查看: 2165|回復: 0
用24C04與1602LCD設計電子密碼鎖程序
ID:501297 發表于 2021-4-27 17:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. void main()
  2. {
  3.    uchar i = 0;
  4.    uchar IIC_Password[10];
  5.    uchar IS_Valid_User = 0;
  6.    P0 = 0xFF;
  7.    P1 = 0xFF;
  8.    P2 = 0xFF;
  9.    TMOD = 0x02;                     //T0設置為8位自動重裝模式
  10.    TH0 = 175;
  11.    TL0 = 175;
  12.    TR0 = 1;                         //啟動T0
  13.    DelayMS(10);
  14.    LCD_Init();                      //初始化LCD
  15.    IIC_24C04_Init();                //初始化24C04
  16.    Display_String(Title_Text,0x00); //在第1行顯示標題
  17.    //24C04的內容已由初始化BIN文件導入
  18.    //將24C04中預先寫入的密碼讀入pass
  19.    RecString(0xa0, 0 , IIC_Password, 6);
  20.    IIC_Password[6] = '\0';
  21.    while(1)
  22.    {
  23.       P1 = 0xF0;
  24.       if(P1 != 0xF0) KeyNo = Keys_Scan();  //掃描鍵盤獲取鍵序號KeyNo
  25.       switch ( KeyNo )
  26.       {
  27.            case 0:  case 1: case 2: case 3: case 4:
  28.            case 5:  case 6: case 7: case 8: case 9:
  29.                    if ( i<= 5 )             //密碼限制在6位以內
  30.                    {
  31.                         //如果i為0則執行一次清屏
  32.                         if (i ==0) Display_String("                ",0x40);
  33.                         UserPassword[ i] = KeyNo + '0';
  34.                         UserPassword[i+1] = '\0';
  35.                         DSY_BUFFER[ i] = '*';
  36.                         DSY_BUFFER[i+1] = '\0';
  37.                         Display_String(DSY_BUFFER,0x40);
  38.                         i++;
  39.                     }
  40.                     break;
  41.            case 10: //按A鍵開鎖
  42.                     if (strcmp(UserPassword,IIC_Password) == 0)
  43.                     {
  44.                        LED_OPEN = 0;  //點亮LED
  45.                        Clear_Password();
  46.                        Display_String("Unlock OK!      ",0x40);
  47.                        IS_Valid_User = 1;
  48.                     }
  49.                     else
  50.                     {
  51.                        LED_OPEN =1;   //關閉LED
  52.                        Clear_Password();
  53.                        Display_String("ERROR !         ",0x40);
  54.                        IS_Valid_User = 0;
  55.                     }
  56.                     i = 0;
  57.                     break;
  58.            case 11: //按B鍵上鎖
  59.                     LED_OPEN =1;
  60.                     Clear_Password();
  61.                     Display_String(Title_Text,0x00);
  62.                     Display_String("                ",0x40);
  63.                     i = 0;
  64.                     IS_Valid_User = 0;
  65.                     break;
  66.            case 12: //按C鍵設置新密碼
  67.                     //如果是合法用戶則提示輸入新密碼
  68.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  69.                     else
  70.                     {
  71.                        i = 0;
  72.                        Display_String("New Password:   ",0x00);
  73.                        Display_String("                ",0x40);
  74.                      }
  75.                     break;
  76.            case 13: //按D鍵保存新密碼
  77.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  78.                     else
  79.                     {
  80.                        SendString(0xa0, 0 , UserPassword, 6);
  81.                        //重新讀入剛寫的密碼
  82.                        RecString(0xa0, 0 , IIC_Password, 6);
  83.                        IIC_Password[6] = '\0';
  84.                        i = 0;
  85.                        Display_String(Title_Text,0x00);
  86.                        Display_String("Password Saved! ",0x40);
  87.                      }
  88.                     break;
  89.            case 14: //按E鍵消除所有輸入
  90.                     i = 0;
  91.                     Clear_Password();
  92.                     Display_String("                ",0x40);
  93.        }
  94.        Beep();
  95.        DelayMS(100);
  96.        P1= 0xF0;
  97.        while (P1 != 0xF0);    //如果有鍵未釋放則等待
  98.        while (P1 == 0xF0);    //如果沒有再次按下按鍵則等待
  99.    }
  100. }
