查看: 1905|回復: 0
密碼鎖代碼
ID:717332 發表于 2021-3-15 22:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include"reg52.h"
char scan_key(void);
void delay(unsigned int i);
sbit P30=P3^0;
        unsigned char led[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
        unsigned char led1[]={0xbf,0x8c,0x86};
        unsigned char i;
        P1=led1[0];
        P30=1;
        P0=0xff;
                i=scan_key();
                if(i==-1)continue;
                else if(i!=8)
                        P1=led[i];
                        delay(10000);
                        P1=led1[2];
                        delay(50000);
                        P1=led1[0];
                        P1=led[i];
                        delay(10000);
                        P1=led1[1];
                        P30=0;
                        delay(50000);
                        P1=led1[0];
                        P30=1;
char scan_key()
        char i,temp,m,n;
        bit find=0;
        P2=0xf0;
        i=P0;
        i &=0x0f;
        if(i!=0x0f)
                delay(1200);
                i=P0;
                i &=0x0f;
                if(i!=0x0f)
                        for(i=0;i<4;i++)
                                P2=0xfe<<i;
                                temp=~P0;
                                temp=temp & 0x0f;
                                if(temp!=0x00)
                                        m=i;
                                        find=1;
                                        switch(temp)
                                                 case 0x01:n=0;break;
                               case 0x02:n=1;break;
             case 0x04:n=2;break;
             case 0x08:n=3;break;
                                                default:break;
            break;
if(find==0)
        return -1;
        return(n*4+m);
unsigned int k;
for(k=0;k<i;k++);
