又是很無聊,弄了個超聲波出來,主要運用定時器TIM2_CH1捕獲,TM1640顯示
超聲波:TRIG:PA1 ECHO:PA0
TM1640:SCLK:PA11 SDIO:PA12
單位:厘米
制作出來的實物圖如下:
2021-2-13 01:53 上傳
2021-2-13 01:53 上傳
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "tim.h"
- #include "gpio.h"
- #include "tm1640.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- uint32_t capture_Buf[3] = {0}; //存放計數值
- uint8_t capture_Cnt = 0; //狀態標志位
- uint32_t high_time; //高電平時間
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- uint8_t i;
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_TIM2_Init();
- /* USER CODE BEGIN 2 */
- TM1640_Init();
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- switch (capture_Cnt){
- case 0:
- capture_Cnt++;
- i=200;
- HAL_GPIO_WritePin(TRIG_GPIO_Port,TRIG_Pin,GPIO_PIN_SET);
- while(i--);
- HAL_GPIO_WritePin(TRIG_GPIO_Port,TRIG_Pin,GPIO_PIN_RESET);
- __HAL_TIM_SET_CAPTUREPOLARITY(&htim2, TIM_CHANNEL_1, TIM_INPUTCHANNELPOLARITY_RISING);
- HAL_TIM_IC_Start_IT(&htim2, TIM_CHANNEL_1); //啟動輸入捕獲 或者: __HAL_TIM_ENABLE(&htim5);
- break;
- case 3:
- high_time = capture_Buf[1]- capture_Buf[0]; //高電平時間
- //HAL_UART_Transmit(&huart1, (uint8_t *)high_time, 1, 0xffff); //發送高電平時間
- high_time*=17;
- TM1640_display(0,high_time%1000000/100000);
- TM1640_display(1,high_time%100000/10000);
- TM1640_display(2,high_time%10000/1000+10);
- TM1640_display(3,high_time%1000/100);
- TM1640_display(4,high_time%100/10);
- TM1640_display(5,high_time%10);
- HAL_Delay(400); //延時1S
- capture_Cnt = 0; //清空標志位
- break;
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /** Initializes the RCC Oscillators according to the specified parameters
- * in the RCC_OscInitTypeDef structure.
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- /** Initializes the CPU, AHB and APB buses clocks
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- /** Enables the Clock Security System
- HAL_RCC_EnableCSS();
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- __disable_irq();
- while (1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
- void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim)
- if(TIM2 == htim->Instance)
- switch(capture_Cnt){
- case 1:
- capture_Buf[0] = HAL_TIM_ReadCapturedValue(&htim2,TIM_CHANNEL_1);//獲取當前的捕獲值.
- __HAL_TIM_SET_CAPTUREPOLARITY(&htim2,TIM_CHANNEL_1,TIM_ICPOLARITY_FALLING); //設置為下降沿捕獲
- capture_Cnt++;
- break;
- case 2:
- capture_Buf[1] = HAL_TIM_ReadCapturedValue(&htim2,TIM_CHANNEL_1);//獲取當前的捕獲值.
- HAL_TIM_IC_Stop_IT(&htim2,TIM_CHANNEL_1); //停止捕獲 或者: __HAL_TIM_DISABLE(&htim5);
- capture_Cnt++;
程序51hei提供下載:
buhuo_chaoshengbo.7z
(5.14 MB, 下載次數: 22)
2021-2-14 03:32 上傳
下載積分: 黑幣 -5
鏈接:https://pan.baidu.com/s/1oibDniL-afTCHEvdAmVmFA
提取碼:ly45
