查看: 2138|回復: 0
EDA中此程序只能一位數碼管顯示幫忙看看怎樣實現兩位數碼管顯示
ID:723220 發表于 2021-5-9 16:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
   LIBRARY IEEE;
   USE IEEE.STD_LOGIC_1164.ALL;
   use ieee.std_logic_arith.all;
   use ieee.std_logic_unsigned.all;
ENTITY Vhdl1 IS
PORT (CP,R,EN:IN STD_LOGIC;
CO:OUT BIT;
Y:OUT INTEGER RANGE 0 TO 10;
LED : out std_logic_vector(6 downto 0));
END Vhdl1;
architecture RT of Vhdl1 is
signal Q:INTEGER RANGE 0 TO 10;
BEGIN
PROCESS(CP,R,EN)
   BEGIN
        IF R='1' THEN Q<=0;
        ELSIF(EN = '1')THEN
        IF(CP'EVENT AND CP='1')THEN
        IF Q=9 THEN
                CO<='1';
                Q<=0;
                ELSE
                Q<=Q+1;
                CO<='0';
        END IF;
        END if;
    END IF;
     Y<=Q;
END PROCESS;
with Q select
  LED<="1000000" when 0,
           "1111001" when 1,
           "0100100" when 2,
            "0110000" when 3,
           "0011001" when 4,
     "0010010" when 5,
         "0000010" when 6,
         "1111000" when 7,
         "0000000" when 8,
     "0010000" when 9,
     "1111111" when others;
END RT;
