查看: 2317|回復: 0
51單片機+1602函數 Proteus仿真
  1. /*---------------------------------------------------------------------
  2.                          LCD1602.C文件 LCD1602的函數
  3. ----------------------------------------------------------------------*/
  4. #include "hardware.h"
  5. #include "lcd1602.h"
  6. void LCD_check_busy(void)   //檢測LCD狀態,看它是不是還在忙呢
  7. {
  8. while(1)
  9.   {
  10.    LCD_EN=0;
  11.    LCD_RS=0;
  12.    LCD_RW=1;
  13.    LCD_DATA=0xff;
  14.    LCD_EN=1;
  15.    if(!LCD_BUSY)break;
  16.   }
  17. LCD_EN=0;
  18. }
  19. void LCD_cls(void)          //LCD清屏
  20. {
  21. LCD_check_busy();
  22. LCD_RS=0;
  23. LCD_RW=0;
  24. LCD_DATA=1;
  25. LCD_EN=1;
  26. LCD_EN=0;
  27. }
  28. void LCD_write_instruction(unsigned char LCD_instruction)   //寫指令到LCD
  29. {
  30.   LCD_check_busy();
  31. LCD_RS=0;
  32. LCD_RW=0;
  33. LCD_DATA=LCD_instruction;
  34. LCD_EN=1;
  35. LCD_EN=0;
  36. }
  37. void LCD_write_data(unsigned char LCD_data)      //輸出一個字節數據到LCD
  38. {
  39.   LCD_check_busy();
  40. LCD_RS=1;
  41. LCD_RW=0;
  42. LCD_DATA=LCD_data;
  43. LCD_EN=1;
  44. LCD_EN=0;
  45. }
  46. void LCD_set_position(unsigned char x)            //LCD光標定位到x處
  47. {
  48. LCD_write_instruction(0x80+x);
  49. }
  50. /*
  51. void LCD_go_home(void)                         //LCD光標歸位
  52. {
  53. LCD_write_instruction(LCD_GO_HOME);
  54. }
  55. */
  56. void LCD_printc(unsigned char lcd_data)          //輸出一個字符到LCD
  57. {
  58. LCD_write_data(lcd_data);
  59. }
  60. void LCD_prints(unsigned char *lcd_string)       //輸出一個字符串到LCD
  61. {
  62. unsigned char i=0;
  63. while(lcd_string[i]!=0x00)
  64.   {
  65.    LCD_write_data(lcd_string[i]);
  66.    i++;
  67.   }
  68. }
  69. void LCD_initial(void)                        //初始化LCD
  70. {
  71. LCD_write_instruction(LCD_AC_AUTO_INCREMENT|LCD_MOVE_DISENABLE);
  72. LCD_write_instruction(LCD_DISPLAY_ON|LCD_CURSOR_OFF);
  73. LCD_write_instruction(LCD_DISPLAY_DOUBLE_LINE);
  74. LCD_cls();
  75. }
項目.zip (73.85 KB, 下載次數: 18)
