  unsigned int
  9. #define w 8                                //定義密碼位數
  10. //1602的控制腳
  11. sbit lcd1602_rs=P2^7;
  12. sbit lcd1602_rw=P2^6;
  13. sbit lcd1602_en=P2^5;
  14. sbit Scl=P3^4;                        //24C02串行時鐘
  15. sbit Sda=P3^5;                        //24C02串行數據
  16. sbit ALAM = P2^1;                //報警
  17. sbit KEY = P3^6;                //開鎖
  18. sbit open_led=P2^2;                //開鎖指示燈(選配)綠燈
  19. sbit ALAM_LED=P2^3;                //報警指示燈                紅燈
  20. bit  operation=0;                //操作標志位
  21. bit  pass=0;                        //密碼正確標志
  22. bit  ReInputEn=0;                //重置輸入允許標志
  23. bit  s3_keydown=0;                //3秒按鍵標志位
  24. bit  key_disable=0;                //鎖定鍵盤標志
  25. unsigned char countt0,second;        //t0中斷計數器,秒計數器
  26. void Delay5Ms(void);                //聲明延時函數
  27. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盤掃描控制表
  28. //液晶顯示數據數組
  29. unsigned char code start_line[]        = {"password:       "};
  30. unsigned char code name[]                  = { "===Coded Lock==="};        //顯示名稱
  31. unsigned char code Correct[]         = {"     correct    "};                //輸入正確
  32. unsigned char code Error[]           = {"      error     "};          //輸入錯誤
  33. unsigned char code codepass[]        = {"      pass      "};
  34. unsigned char code LockOpen[]        = {"      open      "};                //OPEN
  35. unsigned char code SetNew[]         = {"SetNewWordEnable"};
  36. unsigned char code Input[]           = {"input:          "};                //INPUT
  37. unsigned char code ResetOK[]         = {"ResetPasswordOK "};
  38. unsigned char code initword[]        = {"Init password..."};
  39. unsigned char code Er_try[]                = {"error,try again!"};
  40. unsigned char code again[]                = {"input again     "};
  41. unsigned char InputData[8];        //輸入密碼暫存區
  42. unsigned char CurrentPassword[8]={5,1,2,1,1,3,1,4};                         //管理員密碼(只可在程序中修改)
  43. unsigned char TempPassword[8];
  44. unsigned char N=0;                                //密碼輸入位數記數
  45. unsigned char ErrorCont;                        //錯誤次數計數
  46. unsigned char CorrectCont;                        //正確輸入計數
  47. unsigned char ReInputCont;                         //重新輸入計數
  48. unsigned char code initpassword[8]={0,0,0,0,0,0,0,0};                        //輸入管理員密碼后將密碼初始為000000
  49. unsigned char sec=0;
  50. //=====================5ms延時==============================
  51. void Delay5Ms(void)
  52. {
  53.         unsigned int TempCyc = 5552;
  54.         while(TempCyc--);
  55. }
  56. //===================400ms延時==============================
  57. void Delay400Ms(void)
  58. {
  59. unsigned char TempCycA = 5;
  60. unsigned int TempCycB;
  61. while(TempCycA--)
  62. {
  63.   TempCycB=7269;
  64.   while(TempCycB--);
  65. }
  66. }
  67. //=============================================================================================
  68. //================================24C02========================================================
  69. //=============================================================================================
  70. void mDelay(uint t) //延時
  71. {
  72.         uchar i;
  73.            while(t--)
  74.            {
  75.                    for(i=0;i<125;i++)
  76.                    {;}
  77.            }
  78. }
  79.
  80. void Nop(void)                  //空操作
  81. {
  82.         _nop_();                  //僅作延時用一條語句大約1us
  83.         _nop_();
  84.         _nop_();
  85.         _nop_();
  86. }
  87. /*****24c02程序參照24c02時序圖*****/
  88. /*起始條件*/
  89. void Start(void)
  90. {
  91.         Sda=1;
  92.         Scl=1;
  93.         Nop();
  94.         Sda=0;
  95.         Nop();
  96. }
  97. /*停止條件*/
  98. void Stop(void)
  99. {
  100.         Sda=0;
  101.         Scl=1;
  102.         Nop();
  103.         Sda=1;
  104.         Nop();
  105. }
  106. /*應答位*/
  107. void Ack(void)
  108. {
  109.         Sda=0;
  110.         Nop();
  111.         Scl=1;
  112.         Nop();
  113.         Scl=0;
  114. }
  115. /*反向應答位*/
  116. void NoAck(void)
  117. {
  118.         Sda=1;
  119.         Nop();
  120.         Scl=1;
  121.         Nop();
  122.         Scl=0;
  123. }
  124. /*發送數據子程序,Data為要求發送的數據*/
  125. void Send(uchar Data)
  126. {
  127.            uchar BitCounter=8;
  128.            uchar temp;
  129.            do
  130.            {
  131.                    temp=Data;                                           //將待發送數據暫存temp
  132.                    Scl=0;
  133.                    Nop();
  134.                    if((temp&0x80)==0x80)                   //將讀到的數據&0x80
  135.                    Sda=1;
  136.                    else
  137.                    Sda=0;
  138.                    Scl=1;
  139.                    temp=Data<<1;                                   //數據左移
  140.                    Data=temp;                                           //數據左移后重新賦值Data
  141.                    BitCounter--;                                   //該變量減到0時,數據也就傳送完成了
  142.            }
  143.            while(BitCounter);                                   //判斷是否傳送完成
  144.            Scl=0;
  145. }
  146. /*讀一字節的數據,并返回該字節值*/
  147. uchar Read(void)
  148. {
  149.     uchar temp=0;
  150.         uchar temp1=0;
  151.         uchar BitCounter=8;
  152.         Sda=1;
  153.         do
  154.         {
  155.                 Scl=0;
  156.                 Nop();
  157.                 Scl=1;
  158.                 Nop();
  159.                 if(Sda)                                   //數據位是否為1
  160.                         temp=temp|0x01;           //為1 temp的最低位為1(|0x01,就是將最低位變為1)
  161.                 else                                   //如果為0
  162.                         temp=temp&0xfe;           //temp最低位為0(&0xfe(11111110)最低位就是0)
  163.                 if(BitCounter-1)           //BitCounter減1后是否為真
  164.                 {
  165.                         temp1=temp<<1;           //temp左移
  166.                         temp=temp1;
  167.                 }
  168.                 BitCounter--;                   //BitCounter減到0時,數據就接收完了
  169.         }
  170.         while(BitCounter);                   //判斷是否接收完成
  171.         return(temp);
  172. }
  173. void WrToROM(uchar Data[],uchar Address,uchar Num)
  174. {
  175.   uchar i;
  176.   uchar *PData;
  177.   PData=Data;
  178.   for(i=0;i<Num;i++)
  179.   {
  180.   Start();
  181.   Send(0xa0);
  182.   Ack();
  183.   Send(Address+i);
  184.   Ack();
  185.   Send(*(PData+i));
  186.   Ack();
  187.   Stop();
  188.   mDelay(20);
  189.   }
  190. }
  191. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  192. {
  193.   uchar i;
  194.   uchar *PData;
  195.   PData=Data;
  196.   for(i=0;i<Num;i++)
  197.   {
  198.   Start();
  199.   Send(0xa0);
  200.   Ack();
  201.   Send(Address+i);
  202.   Ack();
  203.   Start();
  204.   Send(0xa1);
  205.   Ack();
  206.   *(PData+i)=Read();
  207.   Scl=0;
  208.   NoAck();
  209.   Stop();
  210.   }
  211. }
  212. //==================================================================================================
  213. //=======================================LCD1602====================================================
  214. //==================================================================================================
  215. #define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
  216. #define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
  217. //----------------延時函數,后面經常調用----------------------
  218. void delay(uint xms)//延時函數,有參函數
  219. {
  220.         uint x,y;
  221.         for(x=xms;x>0;x--)
  222.          for(y=110;y>0;y--);
  223. }
  224. //--------------------------寫指令---------------------------
  225. write_1602com(uchar com)//****液晶寫入指令函數****
  226. {
  227.         lcd1602_rs=0;//數據/指令選擇置為指令
  228.         lcd1602_rw=0; //讀寫選擇置為寫
  229.         P0=com;//送入數據
  230.         delay(1);
  231.         lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
  232.         delay(1);
  233.         lcd1602_en=0;//en由高變低,產生下降沿,液晶執行命令
  234. }
  235. //-------------------------寫數據-----------------------------
  236. write_1602dat(uchar dat)//***液晶寫入數據函數****
  237. {
  238.         lcd1602_rs=1;//數據/指令選擇置為數據
  239.         lcd1602_rw=0; //讀寫選擇置為寫
  240.         P0=dat;//送入數據
  241.         delay(1);
  242.         lcd1602_en=1; //en置高電平,為制造下降沿做準備
  243.         delay(1);
  244.         lcd1602_en=0; //en由高變低,產生下降沿,液晶執行命令
  245. }
  246. //-------------------------初始化-------------------------
  247. void lcd_init(void)
  248. {
  249.         write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
  250.         write_1602com(0x0c);//開顯示不顯示光標
  251.         write_1602com(0x06);//整屏不移動,光標自動右移
  252.         write_1602com(0x01);//清顯示
  253. }
  254. //========================================================================================
  255. //=========================================================================================
  256. //==============將按鍵值編碼為數值=========================
  257. unsigned char coding(unsigned char m)
  258. {
  259.         unsigned char k;
  260.
  261.         switch(m)
  262.         {
  263.                 case (0x11): k=1;break;
  264.                 case (0x21): k=2;break;
  265.                 case (0x41): k=3;break;
  266.                 case (0x81): k='A';break;
  267.                 case (0x12): k=4;break;
  268.                 case (0x22): k=5;break;
  269.                 case (0x42): k=6;break;
  270.                 case (0x82): k='B';break;
  271.                 case (0x14): k=7;break;
  272.                 case (0x24): k=8;break;
  273.                 case (0x44): k=9;break;
  274.                 case (0x84): k='C';break;
  275.                 case (0x18): k='*';break;
  276.                 case (0x28): k=0;break;
  277.                 case (0x48): k='#';break;
  278.                 case (0x88): k='D';break;
  279.         }
  280.         return(k);
  281. }
  282. //=====================按鍵檢測并返回按鍵值===============================
  283. unsigned char keynum(void)
  284. {
  285.         unsigned char row,col,i;
  286.         P1=0xf0;
  287.         if((P1&0xf0)!=0xf0)
  288.         {
  289.                    Delay5Ms();
  290.         Delay5Ms();
  291.                    if((P1&0xf0)!=0xf0)
  292.                 {
  293.                     row=P1^0xf0;          //確定行線
  294.                         i=0;
  295.                         P1=a[i];                  //精確定位
  296.                         while(i<4)
  297.                         {
  298.                                  if((P1&0xf0)!=0xf0)
  299.                                   {
  300.                                            col=~(P1&0xff);          //確定列線
  301.                                            break;            //已定位后提前退出
  302.                                   }
  303.                                 else
  304.                                   {
  305.                                            i++;
  306.                                            P1=a[i];
  307.                                   }
  308.                         }
  309.                 }
  310.                 else
  311.                 {
  312.                         return 0;
  313.                 }
  314.
  315.                 while((P1&0xf0)!=0xf0);
  316.                 return (row|col);                         //行線與列線組合后返回
  317.         }
  318.         else return 0;                                 //無鍵按下時返回0
  319. }
  320. //=======================一聲提示音,表示有效輸入========================
  321. void OneAlam(void)
  322. {
  323.         ALAM=0;
  324.         Delay5Ms();
  325.     ALAM=1;
  326. }
  327. //========================二聲提示音,表示操作成功========================
  328. void TwoAlam(void)
  329. {
  330.         ALAM=0;
  331.         Delay5Ms();
  332.     ALAM=1;
  333.     Delay5Ms();
  334.         ALAM=0;
  335.         Delay5Ms();
  336.     ALAM=1;
  337. }
  338. //========================三聲提示音,表示錯誤========================
  339. void ThreeAlam(void)
  340. {
  341.         ALAM=0;
  342.         ALAM_LED=!ALAM_LED;
  343.         Delay5Ms();
  344.     ALAM=1;
  345.     Delay5Ms();
  346.         ALAM=0;
  347.         ALAM_LED=!ALAM_LED;
  348.         Delay5Ms();
  349.     ALAM=1;
  350.     Delay5Ms();
  351.         ALAM=0;
  352.         ALAM_LED=!ALAM_LED;
  353.         Delay5Ms();
  354.     ALAM=1;
  355.         ALAM_LED=1;
  356. }
  357. //=====================顯示輸入的N個數字,用H代替以便隱藏============================
  358. void DisplayOne(void)
  359. {
  360. //        DisplayOneChar(9+N,1,'*');
  361.         write_1602com(yi+5+N);
  362.         write_1602dat('*');
  363. }
  364. //=======================顯示提示輸入=========================
  365. void DisplayChar(void)
  366. {
  367.         unsigned char i;
  368.         if(pass==1)
  369.         {
  370.                 //DisplayListChar(0,1,LockOpen);
  371.                 write_1602com(er);                                   //在二行開始顯示
  372.                 for(i=0;i<16;i++)
  373.                 {
  374.                         write_1602dat(LockOpen[i]);           //顯示open 開鎖成功
  375.                 }
  376.         }
  377.         else
  378.         {
  379.                 if(N==0)
  380.                 {
  381.                         //DisplayListChar(0,1,Error);
  382.                         write_1602com(er);
  383.                         for(i=0;i<16;i++)
  384.                         {
  385.                                 write_1602dat(Error[i]);        //顯示錯誤
  386.                         }
  387.                 }
  388.                 else
  389.                 {
  390.                         //DisplayListChar(0,1,start_line);
  391.                         write_1602com(er);
  392.                         for(i=0;i<16;i++)
  393.                         {
  394.                                 write_1602dat(start_line[i]);//顯示開始輸入
  395.                         }
  396.                 }
  397.         }
  398. }
  399. void DisplayInput(void)
  400. {
  401.         unsigned char i;
  402.         if(CorrectCont==1)
  403.         {
  404.                 //DisplayListChar(0,0,Input);
  405.                 write_1602com(er);
  406.                 for(i=0;i<16;i++)
  407.                 {
  408.                         write_1602dat(Input[i]);        //顯示Input
  409.                 }
  410.         }
  411. }
  412. //========================重置密碼==================================================
  413. //==================================================================================
  414. void ResetPassword(void)
  415. {
  416.         unsigned char i;
  417.         unsigned char j;
  418.         if(pass==0)
  419.         {
  420.                 pass=0;
  421.                 DisplayChar();           //顯示錯誤
  422.                 ThreeAlam();           //沒開鎖時按下重置密碼報警3聲
  423.         }
  424.         else                                   //開鎖狀態下才能進行密碼重置程序
  425.         {
  426.             if(ReInputEn==1)   //開鎖狀態下,ReInputEn置1,重置密碼允許
  427.                 {
  428.                         if(N==8)           //輸入8位密碼
  429.                         {
  430.                                 ReInputCont++;                        //密碼次數計數
  431.                                 if(ReInputCont==2)                //輸入兩次密碼
  432.                                 {
  433.                                         for(i=0;i<8;)
  434.                                         {
  435.                                                 if(TempPassword[i]==InputData[i])        //將兩次輸入的新密碼作對比
  436.                                                         i++;
  437.                                                 else        //如果兩次的密碼不同
  438.                                                 {
  439.                                                         //DisplayListChar(0,1,Error);
  440.                                                         write_1602com(er);
  441.                                                         for(j=0;j<16;j++)
  442.                                                         {
  443.        write_1602dat(Error[j]);        //顯示錯誤Error
  444.                                                         }
  445.                                                         ThreeAlam();                        //錯誤提示
  446.                                                         pass=0;                                        //關鎖
  447.                                                         ReInputEn=0;                        //關閉重置功能,
  448.                                                         ReInputCont=0;
  449.                                                         DisplayChar();
  450.                                                 //        ReInputCont=0; //////////////
  451.                                                         break;
  452.                                                 }
  453.                                         }
  454.                                         if(i==8)
  455.                                         {
  456.                                                 //DisplayListChar(0,1,ResetOK);
  457.                                                 write_1602com(er);
  458.                                                 for(j=0;j<16;j++)
  459.                                                 {
  460.                                                         write_1602dat(ResetOK[j]);          //密碼修改成功,顯示
  461.                                                 }
  462.                                                 TwoAlam();                                //操作成功提示
  463.                                                  WrToROM(TempPassword,0,8);                //將新密碼寫入24C02存儲
  464.                                                 ReInputEn=0;
  465.                                         }
  466.                                         ReInputCont=0;
  467.                                         CorrectCont=0;
  468.                                 }
  469.                                 else                                          //輸入一次密碼時
  470.                                 {
  471.                                         OneAlam();
  472.                                         //DisplayListChar(0, 1, again);                 //顯示再次輸入一次
  473.                                         write_1602com(er);
  474.                                         for(j=0;j<16;j++)
  475.                                         {
  476.                                                 write_1602dat(again[j]);                        //顯示再輸入一次
  477.                                         }
  478.                                         for(i=0;i<8;i++)
  479.                                         {
  480.                                                 TempPassword[i]=InputData[i];                //將第一次輸入的數據暫存起來
  481.                                         }
  482.                                 }
  483.                         N=0;                                                //輸入數據位數計數器清零
  484.                    }
  485.             }
  486.         }
  487. }
  488. //=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
  489. void Alam_KeyUnable(void)
  490. {
  491.         P1=0x00;
  492.         {
  493.                 ALAM=~ALAM;                                 //蜂鳴器一直閃爍鳴響
  494.                 ALAM_LED=!ALAM_LED;
  495.                 Delay5Ms();
  496.         }
  497. }
  498. //=======================取消所有操作============================================
  499. void Cancel(void)
  500. {
  501.         unsigned char i;
  502.         unsigned char j;
  503.         //DisplayListChar(0, 1, start_line);
  504.         write_1602com(er);
  505.         for(j=0;j<16;j++)
  506.         {
  507.                 write_1602dat(start_line[j]);          //顯示開機輸入密碼界面
  508.         }
  509.         TwoAlam();                                //提示音
  510.         for(i=0;i<8;i++)
  511.         {
  512.                 InputData[i]=0;                //將輸入密碼清零
  513.         }
  514.         KEY=1;                                        //關閉鎖
  515.         ALAM=1;                                        //報警關
  516.         ALAM_LED=1;
  517.         operation=0;                        //操作標志位清零
  518.         pass=0;                                        //密碼正確標志清零
  519.         ReInputEn=0;                        //重置輸入充許標志清零
  520.         ErrorCont=0;                        //密碼錯誤輸入次數清零
  521.         CorrectCont=0;                        //密碼正確輸入次數清零
  522.         ReInputCont=0;                        //重置密碼輸入次數清零
  523.         open_led=1;                                //開鎖LED關閉 (選配)
  524.         s3_keydown=0;
  525.         key_disable=0;                        //鎖定鍵盤標志清零
  526.         N=0;                                        //輸入位數計數器清零
  527. }
  528. //==========================確認鍵,并通過相應標志位執行相應功能===============================
  529. void Ensure(void)
  530. {
  531.         unsigned char i,j;
  532.         RdFromROM(CurrentPassword,0,8);                                         //從24C02里讀出存儲密碼
  533.     if(N==8)
  534.         {
  535.                 TR1=0;
  536.                 sec=0;
  537.             if(ReInputEn==0)                                                        //重置密碼功能未開啟
  538.                 {
  539.                         for(i=0;i<8;)
  540.                            {
  541.                                 if(CurrentPassword[i]==InputData[i])        //判斷輸入密碼和24c02中的密碼是否相同
  542.                                 {
  543.                                         i++;        //相同一位 i就+1
  544.                                 }
  545.                                 else        //如果有密碼不同
  546.                                 {
  547.                                         ErrorCont++;                                                //錯誤次數++
  548.                                         if(ErrorCont==3)                        //錯誤輸入計數達三次時,報警并鎖定鍵盤
  549.                                         {
  550.                                                 write_1602com(er);
  551.                                                 for(i=0;i<16;i++)
  552.                                                 {
  553.                                                         write_1602dat(Error[i]);
  554.                                                 }
  555.                                                 do
  556.                                                 Alam_KeyUnable();
  557.                                                 while(1);
  558.                                         }
  559.                                         else                                         //錯誤次數小于3次時,鎖死鍵盤3秒,然后重新可以輸入
  560.                                         {
  561.                                                 TR0=1;                                //開啟定時
  562.                                                 key_disable=1;                        //鎖定鍵盤
  563.                                                 pass=0;                                        //pass位清零
  564.                                                 break;                                        //跳出
  565.                                         }
  566.                                 }
  567.                         }
  568.                         if(i==8)                                         //密碼輸入對時
  569.                         {
  570.                                 CorrectCont++;                                        //輸入正確變量++
  571.                                 if(CorrectCont==1)                                //正確輸入計數,當只有一次正確輸入時,開鎖
  572.                                 {
  573.                                         //DisplayListChar(0,1,LockOpen);
  574.                                         write_1602com(er);
  575.                                         for(j=0;j<16;j++)
  576.                                         {
  577.                                                 write_1602dat(LockOpen[j]);                  //顯示open開鎖畫面
  578.                                         }
  579.                                         TwoAlam();                        //操作成功提示音
  580.                                         KEY=0;        //開鎖
  581.                                         pass=1;        //置正確標志位
  582.                                         TR0=1;        //開啟定時
  583.                                         open_led=0;        //開鎖指示燈亮(選配)
  584.                                         for(j=0;j<8;j++)        //將輸入清除
  585.                                         {
  586.                                                 InputData[i]=0;        //開鎖后將輸入位清零
  587.                                         }
  588.                                 }
  589.                                 else        //當兩次正確輸入時,開啟重置密碼功能
  590.                                 {
  591.                                         //DisplayListChar(0,1,SetNew);
  592.                                         write_1602com(er);
  593.                                         for(j=0;j<16;j++)
  594.                                         {
  595.                                                 write_1602dat(SetNew[j]);                                        //顯示重置密碼界面
  596.                                         }
  597.                                         TwoAlam();        //操作成功提示
  598.                                         ReInputEn=1;        //允許重置密碼輸入
  599.                                         CorrectCont=0;        //正確計數器清零
  600.                                 }
  601.                           }
  602.
  603.                         else                        //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
  604.                         {
  605.                                 if((InputData[0]==5)&&(InputData[1]==1)&&(InputData[2]==2)&&(InputData[3]==1)&&(InputData[4]==1)&&(InputData[5]==3)&&(InputData[6]==1)&&(InputData[7]==4))
  606.                                    {
  607.                                         WrToROM(initpassword,0,8);                                 //強制將初始密碼寫入24C02存儲
  608.                                         //DisplayListChar(0,1,initword);                        //顯示初始化密碼
  609.                                         write_1602com(er);
  610.                                         for(j=0;j<16;j++)
  611.                                         {
  612.                                                 write_1602dat(initword[j]);                                //顯示初始化密碼
  613.                                         }
  614.                                         TwoAlam();        //成功提示音
  615.                                         Delay400Ms();        //延時400ms
  616.                                         TwoAlam();        //成功提示音
  617.                                         N=0;        //輸入位數計數器清零
  618.                                 }
  619.                                 else        //密碼輸入錯誤
  620.                                 {
  621.                                         //DisplayListChar(0,1,Error);
  622.                                         write_1602com(er);
  623.                                         for(j=0;j<16;j++)
  624.                                         {
  625.                                                 write_1602dat(Error[j]);                                 //顯示錯誤信息
  626.                                         }
  627.                                         ThreeAlam();        //錯誤提示音
  628.                                         pass=0;
  629.                                 }
  630.                         }
  631.                 }
  632.                 else        //當已經開啟重置密碼功能時,而按下開鎖鍵,
  633.                 {
  634.                         //DisplayListChar(0,1,Er_try);
  635.                         write_1602com(er);
  636.                         for(j=0;j<16;j++)
  637.                         {
  638.                                 write_1602dat(Er_try[j]);                          //錯誤,請重新輸入
  639.                         }
  640.                         ThreeAlam();                                                          //錯誤提示音
  641.                 }
  642.         }
  643.         else                                   //密碼沒有輸入到8位時,按下確認鍵時
  644.         {
  645.                 //DisplayListChar(0,1,Error);
  646.                 write_1602com(er);
  647.                 for(j=0;j<16;j++)
  648.                 {
  649.                         write_1602dat(Error[j]);                 //顯示錯誤
  650.                 }
  651.                 ThreeAlam();        //錯誤提示音
  652.                 pass=0;
  653.         }
  654.
  655.         N=0;        //將輸入數據計數器清零,為下一次輸入作準備
  656.         operation=1;
  657. }
  658. //==============================主函數===============================
  659. void main(void)
  660. {
  661.         unsigned char KEY,NUM;
  662.         unsigned char i,j;
  663.         P1=0xFF;
  664.         TMOD=0x11;
  665.         TL0=0xB0;
  666.         TH0=0x3C;
  667.         TH1=0x4b;
  668.         TL1=0xff;
  669.         EA=1;
  670.         ET0=1;
  671.         ET1=1;
  672.         TR0=0;
  673.         TR1=0;                                           //打開定時器開關
  674.         Delay400Ms();         //啟動等待,等LCM講入工作狀態
  675.         lcd_init();         //LCD初始化
  676.         write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
  677.         for(i=0;i<16;i++)
  678.         {
  679.                 write_1602dat(name[i]);//向液晶屏寫開機畫面
  680.         }
  681.         write_1602com(er);
  682.         for(i=0;i<16;i++)
  683.         {
  684.                 write_1602dat(start_line[i]);//寫輸入密碼等待界面
  685.         }
  686.         write_1602com(er+9);        //設置光標位置
  687.         write_1602com(0x0f);        //設置光標為閃爍
  688.         Delay5Ms(); //延時片刻(可不要)
  689.         N=0;        //初始化數據輸入位數
  690.         while(1)                 //進入循環
  691.         {
  692.                 if(key_disable==1)                                                //鎖定鍵盤標志為1時
  693.                         Alam_KeyUnable();                                        //報警鍵盤鎖
  694.                 else
  695.                         ALAM=1;        //關報警
  696.                 KEY=keynum();                                                        //讀按鍵的位置碼
  697.                 if(KEY!=0)        //當有按鍵按下時
  698.                 {
  699.                         if(key_disable==1)                                        //鎖定鍵盤標志為1時
  700.                         {
  701.                                 second=0;                                                //秒清零
  702.                         }
  703.                         else        //沒有鎖定鍵盤時
  704.                         {
  705.                                 NUM=coding(KEY);                                //根據按鍵的位置將其編碼,編碼值賦值給NUM
  706.                                 {
  707.                                         switch(NUM)                                        //判斷按鍵值
  708.                                         {
  709. ……………………
  710. …………限于本文篇幅 余下代碼請從51黑下載附件…………
51密碼鎖.zip (662.91 KB, 下載次數: 119)
收藏收藏5 分享淘帖 頂 踩
ID:1067626 發表于 2023-3-22 16:14 來自觸屏版 | 只看該作者
密碼是什么
ID:1085706 發表于 2023-6-27 20:46 | 只看該作者
哥你的密碼鎖密碼是什么啊
ID:1085706 發表于 2023-6-27 20:47 | 只看該作者
哥這個密碼搞出來了么
ID:969770 發表于 2023-6-27 21:09 | 只看該作者
ID:1085706 發表于 2023-6-27 21:40 | 只看該作者
cxh1944 發表于 2023-6-27 21:09
這個不是管理員密碼嗎,輸入進去后不是還要在輸入么,
