查看: 3641|回復: 0
基于51單片機的頻率計 仿真+源程序+hex文件
基于51單片機的頻率計
  1. #include <reg51.h>
  2. //四位一體數碼管位選
  3. sbit Awei = P1^0;
  4. sbit Bwei = P1^1;
  5. sbit Cwei = P1^2;
  6. sbit Dwei = P1^3;
  7. void jisuan();
  8. void delay(int x);
  9. int change(int x);
  10. //字形編碼定義
  11. #define SHU_0 0X3F;
  12. #define SHU_1 0X06;
  13. #define SHU_2 0X5B;
  14. #define SHU_3 0X4F;
  15. #define SHU_4 0X66;
  16. #define SHU_5 0X6D;
  17. #define SHU_6 0X7D;
  18. #define SHU_7 0X07;
  19. #define SHU_8 0X7F;
  20. #define SHU_9 0X6F;
  21. int ge=0, shi=0, bai=0, qian=0;
  22. int count = 0, i = 0;
  23. int freq = 0;
  24. int main()
  25. {
  26.         ge = 0; shi = 0; bai = 0; qian = 0;
  27.         //設置計數器0工作方式1,定時器1工作方式1
  28.         TMOD        = 0X15;
  29.         //定時器初值設置
  30.         TH0 = 0;
  31.         TL0 = 0;
  32.         TH1 = (65535 - 50000)/256;
  33.         TL1 = (65535 - 50000)%256;
  34.         //外部中斷0使能
  35.         IT0 = 1;
  36.         EX0 = 1;
  37.         //中斷使能
  38.         EA = 1;
  39.         ET0 = 1;
  40.         ET1 = 1;
  41.         //定時器使能
  42.         TR0 = 1;
  43.         TR1 = 1;
  44.         while(1)
  45.         {
  46.         //動態顯示
  47.         jisuan();
  48.                 Awei = 1; Bwei = 1; Cwei = 1; Dwei = 0;
  49.                 P2 =  change(ge);
  50.                 delay(10);
  51.                 P2 = 0X00;
  52.                 Awei = 1; Bwei = 1; Cwei = 0; Dwei = 1;
  53.                 P2 =  change(shi);
  54.                 delay(10);
  55.                 P2 = 0X00;
  56.                 Awei = 1; Bwei = 0; Cwei = 1; Dwei = 1;
  57.                 P2 =  change(bai);
  58.                 delay(10);
  59.                 P2 = 0X00;
  60.                 Awei = 0; Bwei = 1; Cwei = 1; Dwei = 1;
  61.                 P2 =  change(qian);
  62.                 delay(10);
  63.                 P2 = 0X00;
  64.
  65.         }
  66. }
  67. void service_timer0() interrupt 1 using 1
  68. {
  69.     TH0 = 0;
  70.     TL0 = 0;
  71. }
  72. void service_timer1() interrupt 3 using 3
  73. {
  74.             TH1 = (65535 - 50000)/256;
  75.         TL1 = (65535 - 50000)%256;
  76.         i++;
  77.         if (i == 20)
  78.         {
  79.                 freq =TL0 + TH0*256;
  80.                 i = 0;
  81.                 TH0 = 0;
  82.                     TL0 = 0;
  83.         }
  84. }
  85. void jisuan()
  86. {
  87.         qian = freq /1000;
  88.         bai = (freq%1000)/100;
  89.         shi = (freq%100)/10;
  90.         ge = freq%10;
  91. }
  92. void delay(int x)
  93. {
  94.         int i, j;
  95.         for(i = 0; i < x; i++)
  96.                 for(j = 0; j < 100; j++);
  97. }
  98. int change(int x)
  99. {
  100.         int shu;
  101.         switch(x)
  102.         {
  103.                 case 0: shu = SHU_0; break;
  104.                 case 1: shu = SHU_1; break;
  105.                 case 2: shu = SHU_2; break;
  106.                 case 3: shu = SHU_3; break;
  107.                 case 4: shu = SHU_4; break;
  108.                 case 5: shu = SHU_5; break;
  109.                 case 6: shu = SHU_6; break;
  110.                 case 7: shu = SHU_7; break;
  111.                 case 8: shu = SHU_8; break;
  112.                 case 9: shu = SHU_9; break;
  113.         }
  114.         return shu;
  115. }
頻率計.zip (98.64 KB, 下載次數: 79)
