名稱:按鍵測試單個菜單顯示
編寫:shifang
修改:無
內容:單個菜單,多頁顯示,不帶子菜單
#include <reg52.h>
#include <intrins.h>
sbit RS = P1^0;
sbit RW = P1^1;
sbit E = P2^5;
sbit RES = P2^3;
sbit PSB = P1^3;
sbit PAUSE = P3^0;
sbit beep=P2^3;
#define DataPort P0 //單片機 P0<------> 液晶DB0-DB7
sbit KEY_ADD=P3^4; //定義按鍵輸入端口
sbit KEY_DEC=P3^5;
sbit k3=P3^6;
unsigned char curr,currold;//全局變量,當前箭頭位置
unsigned char code user16x16[]={ //箭頭圖片
0x00,0x00,0x20,0x00,0x30,0x00,0x38,0x00,0x3C,0x00,0x3E,0x00,0x3F,0x00,0x3F,0x80,
0x3F,0xC0,0x3F,0x80,0x3F,0x00,0x3E,0x00,0x3C,0x00,0x38,0x00,0x30,0x00,0x20,0x00,
unsigned char code *MainMenu[]=
{" 1.蜂鳴器響"},
{" 2.蜂鳴器滅"},
{" 3.蜂鳴器亮"},
{" 4.蜂鳴器滅"},
{" 5.蜂鳴器亮"},
{" 6.蜂鳴器滅"},
檢測忙位
void DelayUs2x(unsigned char t)
while(--t);
mS延時函數,含有輸入參數 unsigned char t,無返回值
unsigned char 是定義無符號字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時請使用匯編
void DelayMs(unsigned char t)
while(t--)
//大致延時1mS
DelayUs2x(245);
DelayUs2x(245);
void Check_Busy()
RS=0;
RW=1;
E=1;
DataPort=0xff;
while((DataPort&0x80)==0x80);//忙則等待
E=0;
寫命令
void Write_Cmd(unsigned char Cmd)
Check_Busy();
RS=0;
RW=0;
E=1;
DataPort=Cmd;
DelayUs2x(5);
E=0;
DelayUs2x(5);
寫數據
void Write_Data(unsigned char Data)
Check_Busy();
RS=1;
RW=0;
E=1;
DataPort=Data;
DelayUs2x(5);
E=0;
DelayUs2x(5);
液晶屏初始化
void Init_ST7920()
DelayMs(40); //大于40MS的延時程序
PSB=1; //設置為8BIT并口工作模式
DelayMs(1); //延時
RES=0; //復位
DelayMs(1); //延時
RES=1; //復位置高
DelayMs(10);
Write_Cmd(0x30); //選擇基本指令集
DelayUs2x(50); //延時大于100us
Write_Cmd(0x30); //選擇8bit數據流
DelayUs2x(20); //延時大于37us
Write_Cmd(0x0c); //開顯示(無游標、不反白)
Write_Cmd(0x01); //清除顯示,并且設定地址指針為00H
DelayMs(15); //延時大于10ms
Write_Cmd(0x06); //指定在資料的讀取及寫入時,設定游標的移動方向及指定顯示的移位,光標從右向左加1位移動
用戶自定義字符
void CGRAM()
int i;
Write_Cmd(0x30);
Write_Cmd(0x40);
for(i=0;i<16;i++)
Write_Data(user16x16[i*2]);
Write_Data(user16x16[i*2+1]);
顯示用戶自定義字符
void DisplayCGRAM(unsigned char x,unsigned char y)
switch(y)
case 1: Write_Cmd(0x80+x);break;
case 2: Write_Cmd(0x90+x);break;
case 3: Write_Cmd(0x88+x);break;
case 4: Write_Cmd(0x98+x);break;
default:break;
Write_Data(00);
Write_Data(00);
顯示字符串
x:橫坐標值,范圍0~8
y:縱坐標值,范圍1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
default:break;
while(*s>0)
Write_Data(*s);
s++;
DelayUs2x(50);
清屏
void ClrScreen()
Write_Cmd(0x01);
DelayMs(15);
顯示圖片
/*void LCD_PutGraphic(unsigned char code *img)
int i,j;
//顯示上半屏內容設置
for(i=0;i<32;i++)
Write_Cmd(0x80 + i); //SET 垂直地址 VERTICAL ADD
Write_Cmd(0x80); //SET 水平地址 HORIZONTAL ADD
for(j=0;j<16;j++)
Write_Data(*img);
img++;
//顯示下半屏內容設置
for(i=0;i<32;i++)
Write_Cmd(0x88); //SET 水平地址 HORIZONTAL ADD
for(j=0;j<16;j++)
Write_Data(*img);
img++;
設置到繪圖模式
/*void SetGraphicMode()
Write_Cmd(0x36); //選擇8bit數據流 圖形模式
DelayUs2x(20);
調用顯示更新
void DisplayUpdata(void)
unsigned char num;
ClrScreen();
num=sizeof(MainMenu)/sizeof(MainMenu[0]);//判斷數組中數值個數
if((0+(curr/4)*4)<num)
LCD_PutString(0,1,MainMenu[0+(curr/4)*4]);
else //如果超出數組最大元素,則寫空信息,不判斷此信息可能會出現亂碼
LCD_PutString(0,1,"");
if((1+(curr/4)*4)<num)
LCD_PutString(0,2,MainMenu[1+(curr/4)*4]);
LCD_PutString(0,2,"");
if((2+(curr/4)*4)<num)
LCD_PutString(0,3,MainMenu[2+(curr/4)*4]);
LCD_PutString(0,3,"");
if((3+(curr/4)*4)<num)
LCD_PutString(0,4,MainMenu[3+(curr/4)*4]);
LCD_PutString(0,4,"");
DisplayCGRAM(0,curr%4+1);
主程序
main()
Init_ST7920(); //初始化
CGRAM(); //寫入自定義字符
DisplayUpdata();
// beep=0;
if(curr!=currold) //光標位置變化,則更新顯示
DisplayUpdata();
currold=curr;
if(!KEY_ADD) //如果檢測到低電平,說明按鍵按下
DelayMs(10); //延時去抖,一般10-20ms
if(!KEY_ADD) //再次確認按鍵是否按下,沒有按下則退出
while(!KEY_ADD);//如果確認按下按鍵等待按鍵釋放,沒有釋放則一直等待
if(curr<sizeof(MainMenu)/sizeof(MainMenu[0])-1)//判斷數組中數值個數
curr++;
if(!KEY_DEC) //如果檢測到低電平,說明按鍵按下
if(!KEY_DEC) //再次確認按鍵是否按下,沒有按下則退出
while(!KEY_DEC);//如果確認按下按鍵等待按鍵釋放,沒有釋放則一直等待
if(curr>0)
curr--;
if(k3==0)
switch(curr)
case 0: beep=0; break;
case 1: beep=1; break;
case 2: beep=0; break;
case 3: beep=1; break;
case 4: beep=0; break;
case 5: beep=1; break;
