查看: 3277|回復: 3
活躍氣氛,發個html萬年歷代碼給大家
ID:886808 發表于 2021-3-13 19:44 來自觸屏版 | 顯示全部樓層 |閱讀模式
本萬年歷是我多年前保存的,不用上網,用瀏覽器打開就行。不用管其它部分。只按我照片中的地方,把公歷農歷相關的文字改成自己需要的。保存的后綴改成.htm即可。
文件如下:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>萬年歷</TITLE>
<META
content="農歷; 陽歷; 月歷; 節日; 時區; 節氣; 八字; 干支; 生肖; gregorian solar; chinese lunar; calendar;"
name=keywords>
<META content=All name=robots>
<META content="gregorian solar calendar and chinese lunar calendar"
name=description>
<META http-equiv=Content-Type content="text/html; charset=gb2312">
<SCRIPT language=JavaScript>
function click() {
if (event.button==2) {alert('歡迎訪問——農歷與公歷對照') ;
alert('您快樂,所以我快樂,別忘了告訴您的好友哦!')
document.onmousedown=click
</SCRIPT>
                                   日期資料
var lunarInfo=new Array(
0x04bd8,0x04ae0,0x0a570,0x054d5,0x0d260,0x0d950,0x16554,0x056a0,0x09ad0,0x055d2,
0x04ae0,0x0a5b6,0x0a4d0,0x0d250,0x1d255,0x0b540,0x0d6a0,0x0ada2,0x095b0,0x14977,
0x04970,0x0a4b0,0x0b4b5,0x06a50,0x06d40,0x1ab54,0x02b60,0x09570,0x052f2,0x04970,
0x06566,0x0d4a0,0x0ea50,0x06e95,0x05ad0,0x02b60,0x186e3,0x092e0,0x1c8d7,0x0c950,
0x0d4a0,0x1d8a6,0x0b550,0x056a0,0x1a5b4,0x025d0,0x092d0,0x0d2b2,0x0a950,0x0b557,
0x06ca0,0x0b550,0x15355,0x04da0,0x0a5d0,0x14573,0x052d0,0x0a9a8,0x0e950,0x06aa0,
0x0aea6,0x0ab50,0x04b60,0x0aae4,0x0a570,0x05260,0x0f263,0x0d950,0x05b57,0x056a0,
0x096d0,0x04dd5,0x04ad0,0x0a4d0,0x0d4d4,0x0d250,0x0d558,0x0b540,0x0b5a0,0x195a6,
0x095b0,0x049b0,0x0a974,0x0a4b0,0x0b27a,0x06a50,0x06d40,0x0af46,0x0ab60,0x09570,
0x04af5,0x04970,0x064b0,0x074a3,0x0ea50,0x06b58,0x055c0,0x0ab60,0x096d5,0x092e0,
0x0c960,0x0d954,0x0d4a0,0x0da50,0x07552,0x056a0,0x0abb7,0x025d0,0x092d0,0x0cab5,
0x0a950,0x0b4a0,0x0baa4,0x0ad50,0x055d9,0x04ba0,0x0a5b0,0x15176,0x052b0,0x0a930,
0x07954,0x06aa0,0x0ad50,0x05b52,0x04b60,0x0a6e6,0x0a4e0,0x0d260,0x0ea65,0x0d530,
0x05aa0,0x076a3,0x096d0,0x04bd7,0x04ad0,0x0a4d0,0x1d0b6,0x0d250,0x0d520,0x0dd45,
0x0b5a0,0x056d0,0x055b2,0x049b0,0x0a577,0x0a4b0,0x0aa50,0x1b255,0x06d20,0x0ada0)
var solarMonth=new Array(31,28,31,30,31,30,31,31,30,31,30,31);
var Gan=new Array("甲","乙","丙","丁","戊","己","庚","辛","壬","癸");
var Zhi=new Array("子","丑","寅","卯","辰","巳","午","未","申","酉","戌","亥");
var Animals=new Array("鼠","牛","虎","兔","龍","蛇","馬","羊","猴","雞","狗","豬");
var solarTerm = new Array("小寒","大寒","立春","雨水","驚蟄","春分","清明","谷雨","立夏","小滿","芒種","夏至","小暑","大暑","立秋","處暑","白露","秋分","寒露","霜降","立冬","小雪","大雪","冬至")
var sTermInfo = new Array(0,21208,42467,63836,85337,107014,128867,150921,173149,195551,218072,240693,263343,285989,308563,331033,353350,375494,397447,419210,440795,462224,483532,504758)
var nStr1 = new Array('日','一','二','叁','四','五','六','七','八','九','十')
var nStr2 = new Array('初','十','廿','卅',' ')
var monthName = new Array("JAN","FEB","MAR","APR","MAY","JUN","JUL","AUG","SEP","OCT","NOV","DEC");
//國歷節日 *表示放假日
var sFtv = new Array(
"0101*元旦節",
"0130 本人生日",
"0214 情人節",
"0305 學雷鋒紀念日",
"0308 婦女節",
"0312 植樹節",
"0315 消費者權益日",
"0401 愚人節",
"0407 世界衛生日",
"0422 世界地球日",
"0501*勞動節",
"0502*勞動節",
"0503*勞動節",
"0504 青年節",
aa.7z
8.7 KB, 下載次數: 11, 下載積分: 黑幣 -5
ID:886808 發表于 2021-3-14 07:14 來自觸屏版 | 顯示全部樓層
其實網頁文件就是純文本文件編的,只要把擴展各改成htm就可以獨立運行。本想娛樂大家,所以發個文本文件。只需點全部復制,粘貼到文件中,再改文件名就可以了。不想讓大家花黑幣下載,所以沒插壓縮文件。破費大家了,在此道歉!
ID:886808 發表于 2021-3-14 08:30 來自觸屏版 | 顯示全部樓層
我用手原文件在手機上可以單獨運行,現在的用WPS編輯后不,估計只能用電腦了。行
ID:79034 發表于 2021-3-18 09:20 | 顯示全部樓層
本帖最后由 邰夏留 于 2021-3-18 13:41 編輯
意思是如果自己重新復制到一個記事本,然后保存為HTML格式,拷到手機里,可以用手機用?
