#include "reg52.h"
#include "1602.h"
#include "delay.h"
#include "18b20.h"
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
sbit host=P2^3;
sbit buzz=P2^7;
unsigned char page;
unsigned char fresh;
unsigned char tempsetflag;
unsigned char updownflag;
unsigned char ss;
unsigned char set=20;
unsigned char up=50;
unsigned char down=10;
unsigned char temp;
void Init_Timer0(void)
TMOD |= 0x01; //使用模式1,16位定時(shí)器,使用"|"符號可以在使用多個(gè)定時(shí)器時(shí)不受影響
EA=1; //總中斷打開
ET0=1; //定時(shí)器中斷打開
TR0=1; //定時(shí)器開關(guān)打開
LCD_Init();
Init_DS18B20();
ReadTemperature();
DelayMs(500);
ReadTemperature();
DelayMs(500);
ReadTemperature();
DelayMs(500);
Init_Timer0();
if(fresh)
fresh=0;
temp=ReadTemperature();
if(temp<set)host=0;
else host=1;
if(temp>=up)buzz=0;
else if(temp<down)buzz=0;
else buzz=1;
if(page==0)
LCD_Write_String(0,0,"TEMPTURE:");
LCD_Write_Tmp(9,0,temp);
LCD_Write_Data(0xdf);
LCD_Write_Data(0x43);
LCD_Write_String(0,1,"SET:");
LCD_Write_Tmp(5,1,set);
if(tempsetflag)
if(ss)LCD_Write_String(5,1," ");
ss=!ss;
else if(page==1)
LCD_Write_String(0,0,"UP:");
LCD_Write_Tmp(6,0,up);
LCD_Write_String(0,1,"DOWN:");
LCD_Write_Tmp(6,1,down);
if(ss)LCD_Write_String(6,0," ");
ss=!ss;
else if(page==2)
if(ss)LCD_Write_String(6,1," ");
ss=!ss;
void Timer0_isr(void) interrupt 1
static unsigned int num;
static unsigned char key1num;//按鍵一按下標(biāo)志
static unsigned char key2num;//按鍵二按下標(biāo)志
static unsigned char key3num;//按鍵三按下標(biāo)志
static unsigned char key4num;//按鍵四按下標(biāo)志
TH0=(65536-2000)/256; //重新賦值 2ms
TL0=(65536-2000)%256;
num++;
if(num==250) //大致100ms
num=0;
fresh=1;
if(key1==0)key1num=1;//設(shè)定設(shè)定溫度
else if(key1num==1)
key1num=0;
if(page==0)tempsetflag=!tempsetflag;//只有在界面一才可以調(diào)節(jié)
if(key2==0)key2num=1;//上下限設(shè)定
else if(key2num==1)
key2num=0;
if(!tempsetflag)//只有非設(shè)置設(shè)置溫度的時(shí)候才可以
page++;
LCD_Init();
if(page==3)page=0;
if(key3==0)key3num=1;//溫度加
else if(key3num==1)
key3num=0;
if((page==0)&&(tempsetflag))if(set<up)set++;//只有在設(shè)置設(shè)置溫度時(shí)才可以調(diào)節(jié)
if(page==1)if(up<99)up++;
if(page==2)if(down<up)down++;
if(key4==0)key4num=1;//溫度減
else if(key4num==1)
key4num=0;
if((page==0)&&(set>down))set--;
if(page==1)if(up>down)up--;
if(page==2)if(down>0)down--;
(61.27 KB, 下載次數(shù): 45)
2021-3-15 19:58 上傳
18B20溫度測試.zip
2021-3-15 19:59 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
129.51 KB, 下載次數(shù): 49, 下載積分: 黑幣 -5
