int main(void)
float ole_roll,diff_roll_value;
USER_DATA_t time_infor;
char str1[10];
//variables to calculate the on-board LED brightness that reflects the heartbeats
uint32_t un_min, un_max, un_prev_data;
int i;
int32_t n_brightness;
float f_temp;
u8 temp_num=0;
u8 temp[6];
u8 str[100];
u8 dis_hr=0,dis_spo2=0;
/* Configure the Priority Group to 2 bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
OLED_Init(); //初始化OLED
OLED_Clear(); //OLED 清屏
delay_ms(500);
USART1_Config(); //串口1(電腦)配置
Bluetooth_Init(); //藍(lán)牙初始化
Rtc_Init(); //RTC初始化(用于顯示時(shí)間和日期、鬧鐘)
Beep_Init(); //鬧鐘提醒
LED_Init(); //LED燈初始化
MPU_Init(); //MPU6050初始化(用于抬手喚醒屏幕、計(jì)步)
TIM4_Int_Init(5000,8400);//500ms
KEY_EXIT_Init();
delay_ms(1863);
while(mpu_dmp_init())
printf("MPU6050 ERROR \r\n");
delay_ms(500);
GPIO_Keyboard_Configuration(); //游戲方向控制鍵盤
GUI_Init();//游戲界面初始化
TIM_Cmd(TIM2,ENABLE);//打開定時(shí)器2,用于判斷20秒無操作熄滅屏幕
/*計(jì)步*/
dmp_get_pedometer_step_count(&STEPS); //MPU6050自帶計(jì)步功能,并且從第7步才可以讀取的到數(shù)據(jù)
sprintf(str1,"步數(shù):%ld",STEPS);
printf("%s\r\n",str);
OLED_ShowCHinese(0,6,0);//步
OLED_ShowCHinese(18,6,1);//數(shù)
OLED_ShowCHinese(36,6,2);//:
if(STEPS>=10)
OLED_ShowNum(40,6,STEPS,3,16);
OLED_ShowNum(40,6,0,3,16);
//printf("dsgkhsd kjhdksahgkljfahglkfadhgkldfag\r\n");
if(BLUETOOTH_STATE==1)
OLED_DrawBMP(0,0,127,2,BLUETOOTH_ON);
OLED_DrawBMP(0,0,127,2,BLUETOOTH_OFF);
/*顯示時(shí)間、日期和手機(jī)修改時(shí)間、日期、鬧鐘*/
Clock_Infor_display(time_infor);
/*操作20秒無操作,熄滅oled*/
if(operrate_flag > 50)
operrate_flag = 0;
TIM_Cmd(TIM2,DISABLE);//關(guān)閉定時(shí)器2,停止計(jì)數(shù)
OLED_Display_Off(); //關(guān)閉oled顯示
/*游戲*/
if(g_key0_flag==1)
g_key0_flag=0;
g_key2_flag=0;
operrate_flag = 0;
OLED_Display_On();
OLED_DrawBMP(0,0,128,8,STARTGAME);//開頭動(dòng)畫
delay_s(2);
Get_Command();
Show_Score();
GUI_Refresh(map);//刷新地圖
if(GameOver())
OLED_Clear();
OLED_DrawBMP(0,0,128,8,GAMEOVER);
if(g_key2_flag==1)
g_key2_flag=0;
OLED_Clear();
break;
TIM_Cmd(TIM2,ENABLE);//開啟定時(shí)器2,停止計(jì)數(shù)
/*抬手喚醒*/
if(res==0)
diff_roll_value = abs(ole_roll-roll);//取絕對(duì)值
if(diff_roll_value >= 9)
diff_roll_value=0;
operrate_flag = 0;
OLED_Display_On();
ole_roll = roll;
printf("pitch=%f,roll=%f,yaw=%f\r\n",pitch,roll,yaw);
delay_ms(1000);
res=1;
delay_s(5);
