Altium Designer畫的額溫槍原理圖和PCB圖如下:(51hei附件中可下載工程文件)
2021-3-7 18:21 上傳
2021-3-7 18:22 上傳
2021-3-7 18:22 上傳
單片機(jī)源程序如下:
- /** \file main.c
- ** A detailed description is available at
- ** @link Sample Group Some description @endlink
- ** - 2017-05-28 LiuHL First Version
- * Include files
- #include "adc.h"
- #include "gpio.h"
- #include "bgr.h"
- #include "lcd.h"
- #include "lvd.h"
- #include "app_lcd.h"
- #include "app_gpio.h"
- #include "app_adc.h"
- #include "app.h"
- * Local pre-processor symbols/macros ('#define')
- #define USERKEYTRUE (0xFFFFFFFFu)
- #define USERKEYFALSE (0x00000000u)
- #define LCDCHAR__ (0xFFFFu)
- #define CHARGEEMPTY (0x00000000u)
- #define CHARGEFULL (0xFFFFFFFFu)
- * Global variable definitions (declared in header file with 'extern')
- volatile uint32_t gu32AdcRestult = 0;
- volatile uint32_t gu32UserKeyFlag[4] = {USERKEYFALSE, USERKEYFALSE, USERKEYFALSE, USERKEYFALSE};
- volatile stc_lcd_display_cfg_t gstcLcdDisplayCfg = {0};
- volatile uint32_t gVolFlag = CHARGEFULL;
- * Local type definitions ('typedef')
- typedef enum enMState
- InitialMode = 0u,
- TempMeasureMode = 1u,
- TempShowMode = 2u,
- PowerOffMode = 3u,
- MemoryMode = 4u,
- }enMState_t;
- * Local function prototypes ('static')
- * Local variable definitions ('static') *
- * Function implementation - global ('extern') and local ('static')
- ** \brief Main function of project
- ** \return uint32_t return value, if needed
- ** This sample
- int32_t main(void)
- volatile enMState_t enMState = InitialMode;
- uint32_t u32AdcResultTmp, u32NtcIndex;
- ///< GPIO 初始化
- AppMGpioInit();
- ///< ADC 模塊初始化
- AppMAdcInit();
- ///< LCD 模塊初始化
- AppLcdInit();
- ///< 電量監(jiān)測模塊初始化
- AppVolMonitorInit();
- // 初次上電開機(jī)LCD全屏顯示閃爍兩次
- AppLcdShowAll();
- delay1ms(400);
- AppLcdClearAll();
- delay1ms(400);
- AppLcdShowAll();
- delay1ms(400);
- AppLcdClearAll();
- delay1ms(400);
- AppLcdShowAll();
- while(1)
- switch(enMState)
- case InitialMode:
- // LCD 初始狀態(tài)顯示
- gstcLcdDisplayCfg.bM6En = FALSE;
- gstcLcdDisplayCfg.bM5En = TRUE;
- gstcLcdDisplayCfg.bM2En = FALSE;
- gstcLcdDisplayCfg.bM7En = TRUE;
- gstcLcdDisplayCfg.bM8En = TRUE;
- gstcLcdDisplayCfg.bM9En = FALSE;
- gstcLcdDisplayCfg.bM10En = FALSE;
- gstcLcdDisplayCfg.bM11En = TRUE;
- gstcLcdDisplayCfg.bM3En = FALSE;
- gstcLcdDisplayCfg.enTmpMode = Char__;
- gstcLcdDisplayCfg.u16Num = LCDCHAR__;
- if(USERKEYTRUE == gu32UserKeyFlag[2])
- //(進(jìn)入溫度測量)
- gu32UserKeyFlag[0] = USERKEYFALSE;
- gu32UserKeyFlag[1] = USERKEYFALSE;
- gu32UserKeyFlag[2] = USERKEYFALSE;
- gu32UserKeyFlag[3] = USERKEYFALSE;
- else if (USERKEYTRUE == gu32UserKeyFlag[2])
- enMState = TempMeasureMode;
- break;
- case TempMeasureMode:
- break;
- case TempShowMode:
- break;
- case PowerOffMode:
- break;
- case MemoryMode:
- break;
- default:
- break;
- ///< 溫度采集及數(shù)據(jù)處理
- if(USERKEYTRUE == gu32UserKeyFlag[3])
- AppAdcNtcAvgCodeGet(&u32AdcResultTmp);
- u32NtcIndex = App_TempNtcFind(u32AdcResultTmp);
- AppLcdStkLcdShow((u32NtcIndex + 10)*10);
- delay1ms(1000);
- AppAdcVirAvgCodeGet(&u32AdcResultTmp);
- AppLcdStkLcdShow(App_TempVirFind(u32NtcIndex, u32AdcResultTmp));
- delay1ms(3000);
- ///< LCD顯示更新
- //AppLcdDisplayUpdate((stc_lcd_display_cfg_t*)(&gstcLcdDisplayCfg));
- ///< LVD 中斷服務(wù)函數(shù)
- void Lvd_IRQHandler(void)
- Lvd_ClearIrq();
- // 電量顯示更新標(biāo)識
- gVolFlag = CHARGEEMPTY;
- ///< GPIO 中斷服務(wù)程序 ———— 測溫及選擇功能鍵
- void PortC_IRQHandler(void)
- delay1ms(20);
- if (TRUE == Gpio_GetIrqStatus(M_KEY_USER0_PORT, M_KEY_USER0_PIN))
- Gpio_ClearIrq(M_KEY_USER0_PORT, M_KEY_USER0_PIN);
- if(FALSE == Gpio_GetInputIO(M_KEY_USER0_PORT, M_KEY_USER0_PIN))
- //標(biāo)定按鍵按下
- return;
- if (TRUE == Gpio_GetIrqStatus(M_KEY_USER1_PORT, M_KEY_USER1_PIN))
- Gpio_ClearIrq(M_KEY_USER1_PORT, M_KEY_USER1_PIN);
- if(FALSE == Gpio_GetInputIO(M_KEY_USER1_PORT, M_KEY_USER1_PIN))
- //標(biāo)定按鍵按下
- return;
- if (TRUE == Gpio_GetIrqStatus(M_KEY_USER2_PORT, M_KEY_USER2_PIN))
- Gpio_ClearIrq(M_KEY_USER2_PORT, M_KEY_USER2_PIN);
- if(FALSE == Gpio_GetInputIO(M_KEY_USER2_PORT, M_KEY_USER2_PIN))
- //標(biāo)定按鍵按下
- return;
- ///< GPIO 中斷服務(wù)程序 ———— 模式功能鍵
- void PortD_IRQHandler(void)
- delay1ms(100);
- if (TRUE == Gpio_GetIrqStatus(M_KEY_USER3_PORT, M_KEY_USER3_PIN))
- Gpio_ClearIrq(M_KEY_USER3_PORT, M_KEY_USER3_PIN);
- if(FALSE == Gpio_GetInputIO(M_KEY_USER3_PORT, M_KEY_USER3_PIN))
- //標(biāo)定按鍵按下
- gu32UserKeyFlag[3] = USERKEYTRUE;
- return;
- * EOF (not truncated)
HC32L136額溫槍方案.zip
(7.54 MB, 下載次數(shù): 84)
2021-3-7 17:26 上傳
下載積分: 黑幣 -5
