- /************* 功能說明 **************
- STC15W4K60S4 2路10位PWM基本應用.
- PWM0 為10位PWM.
- PWM1 為10位PWM.
- #define MAIN_Fosc 24000000L //定義主時鐘
- #include "STC15Fxxxx.H"
- #define PCA0 0
- #define PCA1 1
- #define PCA_Counter 3
- #define PCA_P12_P11_P10 (0<<4)
- #define PCA_P34_P35_P36 (1<<4)
- #define PCA_P24_P25_P26 (2<<4)
- #define PCA_Mode_PWM 0x42 //B0100_0010
- #define PCA_Mode_Capture 0
- #define PCA_Mode_SoftTimer 0x48 //B0100_1000
- #define PCA_Mode_HighPulseOutput 0x4c //B0100_1100
- #define PCA_Clock_1T (4<<1)
- #define PCA_Clock_2T (1<<1)
- #define PCA_Clock_4T (5<<1)
- #define PCA_Clock_6T (6<<1)
- #define PCA_Clock_8T (7<<1)
- #define PCA_Clock_12T (0<<1)
- #define PCA_Clock_Timer0_OF (2<<1)
- #define PCA_Clock_ECI (3<<1)
- #define PCA_Rise_Active (1<<5)
- #define PCA_Fall_Active (1<<4)
- #define PCA_PWM_8bit (0<<6)
- #define PCA_PWM_7bit (1<<6)
- #define PCA_PWM_6bit (2<<6)
- #define PCA_PWM_10bit (3<<6)
- void PCA_config(void);
- void UpdatePwm(u8 PCA_id, u16 pwm_value);
- void main(void)
- PCA_config();
- // EA = 1;
- UpdatePwm(PCA0,800);
- UpdatePwm(PCA1,400);
- while (1)
- // 函數: void PCA_config(void)
- // 描述: PCA初始化函數。
- // 參數: none.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-12-15
- // 備注:
- CR = 0;
- CH = 0;
- CL = 0;
- // AUXR1 = (AUXR1 & ~(3<<4)) | PCA_P12_P11_P10; P1n_standard(0x07); //切換到P1.2 P1.1 P1.0 (ECI CCP0 CCP1)
- // AUXR1 = (AUXR1 & ~(3<<4)) | PCA_P24_P25_P26; P2n_standard(0x70); //切換到P2.4 P2.5 P2.6 (ECI CCP0 CCP1)
- AUXR1 = (AUXR1 & ~(3<<4)) | PCA_P34_P35_P36; P3n_standard(0x70); //切換到P3.4 P3.5 P3.6 (ECI CCP0 CCP1)
- CMOD = (CMOD & ~(7<<1)) | PCA_Clock_1T; //選擇時鐘源
- CMOD &= ~1; //禁止溢出中斷
- // PPCA = 1; //高優先級中斷
- CCAPM0 = PCA_Mode_PWM; //工作模式
- PCA_PWM0 = (PCA_PWM0 & ~(3<<6)) | PCA_PWM_10bit; //PWM寬度
- CCAP0L = 0xff;
- CCAP0H = 0xff;
- CCAPM1 = PCA_Mode_PWM; //工作模式
- PCA_PWM1 = (PCA_PWM1 & ~(3<<6)) | PCA_PWM_10bit; //PWM寬度
- CCAP1L = 0xff;
- CCAP1H = 0xff;
- CR = 1;
- // 函數: UpdatePwm(u8 PCA_id, u16 pwm_value)
- // 描述: 更新PWM值.
- // 參數: PCA_id: PCA序號. 取值 PCA0,PCA1
- // pwm_value: pwm值, 0~1024, 這個值是輸出高電平的時間, 0對應連續的低電平, 1024對應連續的高電平.
- // 返回: none.
- // 版本: V1.0, 2012-11-22
- if(pwm_value > 1024) return; //PWM值過大, 退出
- if(PCA_id == PCA0)
- if(pwm_value == 0)
- PCA_PWM0 |= 0x32;
- CCAP0H = 0xff;
- else
- pwm_value = ~(pwm_value-1) & 0x3ff;
- PCA_PWM0 = (PCA_PWM0 & ~0x32) | ((u8)(pwm_value >> 4) & 0x30);
- CCAP0H = (u8)pwm_value;
- else if(PCA_id == PCA1)
- PCA_PWM1 |= 0x32;
- CCAP1H = 0xff;
- else
- PCA_PWM1 = (PCA_PWM1 & ~0x32) | ((u8)(pwm_value >> 4) & 0x30);
- CCAP1H = (u8)pwm_value;
匯編版本:
81-15W4K-PCA-2路10位硬件PWM.rar
(41.37 KB, 下載次數: 40)
2021-5-1 07:57 上傳
STC15W4K60S4 2路10位PWM基本應用 下載積分: 黑幣 -5
