采用51單片機(jī)+超聲波模塊
提供了另外一種超聲波測速及其程序仿真文件
超聲波模塊電路連接
Trig ------- P2^1;
Echo ------- P2^0;
VCC -------- +5v
GND -------- GND
void Conut(void) //距離數(shù)據(jù)處理函數(shù)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.7)/100; //算出來是CM
if((S>=700)||flag==1) //超出測量范圍顯示“-”
flag=0;
DisplayOneChar(0, 1, ASCII[11]);
DisplayOneChar(1, 1, ASCII[10]); //顯示點(diǎn)
DisplayOneChar(2, 1, ASCII[11]);
DisplayOneChar(3, 1, ASCII[11]);
DisplayOneChar(4, 1, ASCII[12]); //顯示M
disbuff[0]=S%1000/100;
disbuff[1]=S%1000%100/10;
disbuff[2]=S%1000%10 %10;
DisplayOneChar(0, 1, ASCII[disbuff[0]]);
DisplayOneChar(2, 1, ASCII[disbuff[1]]);
DisplayOneChar(3, 1, ASCII[disbuff[2]]);
//中斷函數(shù)
void zd0() interrupt 1 //T0中斷用來計(jì)數(shù)器溢出,超過測距范圍
flag=1; //中斷溢出標(biāo)志
//主函數(shù)
void main(void)
TMOD=0x01; //設(shè)T0為方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1; //允許T0中斷
EA=1; //開啟總中斷
InitLcd1602();
LcdShowStr(0,0,PuZh);
StartModule();
while(!Echo); //當(dāng)RX為零時(shí)等待
TR0=1; //開啟計(jì)數(shù)
while(Echo); //當(dāng)RX為1計(jì)數(shù)并等待
TR0=0; //關(guān)閉計(jì)數(shù)
Conut(); //計(jì)算
delayms(80);
LCD1602顯示函數(shù)
void Read_Busy() //忙檢測函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
unsigned char sta; //
LCD1602_DB = 0xff;
LCD1602_RS = 0;
LCD1602_RW = 1;
do
LCD1602_EN = 1;
sta = LCD1602_DB;
LCD1602_EN = 0; //使能,用完就拉低,釋放總線
}while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd) //寫命令
Read_Busy();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_EN = 1;
LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat) //寫數(shù)據(jù)
Read_Busy();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_EN = 1;
LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y) //坐標(biāo)顯示
unsigned char addr;
if(y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個(gè)字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
X |= 0x80; //算出指令碼
Lcd1602_Write_Cmd(X); //發(fā)命令字
Lcd1602_Write_Data(DData); //發(fā)數(shù)據(jù)
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str) //顯示字符串
LcdSetCursor(x,y); //當(dāng)前字符的坐標(biāo)
while(*str != '\0')
Lcd1602_Write_Data(*str++);
void InitLcd1602() //1602初始化
Lcd1602_Write_Cmd(0x38); //打開,5*8,8位數(shù)據(jù)
Lcd1602_Write_Cmd(0x0c);
Lcd1602_Write_Cmd(0x06);
Lcd1602_Write_Cmd(0x01); //清屏
全部資料51hei下載地址:
仿真代碼.7z
(156.31 KB, 下載次數(shù): 146)
2022-11-22 19:34 上傳
點(diǎn)擊文件名下載附件
程序原理圖及其仿真
評(píng)分
查看全部評(píng)分
