查看: 2412|回復(fù): 1
51單片機nrf24l01藍牙制作避障智能車程序
ID:828888 發(fā)表于 2021-3-16 10:05 | 顯示全部樓層 |閱讀模式
51單片機制作智能車,通過手機app藍牙對nrf2401控制,實現(xiàn)小車運動
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. unsigned int Chao_time=0;
  5. uint S1;
  6. uint S2;
  7. uint S3;
  8. sbit Trig1=P2^0;
  9. sbit Echo1=P2^1;
  10. sbit Trig2=P2^2;
  11. sbit Echo2=P2^3;
  12. sbit Trig3=P2^4;
  13. sbit Echo3=P2^5;
  14. sbit ENA=P1^2;
  15. sbit ENB=P1^3;
  16. sbit dian1=P0^0;                 //左輪前
  17. sbit dian2=P0^1;                 //左輪后
  18. sbit dian3=P0^2;                 //右輪前
  19. sbit dian4=P0^3;                 //右輪后
  20. void delay(uint z)
  21. {
  22.         uint x,y;
  23.         for(x=55;x>0;x--)
  24.                 for(y=z;y>0;y--);
  25. }
  26. void dianjigo()                          //小車前進
  27. {
  28.         dian1=1;
  29.         dian2=0;
  30.         dian3=1;
  31.         dian4=0;
  32. }
  33. void dianjiback()                        //小車后退
  34. {
  35.         dian1=0;
  36.         dian2=1;
  37.         dian3=0;
  38.         dian4=1;
  39. }
  40. void dianjistop()                         //小車停
  41. {
  42.         dian1=0;
  43.         dian2=0;
  44.         dian3=0;
  45.         dian4=0;
  46. }
  47. void dianjileft()                //小車左
  48. {
  49.
  50.         dian1=1;
  51.         dian2=0;
  52.         dian3=0;
  53.         dian4=1;
  54. }
  55.
  56. void dianjiright()                 //小車右
  57. {
  58.         dian1=0;
  59.         dian2=1;
  60.         dian3=1;
  61.         dian4=0;
  62. }
  63. void delay_20us()
  64. {
  65.         uchar bt;
  66.         for(bt=0;bt<100;bt++);
  67. }
  68. void Conut1()
  69. {
  70.
  71.         while(!Echo1);
  72.         TR1=1;
  73.         while(Echo1);
  74.         TR1=0;
  75.         Chao_time=TH1*256+TL1;
  76.         TH1=0;
  77.         TL1=0;
  78.         S1=(Chao_time*1.7)/100;                                //測距離
  79. }
  80. void chaoshengbo1()
  81. {
  82.         Trig1=1;
  83.         delay_20us();
  84.         Trig1=0;
  85.         Conut1();
  86. }
  87. void Conut2()
  88. {
  89.
  90.         while(!Echo2);
  91.         TR1=1;
  92.         while(Echo2);
  93.         TR1=0;
  94.         Chao_time=TH1*256+TL1;
  95.         TH1=0;
  96.         TL1=0;
  97.         S2=(Chao_time*1.7)/100;                                //測距離
  98. }
  99. void chaoshengbo2()
  100. {
  101.         Trig2=1;
  102.         delay_20us();
  103.         Trig2=0;
  104.         Conut2();
  105. }
  106. void Conut3()
  107. {
  108.
  109.         while(!Echo3);
  110.         TR1=1;
  111.         while(Echo3);
  112.         TR1=0;
  113.         Chao_time=TH1*256+TL1;
  114.         TH1=0;
  115.         TL1=0;
  116.         S3=(Chao_time*1.7)/100;                                //測距離
  117. }
  118. void chaoshengbo3()
  119. {
  120.         Trig3=1;
  121.         delay_20us();
  122.         Trig3=0;
  123.         Conut3();
  124. }
  125. void main()
  126. {
  127.         TMOD=0x11;
  128.         TR0=0;
  129.         TR1=0;
  130.         ENA=1;
  131.         ENB=1;
  132.         dianjigo();
  133.         while(1)
  134.         {
  135.                 chaoshengbo1();
  136.                 delay(1);
  137.                   chaoshengbo2();
  138.                 delay(1);
  139.                 chaoshengbo3();
  140.                 delay(1);
  141.                 if(S2>20)
  142.                 {
  143.                         if(S1>20)
  144.                         {
  145.                                 if(S3>20)
  146.                                         dianjigo();
  147.                                 else
  148.                                         dianjiright();
  149.                         }
  150.                         else
  151.                                 dianjileft();
  152.                 }
  153.                 else if(S2>15&&S2<20)
  154.                 {
  155.
  156.                         if(S1>20)
  157.                         {
  158.                                 if(S3>20)
  159.                                         dianjigo();
  160.                                 else
  161.                                         dianjiright();
  162.                         }
  163.                         else
  164.                                 dianjileft();
  165.                 }
  166.                 else if(S2<15)
  167.                         dianjiback();
  168. //                if(S2<15)
  169. //                        dianjiback();
  170. //                if(S2>15)
  171. //                        dianjigo();
  172. //                if(S2>15&&S2<30&&S1<S3)
  173. //                        dianjiright();
  174. //                if(S2>15&&S2<30&&S1>S3)
  175. //                        dianjileft();
  176. //                        delay(1);
  177.         }
  178.
  179. }
以上代碼51hei提供下載:
物聯(lián)網(wǎng)智能車程序.zip (84.09 KB, 下載次數(shù): 21)
ID:894065 發(fā)表于 2021-4-11 19:29 | 顯示全部樓層
你這是超聲波小車哦
