超聲波測距 + 串口發(fā)送距離
#include<reg51.h>
#include<intrins.h>
sbit trig=P1^7;
sbit echo=P3^2;
float tA,dis;
uint distance,timeh,timel;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=1100;y>0;y--);
void delay20us()
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void initT1_SCI()
SM0 = 0; //
SM1 = 1; //10位異步收發(fā),波特率可變
TMOD = 0x21;
TH1 = 0xfd;
TL1 = 0xfd;
TR1 = 1;
void Trig()
trig = 0;
echo = 0;
TH0 = 0;
TL0 = 0;
trig = 1;
delay20us();
trig = 0;
while(echo == 0);
EX0 = 1; //外部中斷0允許
ET0 = 1; //定時器0中斷允許
TR0 = 1; //定時器0運行控制位
delay(60);
void putChar(uchar c)
SBUF = c;
while( !TI ); TI = 0;
void putStr(uchar str[], uint n)
while( n-- )
putChar( str[n] );
int main()
initT1_SCI();
EA = 1;
Trig();
return 0;
void T0_time() interrupt 1
TH0 = 0;
TL0 = 0;
void ex0()interrupt 0
uchar num[2];
timeh = TH0;
timel = TL0;
tA = (timeh * 256 + timel) * 1.09;
dis = tA * 0.17;
distance = (int)dis;
num[1] = distance / 256; num[0] = distance % 256;
putStr(num, 2);
TH0 = 0;
TL0 = 0;
TR0 = 0;
EX0 = 0; //關(guān)閉外部中斷0
ET0 = 0; //關(guān)閉定時器1中斷
Correct
#include<reg51.h>
#include<intrins.h>
#include "6x8.h"
#include "LQ12864.h"
sbit trig=P2^0;
sbit echo=P3^2;
uint succeed;
float tA,dis;
uint flagCG = 0;
uint flag600 = 0, flag50 = 1;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void delay20us()
void initT1_SCI()
TH0 = 0;
TL0 = 0;
TR0 = 0;
SM0 = 0; //
TMOD = 0x21;
TH1 = 0xfd;
TL1 = 0xfd;
TR1 = 1;
SBUF = c;
while( n-- )
putChar( str[n] );
void display()
unsigned char SPEED[4] = {0,0,0,1};
SPEED[2]=distance/100; ready(6,0,SPEED[2]);
SPEED[1]=(distance%100)/10; ready(12,0,SPEED[1]);
SPEED[0]=distance%10; ready(18,0,SPEED[0]);
putStr(SPEED, 3);
void Trig()
trig = 0;
echo = 0;
succeed = 0;
TH0 = 0;
TL0 = 0;
trig = 1;
delay20us();
trig = 0;
while(echo == 0);
EX0 = 1; //外部中斷0允許
ET0 = 1; //定時器0中斷允許
delay(60);
LCD_Init();
initT1_SCI();
EA = 1;
Trig();
if(succeed)
LCD_Cler_6x8(0,0,4);
display();
delay(100);
TH0 = 0;
TL0 = 0;
succeed = 0;
timeh = TH0;
timel = TL0;
dis = tA * 0.17;
succeed = 1;
TH0 = 0;
TL0 = 0;
TR0 = 0;
