- /* 名稱:?jiǎn)纹瑱C(jī)與PC通信
- 說(shuō)明:?jiǎn)纹瑱C(jī)可接收PC發(fā)送的數(shù)字字符,按下單片機(jī)的K1鍵后,單片機(jī)可向PC發(fā)送字符串。在Proteus環(huán)境下完成本實(shí)驗(yàn)時(shí),需要安裝Virtual Serial Port Driver和串口調(diào)試助手。本例緩沖100個(gè)數(shù)字字符,緩沖滿后新數(shù)字從前面開(kāi)始存放(環(huán)形緩沖)。
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar Receive_Buffer[101]; //接收緩沖
- uchar Buf_Index=0; //緩沖空間索引
- //數(shù)碼管編碼
- uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
- //延時(shí)
- void DelayMS(uint ms)
- uchar i;
- while(ms--) for(i=0;i<120;i++);
- //主程序
- void main()
- uchar i;
- P0=0x00;
- Receive_Buffer[0]=-1;
- SCON=0x50; //串口模式1,允許接收
- TMOD=0x20; //T1工作模式2
- TH1=0xfd; //波特率9600
- TL1=0xfd;
- PCON=0x00; //波特率不倍增
- EA=1;EX0=1;IT0=1;
- ES=1;IP=0x01;
- TR1=1;
- while(1)
- for(i=0;i<100;i++)
- { //收到-1為一次顯示結(jié)束
- if(Receive_Buffer[ i]==-1) break;
- P0=DSY_CODE[Receive_Buffer[ i]];
- DelayMS(200);
- DelayMS(200);
- //串口接收中斷函數(shù)
- void Serial_INT() interrupt 4
- uchar c;
- if(RI==0) return;
- ES=0; //關(guān)閉串口中斷
- RI=0; //清接收中斷標(biāo)志
- c=SBUF;
- if(c>='0'&&c<='9')
- { //緩存新接收的每個(gè)字符,并在其后放-1為結(jié)束標(biāo)志
- Receive_Buffer[Buf_Index]=c-'0';
- Receive_Buffer[Buf_Index+1]=-1;
- Buf_Index=(Buf_Index+1)%100;
- ES=1;
- void EX_INT0() interrupt 0 //外部中斷0
- uchar *s="這是由8051發(fā)送的字符串!\r\n";
- uchar i=0;
- while(s[i]!='\0')
- SBUF=s[i];
- while(TI==0);
- TI=0;
- i++;
