運(yùn)用HAL庫(kù)驅(qū)動(dòng)的硬件SPI OLED程序,用起來(lái)爽歪歪,快得很
單片機(jī)源程序如下:
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "spi.h"
- #include "gpio.h"
- #include "oledspi.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "bmp.h"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- uint8_t t;
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_SPI1_Init();
- /* USER CODE BEGIN 2 */
- OLED_Init(); //初始化OLED
- OLED_Clear() ;
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- OLED_Clear();
- OLED_ShowCHinese(0,0,0);//晶
- OLED_ShowCHinese(18,0,1);//藍(lán)
- OLED_ShowCHinese(36,0,2);//電
- OLED_ShowCHinese(54,0,3);//子
- OLED_ShowCHinese(72,0,4);//科
- OLED_ShowCHinese(90,0,5);//技
- OLED_ShowString(0,2,"0.96 OLED TEST");
- OLED_ShowString(20,4,"2020/02/28");
- OLED_ShowString(0,6,"ASCII:");
- OLED_ShowString(63,6,"CODE:");
- OLED_ShowChar(48,6,t);//顯示ASCII字符
- t++;
- if(t>'~')t=' ';
- OLED_ShowNum(103,6,t,3,16);//顯示ASCII字符的碼值
- HAL_Delay(500);
- OLED_Clear();
- HAL_Delay(500);
- OLED_DrawBMP(0,0,128,8,(uint8_t*)BMP1); //圖片顯示(圖片顯示慎用,生成的字表較大,會(huì)占用較多空間,F(xiàn)LASH空間8K以下慎用)
- HAL_Delay(500);
- OLED_DrawBMP(0,0,128,8,(uint8_t*)BMP2);
- HAL_Delay(500);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /** Initializes the RCC Oscillators according to the specified parameters
- * in the RCC_OscInitTypeDef structure.
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
- RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- /** Initializes the CPU, AHB and APB buses clocks
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
- Error_Handler();
- /** Enables the Clock Security System
- HAL_RCC_EnableCSS();
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- __disable_irq();
- while (1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
所有程序51hei提供下載:
OLED_SPI.7z
(5.11 MB, 下載次數(shù): 87)
2021-2-28 16:40 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
