查看: 2956|回復: 4
超聲波HC-SR04與STC89C52RC用1602顯示
看著大家都再使用超聲波模塊,樓主也想試試,看效果怎么樣,說干就干。
  1. #include<reg52.h>
  2. #define LCD1602_DB  P0
  3. #define  u8 unsigned  char
  4. #define  u16  unsigned   int
  5. sbit LCD1602_RS = P2^6;
  6. sbit LCD1602_EN = P2^5;
  7. sbit LCD1602_RW = P2^7;
  8. sbit TX     =P1^3;
  9. sbit RX     =P1^4;
  10. bit  flag   =0;
  11. u16  time   =0;
  12. int  S      =0;
  13. int  H,L;
  14. u8 list[]={"0.00M"};
  15. u8 code asc[15]={'0','1','2','3','4','5','6','7','8','9','.','-','M'};
  16. void Read_Busy()
  17. {
  18.     u8 sta;
  19.     LCD1602_DB = 0xff;
  20.     LCD1602_RS = 0;
  21.     LCD1602_RW = 1;
  22.     do
  23.     {
  24.         LCD1602_EN = 1;
  25.         sta = LCD1602_DB;
  26.         LCD1602_EN = 0;
  27.     }while(sta & 0x80);
  28. }
  29. void Lcd1602_Write_Cmd(u8 cmd)
  30. {
  31.     Read_Busy();
  32.     LCD1602_RS = 0;
  33.     LCD1602_RW = 0;
  34.     LCD1602_DB = cmd;
  35.     LCD1602_EN = 1;
  36.     LCD1602_EN = 0;
  37. }
  38. void Lcd1602_Write_Data(u8 dat)
  39. {
  40.     Read_Busy();
  41.     LCD1602_RS = 1;
  42.     LCD1602_RW = 0;
  43.     LCD1602_DB = dat;
  44.     LCD1602_EN = 1;
  45.     LCD1602_EN = 0;
  46. }
  47. void LcdSetCursor(u8 x,u8 y)
  48. {
  49.     u8 addr;
  50.     if(y == 0)
  51.         addr = 0x00 + x;
  52.     else
  53.         addr = 0x40 + x;
  54.
  55.     Lcd1602_Write_Cmd(addr|0x80);
  56. }
  57. void LcdShowStr(u8 x,u8 y,u8 *str)
  58. {
  59.     LcdSetCursor(x,y);
  60.     while(*str != '\0')
  61.     {
  62.         Lcd1602_Write_Data(*str++);
  63.     }
  64. }
  65. void InitLcd1602()
  66. {
  67.     Lcd1602_Write_Cmd(0x38);
  68.     Lcd1602_Write_Cmd(0x0c);
  69.     Lcd1602_Write_Cmd(0x06);
  70.     Lcd1602_Write_Cmd(0x01);
  71. }
  72. void Delay1ms()                //@12.000MHz
  73. {
  74.    unsigned char i, j;
  75.          i = 2;
  76.          j = 239;
  77.          do
  78.          {
  79.                    while (--j);
  80.          } while (--i);
  81. }
  82. void Delay(u16 t)
  83. {
  84.          while (--t)
  85.          Delay1ms();
  86. }
  87. void Conut(void)
  88. {
  89.    time=TH0*256+TL0;
  90.          TH0=0;
  91.          TL0=0;
  92.          S=(time*1.7)/100;
  93.    if (S<35)S=S+1;
  94.    list[0]=asc[S%1000/100];
  95.    list[1]=asc[10];
  96.    list[2]=asc[S%100/10];
  97.    list[3]=asc[S%10];
  98.    list[4]=asc[12];
  99. }
  100. void  StartModule()
  101. {
  102.    TX=1;
  103.    Delay(800);
  104.    TX=0;
  105. }
  106. void Timer0Init(void)                //@12.0000MHz
  107. {
  108.    TMOD &= 0xF0;
  109.          TMOD |= 0x01;
  110.          TL0 = 0;
  111.          TH0 = 0;
  112.          TF0 = 0;
  113. }
  114. void main()
  115. {
  116.    Timer0Init();
  117.    InitLcd1602();
  118.    H=200;
  119.    L=100;
  120.    LcdShowStr(5,0,list);
  121.    while(1)
  122.    {
  123.       StartModule();
  124.             while(!RX);
  125.             TR0=1;
  126.             while(RX);
  127.             TR0=0;
  128.       Conut();
  129.       LcdShowStr(5,0,list);
  130.          }
  131. }
工程文件下載:
超聲波HC-SR04與STC89C52RC用1602顯示.rar (34.27 KB, 下載次數: 49)
收藏收藏2 分享淘帖 頂 踩
ID:506248 發表于 2021-5-1 16:35 | 只看該作者
雖然程序調通了,但說實話感覺準確性不是很高,樓主水平有限僅供大家參考,網上這類程序還是蠻多的。
ID:506248 發表于 2021-5-1 16:37 | 只看該作者
我們畫電路圖,LCD1602并沒有畫,根據源程序應該可以知道是接在那些IO上的。
ID:942433 發表于 2021-6-22 18:08 | 只看該作者
能加你 幫我過一個設計嗎 大佬
