查看: 1984|回復(fù): 0
STM32 LoRa綜合實(shí)驗(yàn)程序
ID:437105 發(fā)表于 2021-4-7 16:30 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
主要代碼
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "usmart.h"
  8. #include "malloc.h"
  9. #include "sdio_sdcard.h"
  10. #include "w25qxx.h"
  11. #include "ff.h"
  12. #include "exfuns.h"
  13. #include "text.h"
  14. #include "usart3.h"
  15. #include "string.h"
  16. #include "touch.h"
  17. #include "lora_app.h"
  18. //主函數(shù)
  19. int main(void)
  20. {
  21.         u8 key=0;
  22.         u8 fontok=0;
  23.
  24.         delay_init();                                            //延時(shí)函數(shù)初始化
  25.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設(shè)置中斷優(yōu)先級分組為組2:2位搶占優(yōu)先級,2位響應(yīng)優(yōu)先級
  26.         uart_init(115200);                                         //串口初始化為115200
  27.     LCD_Init();
  28.         tp_dev.init();                                                    //初始化觸摸屏
  29.         LED_Init();
  30.         KEY_Init();
  31.     W25QXX_Init();                                                      //初始化W25Q128
  32.         my_mem_init(SRAMIN);                                    //初始化內(nèi)部內(nèi)存池
  33.         exfuns_init();                                                    //為fatfs相關(guān)變量申請內(nèi)存
  34.          f_mount(fs[0],"0:",1);                                 //掛載SD卡
  35.          f_mount(fs[1],"1:",1);                                 //掛載FLASH.
  36.         key=KEY_Scan(0);
  37.         if(key==KEY0_PRES&&((tp_dev.touchtype&0X80)==0))//強(qiáng)制校準(zhǔn)
  38.         {
  39.                 LCD_Clear(WHITE);                                    //清屏
  40.                 TP_Adjust();                                              //屏幕校準(zhǔn)
  41.                 TP_Save_Adjdata();
  42.                 LCD_Clear(WHITE);                                    //清屏
  43.         }
  44.         fontok=font_init();                                        //檢查字庫是否OK
  45.         if(fontok||key==KEY1_PRES)                            //需要更新字庫
  46.         {
  47.                 LCD_Clear(WHITE);                                    //清屏
  48.                  POINT_COLOR=RED;                                    //設(shè)置字體為紅色
  49.                 LCD_ShowString(60,50,200,16,16,"ALIENTEK STM32");
  50.                 while(SD_Init())                                    //檢測SD卡
  51.                 {
  52.                         LCD_ShowString(60,70,200,16,16,"SD Card Failed!");
  53.                         delay_ms(200);
  54.                         LCD_Fill(60,70,200+60,70+16,WHITE);
  55.                         delay_ms(200);
  56.                 }
  57.                 LCD_ShowString(60,70,200,16,16,"SD Card OK");
  58.                 LCD_ShowString(60,90,200,16,16,"Font Updating...");
  59.                 key=update_font(20,110,16,"0:");           //從SD卡更新
  60.                 while(key)                                 //更新失敗
  61.                 {
  62.                         LCD_ShowString(60,110,200,16,16,"Font Update Failed!");
  63.                         delay_ms(200);
  64.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  65.                         delay_ms(200);
  66.                 }
  67.                 LCD_ShowString(60,110,200,16,16,"Font Update Success!");
  68.                 delay_ms(1500);
  69.                 LCD_Clear(WHITE);                         //清屏
  70.         }
  71.         Lora_Test();//主測試
  72.
  73. }
完整程序如附件
ATK-LORA-01模塊實(shí)驗(yàn).7z (1.31 MB, 下載次數(shù): 22)
