查看: 1415|回復: 0
matlab圖像處理程序 關于二值化
ID:898840 發表于 2021-3-31 08:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
i4=im2double(J);
[L,num]=bwlabel(i4,8); % 區域標記
figure,imagesc(L);axis tight;axis equal; %標記顏色顯示
[r,c] = find(L == 1);%調用標記區域
MIN1 = min(c)-5;           %計算橫最小坐標點
MIN2 = min(r)-5;           %計算縱最小坐標點
MAX1 = max(c)+5;           %計算橫最大坐標點
MAX2 = max(r)+5;           %計算縱最大坐標點
%數值檢查,顯示初步框選區域
  if(MIN1 > 0)
      MMIN1=MIN1;
      MMIN1 = 1;
end
if(MIN2 > 0)
  MMIN2=MIN2;
      MMIN2 = 1;
end
[mm nn] = size(i4);
if(MAX1 < nn)
      MMAX1=MAX1;
      MMAX1 = nn-1;
end
if(MAX2 < mm)
      MMAX2=MAX2;
      MMAX2 = mm-1;
end
cxk=i4(MMIN2:MMAX2,MMIN1:MMAX1); %將初步框選區域保存
%figure,imshow(1-cxk);           %顯示初步框選區域
  %邊緣檢測
[BW1,thresh1]=edge(cxk,'roberts');  %Roberts邊緣算子
[BW2,thresh2]=edge(cxk,'sobel');    %Sobel邊緣算子
[BW3,thresh3]=edge(cxk,'prewitt');  %Prewitt邊緣算子
subplot(2,2,1);
imshow(cxk);           %顯示初步框選區域
subplot(2,2,2);
imshow(BW1);           %顯示Roberts邊緣算子結果
subplot(2,2,3);
imshow(BW2);           %顯示Sobel邊緣算子結果
subplot(2,2,4);
imshow(BW3);           %顯示Prewitt邊緣算子結果
CXKK=im2double(BW1);
%投影
im=CXKK;
[m n]=size(im); % m n分別為圖像的行 列數
% 進行垂直投影
for y=1:n
     V1(y)=sum(im(1:m,y));
end
% 進行水平投影
for x=1:m
   V2(x)=sum(im(x,:));
end
%投影結果
Q1=im2bw(V1);   %算長
i1=sum(Q1,2)-1;
Q2=im2bw(V2);   %算寬
i2=sum(Q2,2)-1;
%計算四點坐標
[LL,num2]=bwlabel(BW1,8); % 區域標記
[rr,cc] = find(LL == 1);%調用標記區域
MINN1=min(rr)+MIN1;    %橫最小
MINN2=min(cc)+MIN2+4;    %縱最小
aaaaa(1,:)=[MINN1;MINN2];       %左上點坐標
bbbbb(1,:)=[MINN1+i1;MINN2];    %右上點坐標
ccccc(1,:)=[MINN1;MINN2+i2];    %左下點坐標
ddddd(1,:)=[MINN1+i1;MINN2+i2]; %右下點坐標
imshow(1-i4)         % 顯示二值化圖像
hold on
plot([MINN1 MINN1+i1],[MINN2 MINN2],'m','LineWidth',2)
plot([MINN1+i1 MINN1+i1],[MINN2 MINN2+i2],'m','LineWidth',2)
plot([MINN1+i1 MINN1],[MINN2+i2 MINN2+i2],'m','LineWidth',2)
plot([MINN1 MINN1],[MINN2+i2 MINN2],'m','LineWidth',2)
plot([MINN1 MINN1+i1],[MINN2 MINN2],'mo','LineWidth',2)
plot([MINN1+i1 MINN1+i1],[MINN2 MINN2+i2],'mo','LineWidth',2)
plot([MINN1+i1 MINN1],[MINN2+i2 MINN2+i2],'mo','LineWidth',2)
plot([MINN1 MINN1],[MINN2+i2 MINN2],'mo','LineWidth',2)
V1=0;
V2=0;
Q1=0;
Q2=0;
i1=0;
i2=0;
%2222222222
[r,c] = find(L == 2);%調用標記區域
%數值檢查,顯示初步框選區域
  if(MIN1 > 0)
      MMIN1=MIN1;
      MMIN1 = 1;
end
if(MIN2 > 0)
  MMIN2=MIN2;
      MMIN2 = 1;
end
[mm nn] = size(i4);
if(MAX1 < nn)
      MMAX1=MAX1;
      MMAX1 = nn-1;
end
if(MAX2 < mm)
      MMAX2=MAX2;
      MMAX2 = mm-1;
end
  %邊緣檢測
%subplot(2,2,1);
%imshow(cxk);           %顯示初步框選區域
%subplot(2,2,2);
%imshow(BW1);           %顯示Roberts邊緣算子結果
%subplot(2,2,3);
%imshow(BW2);           %顯示Sobel邊緣算子結果
%subplot(2,2,4);
%imshow(BW3);           %顯示Prewitt邊緣算子結果
%投影
im=CXKK;
% 進行垂直投影
for y=1:n
end
% 進行水平投影
for x=1:m
   V2(x)=sum(im(x,:));
end
%投影結果
Q1=im2bw(V1);   %算長
i1=sum(Q1,2);
Q2=im2bw(V2);   %算寬
i2=sum(Q2,2);
%計算四點坐標
MINN1=MIN1+min(rr)+3;    %橫最小
MINN2=MIN2+min(cc);    %縱最小
aaaaa(2,:)=[MINN1;MINN2];       %左上點坐標
bbbbb(2,:)=[MINN1+i1;MINN2];    %右上點坐標
ccccc(2,:)=[MINN1;MINN2+i2];    %左下點坐標
ddddd(2,:)=[MINN1+i1;MINN2+i2]; %右下點坐標
hold on
V1=0;
V2=0;
Q1=0;
Q2=0;
i1=0;
i2=0;
%3333333333333
[r,c] = find(L == 4);%調用標記區域
%數值檢查,顯示初步框選區域
  if(MIN1 > 0)
      MMIN1=MIN1;
      MMIN1 = 1;
end
if(MIN2 > 0)
  MMIN2=MIN2;
      MMIN2 = 1;
end
[mm nn] = size(i4);
if(MAX1 < nn)
      MMAX1=MAX1;
      MMAX1 = nn-1;
end
if(MAX2 < mm)
      MMAX2=MAX2;
      MMAX2 = mm-1;
end
  %邊緣檢測
%subplot(2,2,1);
%subplot(2,2,2);
%subplot(2,2,3);
%subplot(2,2,4);
%投影
im=CXKK;
% 進行垂直投影
for y=1:n
end
% 進行水平投影
for x=1:m
   V2(x)=sum(im(x,:));
end
%投影結果
Q1=im2bw(V1);   %算長
i1=sum(Q1,2)-1;
Q2=im2bw(V2);   %算寬
i2=sum(Q2,2)-1;
%計算四點坐標
MINN2=min(cc)+MIN2;    %縱最小
aaaaa(3,:)=[MINN1;MINN2];       %左上點坐標
bbbbb(3,:)=[MINN1+i1;MINN2];    %右上點坐標
ccccc(3,:)=[MINN1;MINN2+i2];    %左下點坐標
ddddd(3,:)=[MINN1+i1;MINN2+i2]; %右下點坐標
hold on
V1=0;
V2=0;
Q1=0;
Q2=0;
i1=0;
i2=0;
%44444444
[r,c] = find(L == 3);%調用標記區域
%數值檢查,顯示初步框選區域
  if(MIN1 > 0)
      MMIN1=MIN1;
      MMIN1 = 1;
end
if(MIN2 > 0)
  MMIN2=MIN2;
      MMIN2 = 1;
end
[mm nn] = size(i4);
if(MAX1 < nn)
      MMAX1=MAX1;
      MMAX1 = nn-1;
end
if(MAX2 < mm)
      MMAX2=MAX2;
      MMAX2 = mm-1;
end
% figure,imshow(1-cxk);           %顯示初步框選區域
  %邊緣檢測
%subplot(2,2,1);
%subplot(2,2,2);
%subplot(2,2,3);
%subplot(2,2,4);
%投影
im=CXKK;
% 進行垂直投影
for y=1:n
end
% 進行水平投影
for x=1:m
   V2(x)=sum(im(x,:));
end
%投影結果
Q1=im2bw(V1);   %算長
i1=sum(Q1,2);
Q2=im2bw(V2);   %算寬
i2=sum(Q2,2)-1;
%計算四點坐標
MINN1=MMIN1+min(cc);    %橫最小
MINN2=MMIN2+min(rr);    %縱最小
aaaaa(4,:)=[MINN1;MINN2];       %左上點坐標
bbbbb(4,:)=[MINN1+i1;MINN2];    %右上點坐標
ccccc(4,:)=[MINN1;MINN2+i2];    %左下點坐標
ddddd(4,:)=[MINN1+i1;MINN2+i2]; %右下點坐標
hold on
V1=0;
V2=0;
Q1=0;
Q2=0;
i1=0;
i2=0;
%555555555555
[r,c] = find(L == 5);%調用標記區域
%數值檢查,顯示初步框選區域
  if(MIN1 > 0)
      MMIN1=MIN1;
      MMIN1 = 1;
end
if(MIN2 > 0)
  MMIN2=MIN2;
      MMIN2 = 1;
end
[mm nn] = size(i4);
if(MAX1 < nn)
      MMAX1=MAX1;
      MMAX1 = nn-1;
end
if(MAX2 < mm)
      MMAX2=MAX2;
      MMAX2 = mm-1;
end
  %邊緣檢測
%subplot(2,2,1);
%subplot(2,2,2);
%subplot(2,2,3);
%subplot(2,2,4);
%投影
im=CXKK;
% 進行垂直投影
for y=1:n
end
% 進行水平投影
for x=1:m
   V2(x)=sum(im(x,:));
end
%投影結果
Q1=im2bw(V1);   %算長
i1=sum(Q1,2)-1;
Q2=im2bw(V2);   %算寬
i2=sum(Q2,2);
%計算四點坐標
MINN1=min(cc)+MMIN1;    %橫最小
MINN2=min(rr)+MMIN2;    %縱最小
aaaaa(5,:)=[MINN1;MINN2];       %左上點坐標
bbbbb(5,:)=[MINN1+i1;MINN2];    %右上點坐標
ccccc(5,:)=[MINN1;MINN2+i2];    %左下點坐標
ddddd(5,:)=[MINN1+i1;MINN2+i2]; %右下點坐標
hold on
hold off
