keil的安裝目錄中有例程,可以直接拿來(lái)用。并且keil的幫助文件有很詳細(xì)的說(shuō)明和更適合實(shí)際工程的。- /*------------------------------------------------------------------------------
- HELLO.C
- Copyright 1995-2005 Keil Software, Inc.
- #include <REG52.H> /* special function register declarations */
- /* for the intended 8051 derivative */
- #include <stdio.h> /* prototype declarations for I/O functions */
- #ifdef MONITOR51 /* Debugging with Monitor-51 needs */
- char code reserve [3] _at_ 0x23; /* space for serial interrupt if */
- #endif /* Stop Exection with Serial Intr. */
- /* is enabled */
- The main C function. Program execution starts
- here after stack initialization.
- void main (void) {
- Setup the serial port for 1200 baud at 16MHz.
- #ifndef MONITOR51
- SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */
- TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */
- TH1 = 221; /* TH1: reload value for 1200 baud @ 16MHz */
- TR1 = 1; /* TR1: timer 1 run */
- TI = 1; /* TI: set TI to send first char of UART */
- #endif
- Note that an embedded program never exits (because
- there is no operating system to return to). It
- must loop and execute forever.
- while (1) {
- P1 ^= 0x01; /* Toggle P1.0 each time we print */
- printf ("Hello World\n"); /* Print "Hello World" */
復(fù)制代碼 代碼。 |
