查看: 2130|回復(fù): 1
第十一屆藍(lán)橋杯單片機(jī)代碼
ID:909832 發(fā)表于 2021-4-28 21:02 | 顯示全部樓層 |閱讀模式
#include "stc15f2k60s2.h"
#include "iic.h"
#include "ds18b20.h"
                                                         //0    1    2    3    4   5   6     7    8    9   熄滅   C    P
code unsigned char tab[] = { 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xc6,0x8C};
unsigned char dspbuf[8] = {10,10,10,10,10,10,10,10};  //顯示緩沖區(qū)
unsigned char dspcom=0;//數(shù)碼管碼段
unsigned char yi=10,er=10,san=10,si=10,wu=10,liu=10,qi=10,ba=10;
unsigned char key_temp;
unsigned char key_num;//鍵值
bit key_flag;//按鍵掃描標(biāo)記位 10ms
unsigned char key_press;//消抖的標(biāo)記變量
unsigned char key_value=0xff;
unsigned char key_re;
unsigned char intr;
bit s4_cnt=0;//按鍵s4切換狀態(tài)
bit s5_cnt=0;//按鍵s5切換狀態(tài)
bit flag_set=1;//進(jìn)入設(shè)置狀態(tài)標(biāo)記位
unsigned char T_min=20;//溫度下限值
unsigned char T_max=30;//溫度上限值
unsigned char Tmin;
unsigned char Tmax;
unsigned char temper=25;//實(shí)時(shí)溫度
unsigned char p_flag=0xff;
unsigned char t_cnt=0;
//上電初始化
void power_init()
        P2=0XA0;P0=0X00;
        P2=0X80;P0=0XFF;
        P2=0XC0;P0=0XFF;
        P2=0XE0;P0=0XFF;
void display()//數(shù)碼管顯示
        dspbuf[0]=yi;
        dspbuf[1]=er;
        dspbuf[2]=san;
        dspbuf[3]=si;
        dspbuf[4]=wu;
        dspbuf[5]=liu;
        dspbuf[6]=qi;
        dspbuf[7]=ba;
        P2=0x00;
        P0=0xff; //消隱
        P2=(0xE0|(P2&0x1f));
        P2&=0x1f;
        P0=0x01<<dspcom;
        P2=(0xC0|(P2&0x1f));
        P2&=0x1f;
        P0=tab[dspbuf[dspcom]];
        P2&=0x1f;
        if(++dspcom>=8)
           dspcom=0;
unsigned char read_keyboard(void)  //獨(dú)立按鍵
    static unsigned char col;
        P3 = 0xff;
    if((P3&0x0f)!=0x0f) //有按鍵按下 或者抖動(dòng)
        key_press++;
                key_press = 0;
    if(key_press == 3)
                key_press = 0;
                key_re = 1;
                if((P3 & 0x01) == 0)        col = 1;
                if((P3 & 0x02) == 0)        col = 2;
                if((P3 & 0x04) == 0)        col = 3;
                if((P3 & 0x08) == 0)        col = 4;
        //連續(xù)三次檢測(cè)到按鍵被按下,并且該按鍵已經(jīng)釋放
        P3 = 0xff;
    if(((key_re == 1) && ((P3&0x0f)==0x0f)))
        key_re = 0;
                key_value=col;
        return key_value;
    return 0xff;  //無(wú)按鍵按下或被按下的按鍵未被釋放
void Timer0Init(void)                //1毫秒@12.000MHz
        AUXR |= 0x80;                //定時(shí)器時(shí)鐘1T模式
        TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
        TL0 = 0x20;                //設(shè)置定時(shí)初值
        TH0 = 0xD1;                //設(shè)置定時(shí)初值
        TF0 = 0;                //清除TF0標(biāo)志
        TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
        ET0=1;
        EA=1;
void timer0(void) interrupt 1        //定時(shí)器0的中斷處理函數(shù)          1ms
        display();//數(shù)碼管顯示
           if(++intr>=10)
           intr=0;
           key_flag=1;
        t_cnt++;
        if(s4_cnt==0)
                yi=11,er=10,san=10,si=10,wu=10,liu=10,qi=temper/10,ba=temper%10;
           yi=12,er=10,san=10,si=T_max/10,wu=T_max%10,liu=10,qi=T_min/10,ba=T_min%10;
        if(s4_cnt==0&&flag_set==1)
                flag_set=0;
                if(T_max<T_min)
                        T_max=Tmax;
                        T_min=Tmin;
                        p_flag=0xf7;
                        Tmax=T_max;Tmin=T_min;
                        p_flag=0xff;
        else if(s4_cnt==1&&flag_set==0)
                flag_set=1;
        //上電初始化
        power_init();
        Timer0Init();
                if(t_cnt>=200)
                         t_cnt=0;
                        temper=rd_temperature();         //獲取溫度值
                        if(temper>Tmax)
                                 SetDACOut(204);
                                 P2=0X00;P0=0XFF;P2=0X80;P0=0XFE&p_flag;
                        else if(temper>=Tmin)
                                  SetDACOut(153);
                                  P2=0X00;P0=0XFF;P2=0X80;P0=0XFD&p_flag;
                                  SetDACOut(102);
                                  P2=0X00;P0=0XFF;P2=0X80;P0=0XFB&p_flag;
                 if(key_flag)//按鍵標(biāo)記10ms進(jìn)來(lái)一次
                        key_flag=0;
                        key_temp=read_keyboard();
                        if(key_temp!=0xff) //有效按鍵
                                key_num=key_temp;
                                switch(key_num)
                                        case 1:           //s7                   -
                                                if(s4_cnt==1)
                                                         if(s5_cnt==0)
        if(T_min--<=0)
        T_min=0;
        if(T_max--<=0)
        T_max=0;
                                                break;
                                        case  2://s6                 +
                                                if(s4_cnt==1)
                                                         if(s5_cnt==0)
        if(++T_min>=100)
        T_min=99;
        if(++T_max>=100)
        T_max=99;
                                                break;
                                        case  3://s5
                                                s5_cnt=~s5_cnt;
                                                break;
                                        case  4://s4        界面切換
                                                 s4_cnt=~s4_cnt;
                                                break;
評(píng)分
參與人數(shù) 1黑幣 +10 收起 理由
haokey + 10 和我的代碼風(fēng)格一樣,在定時(shí)器里計(jì)數(shù)++,按.
查看全部評(píng)分
ID:569384 發(fā)表于 2021-5-5 10:54 | 顯示全部樓層
可以直接去公司上班了
