2021-3-11 21:17 上傳
2021-3-11 21:17 上傳
單片機源程序如下:- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "timer.h"
- #include "HCSR04.h"
- #include "led.h"
- #include "beep.h"
- #include "key.h"
- #include "lcd1602.h"
- #include "stmflash.h" //包含頭文件
- unsigned long S=0; //定義超聲數據
- #define FLASH_SAVE_ADDR 0X0800FF00 //設置FLASH 保存地址(必須為偶數,且其值要大于本代碼所占用FLASH的大小+0X08000000)
- extern unsigned long Clock_time;
- unsigned char Send_flag=0;
- extern u8 TIM3CH1_CAPTURE_STA; //輸入捕獲狀態
- extern u16 TIM3CH1_CAPTURE_VAL; //輸入捕獲值
- u16 fls[4];
- u8 k=0;
- u32 TL=50;
- u8 beep1;
- u8 t=0;
- void key() //按鍵函數
- k=KEY_Scan(1); //按鍵掃描的值給K
- if(k == KEY0_PRES) //如果K等于 KEY0_PRES,就說明是按下加按鍵
- TL++; //數據加一,如果大于400,則減一,保持最大400
- if(TL>400)
- TL--;
- fls[0]=TL;
- STMFLASH_Write(FLASH_SAVE_ADDR,(u16*)fls,1); //存儲
- if(k == KEY1_PRES)//同上,不過是減
- TL--;
- if(TL<5)
- TL++;
- fls[0]=TL;
- void ceju()
- Trig=1;
- delay_us(20);
- Trig=0; //啟動信號
- S=0; //清零距離數據
- Clock_time=0;
- TIM_Cmd(TIM3, DISABLE); //關定時器,清零計時變量
- while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5)); //等待檢測到高電平
- Clock_time=0;
- TIM_Cmd(TIM3, ENABLE); //開定時器
- while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5)==1&&Clock_time<47058); //只要是高,一直算時間,如果時間計數超過 47058,所說有問題,直接跳過,47058不一定精確,是一個大概值,
- S=((Clock_time*2)*340/10000)/2; //時間變量是2us加一,乘以速度,因為時間是us,換成秒是除以1000000,保留兩位小數,所以除以 10000,然后除以二得到單方面距離
- Clock_time=0; //清零數據
- printf("Distance:%d cm\r\n",S);//打印總的高點平時間
- void show()
- LCD1602_Show_Str(0,0,"Distance:"); //顯示
- if(S>=100&&S<=400) LCD1602_Write_Dat(S/100%10+0x30); //這里是測速數據
- else LCD1602_Show_Str(9,0," ");
- if(S>=10) LCD1602_Write_Dat(S/10%10+0x30);
- else LCD1602_Show_Str(10,0," ");
- LCD1602_Write_Dat(S%10+0x30);
- LCD1602_Show_Str(12,0,"cm ");
- LCD1602_Show_Str(0,1,"alarm :"); //這里開始顯示報警數據,下面這三段,其實就是判斷閾值數據是百位數還是十位數還是個位數,如果是個位數,顯示個位數據,百位十位顯示空
- if(TL>=100&&TL<=400)
- LCD1602_Write_Dat(TL/100%10+0x30);
- LCD1602_Write_Dat(TL/10%10+0x30);
- LCD1602_Write_Dat(TL%10+0x30);
- LCD1602_Show_Str(12,1,"cm ");
- if(TL>=10&&TL<100)
- LCD1602_Show_Str(9,1," ");
- if(TL>0&&TL<10)
- LCD1602_Show_Str(10,1," ");
- void problem() //報警函數
- if(S<TL) //小于閾值,蜂鳴器開始響,對應指示燈亮,否則蜂鳴器不響
- beep1=1;
- LED1=1;
- else
- beep1=0;
- LED1=0;
- LED0=1;
- int main(void)
- u16 datatemp[1];
- BEEP_Init();
- KEY_Init();
- delay_init(); //延時函數初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
- uart_init(115200); //串口初始化為115200
- LED_Init(); //LED端口初始化
- UltrasonicWave_Configuration(); //初始化超聲IO
- TIM3_Cap_Init(1,72-1); //以1Mhz的頻率計數,第一個選項,最小只能是1
- LCD1602_Init();
- STMFLASH_Read(FLASH_SAVE_ADDR,(u16*)datatemp,1);
- TL=datatemp[0];
- if(TL<5||TL>400)
- TL=50;
- ceju();
- printf("Distance"); //串口打印一下,調試用
- while(1)
- if(beep1==1) //如果蜂鳴器標志等于1,則開始滴滴叫,指示燈也是閃爍
- BEEP=!BEEP;
- LED0=!LED0;
- else
- BEEP=0;
- show(); //調用顯示函數
- key(); //調用按鍵函數
- problem();//調用報警處理函數
- t++; //變量自加,加到5的時候,對5取余會等于0,則啟動一次測距函數
- if(t%5==0)
- t=0;
- ceju();
全部資料51hei下載地址:
STM32 超聲波測距完整資料.7z
(343.7 KB, 下載次數: 116)
2021-3-11 21:18 上傳
下載積分: 黑幣 -5
