請問一下這個程序里為什么數據都不能存入at24c02中
- #include <STC15F2K60S2.h>
- #include "ds1302.h"
- #include "iic.h"
- typedef unsigned char u8;
- typedef unsigned int u16;
- sbit COL1 = P4^4;
- sbit COL2 = P4^2;
- sbit COL3 = P3^5;
- sbit COL4 = P3^4;
- bit flat,add,m=0,del,non=0;
- u8 timer=0,key_val=0,n=0,mom=0;
- u16 f=0,fre=0,cyl=0,vol=0,vh=20,vl=10;
- u8 num[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- u8 write_time[7]={0x80,0x82,0x84,0x86,0x88,0x8a,0x8c};
- u8 read_time[7]={0x81,0x83,0x85,0x87,0x89,0x8b,0x8d};
- u8 time[7]={0x55,0x59,0x23,0x01,0x02,0x03,0x12};
- u8 seg[8];
- void delay(u8 x)
- while(x--);
- void select(u8 deat,u8 date)
- switch(deat)
- case 4:COL3=0;P2=(P2&0x1f)|0x80;break;
- case 5:COL3=0;P2=(P2&0x1f)|0xa0;break;
- case 6:COL3=0;P2=(P2&0x1f)|0xc0;break;
- case 7:COL3=0;P2=(P2&0x1f)|0xe0;break;
- P0 = date;
- void close()
- select(4,0xff);
- select(5,0x00);
- select(6,0x00);
- select(7,0xff);
- void ds1302_init()
- u8 i;
- Write_Ds1302_Byte(0x8e,0x00);
- for(i=0;i<7;i++)
- Write_Ds1302_Byte(write_time[i],time[i]);
- Write_Ds1302_Byte(0x8e,0x80);
- void timer_init()
- TMOD = 0x15;
- AUXR |= 0x00;
- TH0 = 0xff;
- TL0 = 0xff;
- TH1 = (65535-50000)/256;
- TL1 = (65535-50000)%256;
- ET0 = 1;
- ET1 = 1;
- TR0 = 1;
- TR1 = 1;
- EA = 1;
- void timer0_() interrupt 1
- TH0 = 0xff;
- TL0 = 0xff;
- f++;
- void timer1_() interrupt 3
- timer++;
- if(!(timer%20)) flat=!flat;
- void time_proc()
- u8 i;
- for(i=0;i<3;i++)
- time[i]=Read_Ds1302_Byte(read_time[i]);
- seg[0] = num[time[2]/16];
- seg[1] = num[time[2]%16];
- seg[2] = seg[5] = 0xbf;
- seg[3] = num[time[1]/16];
- seg[4] = num[time[1]%16];
- seg[6] = num[time[0]/16];
- seg[7] = num[time[0]%16];
- void time_deal()
- u8 i;
- for(i=0;i<3;i++)
- if(flat)
- n%=3;
- seg[7-n*3]=0xff;
- seg[7-n*3-1]=0xff;
- if(add)
- add=0;
- n%=3;
- time[n]++;
- if((time[n]&0x0f)>9) time[n]+=6;
- if((time[n]>0x59)&&(n<2)) time[n]=0x00;
- else if((time[n]>0x23)&&(n==2)) time[n]=0x00;
- for(i=0;i<3;i++)
- if(del)
- del=0;
- n%=3;
- if(((time[n]&0x0f)==0)&&(time[n]!=0)) time[n]= time[n]-0x10+0x09;
- else if((time[n]==0)&&(n<2)) time[n]=0x59;
- else if((time[n]==0)&&(n==2)) time[n]=0x23;
- else time[n]--;
- for(i=0;i<3;i++)
- void vol_proc()
- vol=read_date(0x90,0x03);
- vol=vol/5.1;
- seg[0]=seg[2]=0xbf;
- seg[1]=num[1];
- seg[3]=0xff;
- seg[4]=num[vol%100/10];
- seg[5]=num[vol%10];
- seg[6]=num[0];
- seg[7]=num[0];
- void vol_deal()
- vh=at24c02read(0x09);
- vl=at24c02read(0x0b);
- seg[0]=num[vh/10];
- seg[1]=num[vh%10];
- seg[2]=num[0];
- seg[3]=num[0];
- seg[4]=num[vl/10];
- seg[5]=num[vl%10];
- seg[6]=num[0];
- seg[7]=num[0];
- if(flat)
- n%=2;
- seg[n*4]=0xff;
- seg[n*4+1]=0xff;
- seg[n*4+2]=0xff;
- seg[n*4+3]=0xff;
- if(add)
- add=0;
- if(!n)
- vh+=5;
- else
- vl+=5;
- if(vh>=50) vh=50;
- if(vl>=50) vl=50;
- if(del)
- del=0;
- if(!n)
- vh-=5;
- else
- vl-=5;
- if(vh==0) vh=0;
- if(vl==0) vl=0;
- write_date(0x09,vh);
- write_date(0x0b,vl);
- void fre_proc()
- TR0=1;
- TR1=1;
- if(timer>=20)
- timer%=20;
- fre=f;
- f=0;
- if(fre>=20000) fre=20000;
- if(fre<=500) fre=500;
- seg[1]=num[2];
- seg[3]=num[fre/10000];
- seg[4]=num[fre%10000/1000];
- seg[5]=num[fre%1000/100];
- seg[6]=num[fre%100/10];
- seg[7]=num[fre%10];
- void cyl_proc()
- float cy;
- TR0=1;TR1=1;
- if(timer>20)
- timer%=20;
- fre = f;
- f=0;
- cy=1.0/fre;
- cyl=cy*1000*1000;
- seg[1]=num[2];
- seg[3]=num[cyl/10000];
- seg[4]=num[cyl%10000/1000];
- seg[5]=num[cyl%1000/100];
- seg[6]=num[cyl%100/10];
- seg[7]=num[cyl%10];
- void timer_proc()
- u8 timed[3];
- time[0]=at24c02read(0x03);
- time[1]=at24c02read(0x05);
- time[2]=at24c02read(0x07);
- seg[0]=num[timed[2]/16];
- seg[1]=num[timed[2]%16];
- seg[2]=seg[5]=0xbf;
- seg[3]=num[timed[1]/16];
- seg[4]=num[timed[1]%16];
- seg[6]=num[timed[0]/16];
- seg[7]=num[timed[0]%16];
- void lei_proc()
- u8 lei;
- lei = at24c02read(0x01);
- seg[0]=seg[1]=seg[2]=seg[3]=seg[4]=seg[5]=0xff;
- seg[6]=num[0];
- seg[7]=num[lei];
- void key_proc()
- u8 key;
- P3=0x0f;
- COL1=0;COL2=1;
- COL3=1;COL4=1;
- key = P3&0x0f;
- if(key!=0x0f)
- key |= 0x70;
- else
- COL1=1;COL2=0;
- key = P3&0x0f;
- if(key!=0x0f)
- key |= 0xb0;
- else
- COL2=1;COL3=0;
- key = P3&0x0f;
- if(key!=0x0f)
- key |= 0xd0;
- else
- COL3=1;COL4=0;
- key = P3&0x0f;
- if(key!=0x0f)
- key |= 0xe0;
- else
- COL4=1;
- switch(key)
- case 0x77:key_val=4;break;
- case 0x7b:key_val=5;break;
- case 0x7d:key_val=6;break;
- case 0x7e:key_val=7;break;
- case 0xbb:key_val=9;break;
- case 0xbd:key_val=10;break;
- case 0xbe:key_val=11;break;
- default:key_val=0;
- void seg_proc()
- select(6,0x01);select(7,seg[0]);delay(1000);
- select(6,0x02);select(7,seg[1]);delay(1000);
- select(6,0x04);select(7,seg[2]);delay(1000);
- select(6,0x08);select(7,seg[3]);delay(1000);
- select(6,0x10);select(7,seg[4]);delay(1000);
- select(6,0x20);select(7,seg[5]);delay(1000);
- select(6,0x40);select(7,seg[6]);delay(1000);
- select(6,0x80);select(7,seg[7]);delay(1000);
- close();
- void mom_proc()
- if((vol>vh)||(vol<vl))
- if(vol>vh)
- {write_date(0x01,1);delay(5000);}
- else if(vol<vl)
- {write_date(0x01,0);delay(5000);}
- write_date(0x03,time[0]);delay(5000);
- write_date(0x05,time[1]);delay(5000);
- write_date(0x07,time[2]);delay(5000);
- key_proc();
- if(key_val==11)
- add=1;
- while(key_val==11)
- key_proc();
- seg_proc();
- if(key_val==10)
- del=1;
- while(key_val==10)
- key_proc();
- seg_proc();
- if(key_val==9)
- mom=3;
- m=0;
- while(key_val==9)
- key_proc();
- seg_proc();
- if(key_val==7)
- mom=0;
- non=0;
- n=2;
- while(key_val==7)
- key_proc();
- seg_proc();
- if(key_val==6)
- mom=1;
- non=0;
- n=1;
- while(key_val==6)
- key_proc();
- seg_proc();
- if(key_val==5)
- mom=2;
- m=0;
- while(key_val==5)
- key_proc();
- seg_proc();
- if(key_val==4)
- m=!m;
- non=1;
- n++;
- while(key_val==4)
- key_proc();
- seg_proc();
- void main()
- timer_init();
- ds1302_init();
- close();
- while(1)
- mom_proc();
- if((!mom)&&(non))
- time_deal();
- seg_proc();
- else if((!mom)&&(!non))
- time_proc();
- seg_proc();
- else if((mom==1)&&(non))
- vol_deal();
- seg_proc();
- else if((mom==1)&&(!non))
- vol_proc();
- seg_proc();
- else if((mom==2)&&(m))
- cyl_proc();
- seg_proc();
- else if((mom==2)&&(!m))
- fre_proc();
- seg_proc();
- else if((mom==3)&&(m))
- timer_proc();
- seg_proc();
- else if((mom==3)&&(!m))
- lei_proc();
- seg_proc();
- #include "iic.h"
- #include "reg52.h"
- #include "intrins.h"
- #define DELAY_TIME 5
- #define SlaveAddrW 0xA0
- #define SlaveAddrR 0xA1
- sbit SDA = P2^1;
- sbit SCL = P2^0;
- void IIC_Delay(unsigned char i)
- do{_nop_();}
- while(i--);
- void IIC_Start(void)
- SDA = 1;
- SCL = 1;
- IIC_Delay(DELAY_TIME);
- SDA = 0;
- SCL = 0;
- void IIC_Stop(void)
- SDA = 0;
- SCL = 1;
- SDA = 1;
- void IIC_SendAck(bit ackbit)
- SCL = 0;
- SDA = ackbit;
- SCL = 1;
- SCL = 0;
- SDA = 1;
- bit IIC_WaitAck(void)
- bit ackbit;
- SCL = 1;
- ackbit = SDA;
- SCL = 0;
- return ackbit;
- void IIC_SendByte(unsigned char byt)
- unsigned char i;
- for(i=0; i<8; i++)
- SCL = 0;
- if(byt & 0x80) SDA = 1;
- else SDA = 0;
- SCL = 1;
- byt <<= 1;
- SCL = 0;
- unsigned char IIC_RecByte(void)
- unsigned char i, da;
- SCL = 1;
- da <<= 1;
- if(SDA) da |= 1;
- SCL = 0;
- return da;
- void write_date(unsigned char deet,unsigned char date)
- IIC_Start();
- IIC_SendByte(0xa0);
- IIC_WaitAck();
- IIC_SendByte(deet);
- IIC_WaitAck();
- IIC_SendByte(date);
- IIC_SendAck(1);
- IIC_Stop();
- unsigned char read_date(unsigned char deat,unsigned char deet)
- unsigned char date;
- IIC_Start();
- IIC_SendByte(deat);
- IIC_WaitAck();
- IIC_WaitAck();
- IIC_Stop();
- IIC_Start();
- IIC_SendByte(deat+1);
- IIC_WaitAck();
- date = IIC_RecByte();
- // IIC_SendAck(1);
- IIC_Stop();
- return date;
- unsigned char at24c02read(unsigned char deet)
- unsigned char dat;
- IIC_Start();
- IIC_WaitAck();
- IIC_WaitAck();
- IIC_Start();
- IIC_SendByte(0xa1);
- IIC_WaitAck();
- dat=IIC_RecByte();
- // IIC_SendAck(0);
- IIC_Stop();
- return dat;
- #include <reg52.h>
- #include <intrins.h>
- sbit SCK=P1^7;
- sbit SDA=P2^3;
- sbit RST = P1^3;
- void Write_Ds1302(unsigned char temp)
- unsigned char i;
- for (i=0;i<8;i++)
- SCK=0;
- SDA=temp&0x01;
- temp>>=1;
- SCK=1;
- void Write_Ds1302_Byte( unsigned char address,unsigned char dat )
- RST=0; _nop_();
- SCK=0; _nop_();
- RST=1; _nop_();
- Write_Ds1302(address);
- Write_Ds1302(dat);
- RST=0;
- unsigned char Read_Ds1302_Byte ( unsigned char address )
- unsigned char i,temp=0x00;
- RST=0; _nop_();
- SCK=0; _nop_();
- RST=1; _nop_();
- for (i=0;i<8;i++)
- SCK=0;
- temp>>=1;
- if(SDA)
- temp|=0x80;
- SCK=1;
- RST=0; _nop_();
- SCK=0; _nop_();
- SCK=1; _nop_();
- SDA=0; _nop_();
- SDA=1; _nop_();
- return (temp);
