查看: 5068|回復(fù): 7
51單片機(jī)四路DS18B20溫度檢測(cè)系統(tǒng)代碼與Proteus仿真圖
基于51單片機(jī)四路溫度檢測(cè)系統(tǒng)DS18B20的仿真和源程序
單片機(jī)源程序如下:
  1. #include"stc89c51.h"
  2. #include"define.h"
  3. sbit SetKey = P3^0;
  4. sbit UpKey  = P3^1;
  5. sbit DnKey  = P3^2;
  6. sbit AlarmK = P3^3;
  7. sbit BEEP   = P2^4;
  8. sbit LED1   = P2^0;
  9. sbit LED2   = P2^1;
  10. sbit LED3   = P2^2;
  11. sbit LED4   = P2^3;
  12. extern void StartDs18b20(uchar * ROMCODE);
  13. extern void ReadDs18b20(uchar * ROMCODE);
  14. extern  uchar  TZ;                           //轉(zhuǎn)換后的溫度值整數(shù)部分
  15. extern  uchar  TD;                           //轉(zhuǎn)換后的溫度值整數(shù)部分
  16. //extern void init_lcd (void);
  17. //extern void LcdWrData(uchar content);
  18. //extern  void LcdWrCommand(uchar content)        ;
  19. extern uchar FindDevices(uchar CodeROM[][8]);
  20. data uchar Ds18b20Rom[4][8];
  21. //************************************************************************************************************************
  22. extern uchar   LastDiscrap        ;
  23. //extern void writeChar(uchar x,uchar y,uchar s); //LCD 寫字符串
  24. //extern  void writestring(uchar x,uchar y,uchar *s) ;//LCD 寫字符串
  25. //extern void LCD_Initial(void);
  26. //extern void write_dat(unsigned char dat);
  27. //extern void command(unsigned int com);
  28. extern  unsigned char tflag;
  29. unsigned char AlarmTempLow=1,AlarmTempTop=125,Set=0;
  30. unsigned char fAlarm=0xff;
  31. unsigned char TP1=0xff,TP2=0xff,TP3=0xff,TP4=0xff;
  32. unsigned char Alarm1=0,Alarm2=0,Alarm3=0,Alarm4=0;
  33. unsigned char tf1=0,tf2=0,tf3=0,tf4=0;
  34. void delayms(uint ms)                 //延時(shí)xx毫秒
  35. {
  36.         uchar i;
  37.         while(ms--)
  38.         {
  39.                  for(i=0;i<120;i++);
  40.         }
  41. }
  42. sbit RS=P2^5;
  43. sbit RW=P2^6;
  44. sbit EN=P2^7;
  45. #define LCD_BUS P0
  46. void command(unsigned int com)         //LCD寫指令
  47. {
  48.    RS=0;                                  //RS為0
  49.    LCD_BUS=com;          //裝載指令
  50.    delayms(5);                 //延時(shí)5ms
  51.    EN=1;                                 //LCD使能
  52.    delayms(5);                //延時(shí)5ms
  53.    EN=0;                                //LCD不使能
  54. }
  55. void write_dat(unsigned char dat)          //LCD寫數(shù)據(jù)
  56. {
  57.    RS=1;                                        //RS為1
  58.    LCD_BUS=dat;                //裝載數(shù)據(jù)
  59.    delayms(5);                         //延時(shí)5ms
  60.    EN=1;                                         //LCD使能
  61.    delayms(5);                         //延時(shí)5ms
  62.    EN=0;                                         //LCD不使能
  63. }
  64. void writestring(unsigned char x,unsigned char y,unsigned char *s) //LCD 寫字符串
  65. {
  66.         if (y == 0)  command(0x80 + x);     //表示第一行
  67.         else         command(0xC0 + x);      //表示第二行
  68.
  69.         while (*s)                         //判斷是否字符串的結(jié)尾
  70.         {
  71.      write_dat( *s);    //顯示當(dāng)前字符
  72.                 s ++;                             //字符串地址加1
  73.         }
  74. }
  75. void writeChar(unsigned char x,unsigned char y,unsigned char s) //LCD 寫字符串
  76. {
  77.         if (y == 0)  command(0x80 + x);     //表示第一行
  78.         else         command(0xC0 + x);      //表示第二行
  79.
  80.         {
  81.      write_dat( s);    //顯示當(dāng)前字符
  82.         }
  83. }
  84. void LCD_Initial(void)                //LCD初始化
  85. {
  86.    EN=0;                                  //LCD不使能
  87.    RW=0;                                  //RW為0
  88.    command(0x38);                //發(fā)送初始化指令
  89.    command(0x0c);                //發(fā)送初始化指令
  90.    command(0x06);          //發(fā)送初始化指令
  91.    command(0x01);          //發(fā)送初始化指令
  92.    command(0x80+0x02);        //發(fā)送LCD初始位置
  93. }
  94. void Alarm(void)
  95. {
  96.         if(TP1!=0xff)
  97.         {
  98.                 if((TP1>(AlarmTempTop))||(TP1<(AlarmTempLow))||(tf1==0x2d))        {Alarm1=1;LED1=0;}
  99.                 else  {Alarm1=0;LED1=1;}
  100.         }
  101.    else  {Alarm1=0;LED1=1;}
  102.
  103.         if(TP2!=0xff)
  104.         {
  105.                 if((TP2>(AlarmTempTop))||(TP2<(AlarmTempLow))||(tf2==0x2d))        {Alarm2=1;LED2=0;}
  106.                 else  {Alarm2=0;LED2=1;}
  107.         }
  108.    else  {Alarm2=0;LED2=1;}
  109.
  110.         if(TP3!=0xff)
  111.         {
  112.                 if((TP3>(AlarmTempTop))||(TP3<(AlarmTempLow))||(tf3==0x2d))        {Alarm3=1;LED3=0;}
  113.                 else  {Alarm3=0;LED3=1;}
  114.         }
  115.    else  {Alarm3=0;LED3=1;}
  116.
  117.         if(TP4!=0xff)
  118.         {
  119.                 if((TP4>(AlarmTempTop))||(TP4<(AlarmTempLow))||(tf4==0x2d))        {Alarm4=1;LED4=0;}
  120.                 else  {Alarm4=0;LED4=1;}
  121.         }
  122.         else  {Alarm4=0;LED4=1;}
  123.
  124.         if(fAlarm!=0)
  125.         {
  126.                 if((Alarm1==1)||(Alarm2==1)||(Alarm3==1)||(Alarm4==1)) {BEEP=0;}
  127.                 else BEEP=1;
  128.         }
  129.         else BEEP=1;
  130. }
  131. void DispAlData(void)
  132. {
  133.         unsigned char i1=0,i2=0,i3=0,i4=0,i5=0,i6=0;
  134.
  135.         i1 = AlarmTempLow/100;          //獲得溫度值的百位
  136.         i2 = AlarmTempLow%100/10;         //獲得溫度值的十位
  137.         i3 = AlarmTempLow%10;                 //獲得溫度值的個(gè)位
  138.
  139.         i4 = AlarmTempTop/100;          //獲得溫度值的百位
  140.         i5 = AlarmTempTop%100/10;         //獲得溫度值的十位
  141.         i6 = AlarmTempTop%10;                 //獲得溫度值的個(gè)位
  142.         writestring(5,1,"   ");
  143.         writestring(13,1,"     ");
  144.         if(i1!=0)        writeChar(5,1,i1+'0');
  145.         if((i1==0)&&(i2!=0)) writeChar(5,1,i2+'0');
  146.         if(i1!=0) writeChar(6,1,i2+'0');
  147.         if((i1==0)&&(i2==0))        writeChar(5,1,i3+'0');
  148.         else if((i1==0)&&(i2!=0))        writeChar(6,1,i3+'0');
  149.         if((i1!=0))         writeChar(7,1,i3+'0');
  150.
  151.         if(i4!=0)        writeChar(13,1,i4+'0');
  152.         if((i4==0)&&(i5!=0)) writeChar(13,1,i5+'0');
  153.         if(i4!=0) writeChar(14,1,i5+'0');
  154.         if((i4==0)&&(i5==0))        writeChar(13,1,i6+'0');
  155.         else if((i4==0)&&(i5!=0))        writeChar(14,1,i6+'0');
  156.         if((i4!=0)) writeChar(15,1,i6+'0');
  157. }
  158. void SetFun(void)
  159. {
  160.         if(SetKey==0)
  161.         {
  162.                 delayms(20);
  163.                 if(SetKey==0)
  164.                 {
  165.                         if(Set<2)        {Set++;writestring(0,1," Low=    Top=   ");}
  166.                         else {Set=0;}
  167.                 }
  168.                 DispAlData();
  169.                 switch(Set)
  170.                 {
  171.                         case 0:  writestring(0,1,"C        D      ");break;
  172.                         case 1:        writestring(0,1,">");writestring(8,1," ");break;
  173.                         case 2:        writestring(0,1," ");writestring(8,1,">");break;
  174.                 }
  175.
  176.
  177.                 while(SetKey==0);
  178.         }
  179.
  180.         if((UpKey==0)&&(Set!=0))
  181.         {
  182.                 delayms(20);
  183.                 if(UpKey==0)
  184.                 {
  185.                         switch(Set)
  186.                         {
  187.                                 case 1:        if(AlarmTempLow<125) AlarmTempLow++;else AlarmTempLow=125; break;
  188.                                 case 2:        if(AlarmTempTop<125) AlarmTempTop++;else AlarmTempTop=125; break;
  189.                         }
  190.                         DispAlData();
  191.                         while(UpKey==0);
  192.                 }
  193.         }
  194.
  195.         if((DnKey==0)&&(Set!=0))
  196.         {
  197.                 delayms(20);
  198.                 if(DnKey==0)
  199.                 {
  200.                         switch(Set)
  201.                         {
  202.                                 case 1:        if(AlarmTempLow>-20) AlarmTempLow--;else AlarmTempLow=-20; break;
  203.                                 case 2:        if(AlarmTempTop>0) AlarmTempTop--;else AlarmTempTop=0; break;
  204.                         }
  205.                         DispAlData();
  206.                         while(DnKey==0);
  207.                 }
  208.         }
  209.
  210.         if(AlarmK==0)
  211.         {
  212.                 delayms(20);
  213.                 if(AlarmK==0)
  214.                 {
  215.                         fAlarm=~fAlarm;
  216.                         while(AlarmK==0)        ;
  217.                 }
  218.         }
  219. }
  220. void main(void)
  221. {
  222.         uint k;
  223.         uchar number;
  224.    BEEP=1;
  225.    LCD_Initial();
  226.         //init_lcd();
  227.    writestring(0,0,"  Search Sensor  ");
  228.    delayms(800);
  229.    number=FindDevices(Ds18b20Rom);
  230.    writestring(0,0,"Search    sensors");
  231.         writeChar(7,0,number/10+'0');
  232.    writeChar(8,0,number%10+'0');
  233.
  234.    for(k=0;k<number;k++)
  235.    {
  236.       StartDs18b20(& Ds18b20Rom[k][0]);
  237.    }
  238.    delayms(800);
  239.    writestring(0,0,"A        B      ");
  240.    writestring(0,1,"C        D      ");
  241.         while(1)
  242.         {
  243.       if(Set==0)
  244.       {
  245.          for(k=0;k<number;k++)
  246.          {
  247.             StartDs18b20(& Ds18b20Rom[k][0]);
  248.
  249.             ReadDs18b20(& Ds18b20Rom[k][0]);
  250.             switch(k)
  251.             {
  252.                case 0:
  253.                   TP1=TZ;tf1=tflag;
  254.                   writeChar(1,0,tflag);
  255.                   writeChar(2,0,TZ/100+'0');
  256.                   writeChar(3,0,TZ/10%10+'0');
  257.                   writeChar(4,0,TZ%10+'0');
  258.                   writeChar(5,0,'.');
  259.                   writeChar(6,0,TD+'0');
  260.                   break;
  261.                case 1:
  262.                   TP2=TZ;tf2=tflag;
  263.                   writeChar(10,0,tflag);
  264.                   writeChar(11,0,TZ/100+'0');
  265.                   writeChar(12,0,TZ/10%10+'0');
  266.                   writeChar(13,0,TZ%10+'0');
  267.                   writeChar(14,0,'.');
  268.                   writeChar(15,0,TD+'0');
  269.                   break;
  270.                case 2:
  271.                   TP3=TZ;tf3=tflag;
  272.                   writeChar(1,1,tflag);
  273.                   writeChar(2,1,TZ/100+'0');
  274.                   writeChar(3,1,TZ/10%10+'0');
  275.                   writeChar(4,1,TZ%10+'0');
  276.                   writeChar(5,1,'.');
  277.                   writeChar(6,1,TD+'0');
  278.                   break;
  279.                case 3:
  280.                   TP4=TZ;tf4=tflag;
  281.                   writeChar(10,1,tflag);
  282.                   writeChar(11,1,TZ/100+'0');
  283.                   writeChar(12,1,TZ/10%10+'0');
  284.                   writeChar(13,1,TZ%10+'0');
  285.                   writeChar(14,1,'.');
  286.                   writeChar(15,1,TD+'0');
  287.                   break;
  288.             }
  289.          }
  290.       }
  291.       SetFun();
  292.                 Alarm();
  293.         }
  294. }
所有程序仿真51hei提供下載:
仿真.zip (242.92 KB, 下載次數(shù): 171)
評(píng)分
參與人數(shù) 1黑幣 +15 收起 理由
zy0818 + 15
查看全部評(píng)分
收藏收藏9 分享淘帖 頂1 踩
ID:1015521 發(fā)表于 2022-5-29 20:04 | 只看該作者
感謝樓主的講解
ID:228452 發(fā)表于 2022-5-30 03:03 | 只看該作者
Had similiar project 4xDS18B20 and Modbus...
Nice work..
無效樓層,該帖已經(jīng)被刪除
5#
ID:1088947 發(fā)表于 2023-7-21 19:46 | 只看該作者
需要用Proteus7.8版本打開dsn文件  不然工程內(nèi)是空的沒有仿真圖
ID:1088947 發(fā)表于 2023-7-22 18:20 | 只看該作者
想要這樣的效果,該怎么做?大佬求教。
ID:1088947 發(fā)表于 2023-7-22 21:12 | 只看該作者
我改了顯示元件后,只能顯示一個(gè),不知道是為什么。proteus仿真圖是我照著圖片弄得。可能有毛病
ID:1088947 發(fā)表于 2023-7-23 09:12 | 只看該作者
搞好了,是自己放的ds18b20沒給序列號(hào)導(dǎo)致的只能識(shí)別一個(gè)
ID:1083556 發(fā)表于 2023-7-23 12:10 | 只看該作者
非常感謝,很需要這方面的資料,,,,
無效樓層,該帖已經(jīng)被刪除
