100黑幣
我使用的是12C5A60S2,郭天祥的單片機(jī)開(kāi)發(fā)板,網(wǎng)上找的驅(qū)動(dòng),num1就是沒(méi)有保存進(jìn)EEPROM里去,不知道是哪出的問(wèn)題,感謝大神們幫幫忙。文件如下:#include <reg52.H>
#include <intrins.h>
#define RdCommand 0x01 //定義ISP的操作命令
#define prgCommand 0x02
#define EraseCommand 0x03
#define Error 1
#define Ok 0
#define WaitTime 0x01 //定義CPU的等待時(shí)間
sfr ISP_DATA = 0xE2;
sfr ISP_ADDRH = 0xE3;
sfr ISP_ADDRL = 0xE4 ;
sfr ISP_CMD = 0xE5;
sfr ISP_TRIG = 0xE6;
sfr ISP_CONTR = 0xE7;
sbit duan=P2^6;
sbit wei=P2^7;
sbit key1=P3^4;
uchar code table[]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71 };
uchar num;
void delayms(uint xms) //毫秒延時(shí)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void display(uchar shi,uchar ge) //數(shù)碼管顯示子函數(shù)
duan=1;
P0=table[shi]; //送位選數(shù)據(jù)前關(guān)閉所有顯示,防止打開(kāi)位選鎖存時(shí)
duan=0;
P0=0xff;
wei=1;
P0=0xfe;
wei=0;
delayms(5);
duan=1;
P0=table[ge]; //送位選數(shù)據(jù)前關(guān)閉所有顯示,防止打開(kāi)位選鎖存時(shí)
duan=0;
P0=0xff;
wei=1;
P0=0xfd;
wei=0;
delayms(5);
/*======================打開(kāi) ISP,IAP 功能=====================*/
void ISP_IAP_enable(void)
EA=0; //關(guān)中斷
ISP_CONTR=ISP_CONTR & 0x18 ; //0001,1000
ISP_CONTR= ISP_CONTR| 0x01;//WaitTime; //寫(xiě)入硬件延時(shí)
ISP_CONTR=ISP_CONTR| 0x80; //ISPEN=1
/*=======================關(guān)閉 ISP,IAP==========================*/
void ISP_IAP_disable(void)
ISP_CONTR= ISP_CONTR & 0x7f; //ISPEN=0
ISP_TRIG=0x00;
EA=1; //開(kāi)中斷
/*=======================公共的觸發(fā)代碼=========================*/
void ISPgoon(void)
ISP_IAP_enable(); //打開(kāi)ISP,IAP功能
ISP_TRIG=0x46; //觸發(fā)ISP_IAP命令字節(jié)1
ISP_TRIG=0xb9; //觸發(fā)ISP_IAP命令字節(jié)2
_nop_();
/*=======================字節(jié)讀=================================*/
unsigned char byte_read(unsigned int byte_addr)
ISP_ADDRH=(unsigned char)(byte_addr >>8); //地址賦值
ISP_ADDRL=(unsigned char)(byte_addr &0x00ff);
ISP_CMD=ISP_CMD &0xf8; //清除低3位
ISP_CMD=ISP_CMD | RdCommand; //寫(xiě)讀命令
ISPgoon(); //觸發(fā)執(zhí)行
ISP_IAP_disable(); //關(guān)閉ISP,IAP功能
return(ISP_DATA); //返回讀到的數(shù)據(jù)
/*========================扇區(qū)擦除================================*/
void SectorErase(unsigned int sector_addr)
unsigned int iSectorAddr;
iSectorAddr=(sector_addr &0xfe00); //取扇區(qū)地址
ISP_ADDRH=(unsigned char )(iSectorAddr>>8);
ISP_ADDRL=0x00;
ISP_CMD=ISP_CMD &0xf8; //清空低3位
ISP_CMD=ISP_CMD|EraseCommand; //擦除命令3
/*=========================字節(jié)寫(xiě)====================================*/
void byte_write(unsigned int byte_addr,unsigned char original_data)
ISP_ADDRH=(unsigned char)(byte_addr>>8); //取地址
ISP_ADDRL=(unsigned char)(byte_addr & 0xff00);
ISP_CMD =ISP_CMD & 0xf8; //清低3位
ISP_CMD =ISP_CMD | prgCommand; //寫(xiě)命令2
ISP_DATA =original_data; //寫(xiě)入數(shù)據(jù)準(zhǔn)備
ISP_IAP_disable(); //關(guān)閉IAP功能
/*========================main========================================*/
uchar a,b,num1;
TMOD=0x01 ; //設(shè)定定時(shí)器0為工作方式1
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
num1=byte_read(0x2000); // 程序開(kāi)始時(shí)讀取EEPROM中數(shù)據(jù)
if(num1>=60) //防止首次上電時(shí)讀取出錯(cuò)
num1=0;
if(num>=20)
// if(key1==0) //調(diào)試用按鍵
num=0;
num1++;
SectorErase(0x2000);
byte_write(0x2000,num1);
if(num1==60)
num1=0;
a=num1/10;
b=num1%10;
display(a,b);
void timer0() interrupt 1
num++;
