呼吸燈加交通燈
J9跳線帽不能拔掉
#include <reg52.h>
sbit Red = P1^0;
sbit Yellow = P1^1;
sbit Green = P1^2;
sbit DU = P2^6; //數碼管段選
sbit WE = P2^7; //數碼管位選
unsigned char const discode[] ={ 0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,0x6F,0x40,0x00/*-*/};
unsigned char const positon[2]={ 0xfe,0xfd};
unsigned char disbuff[2] ={ 0,0};
unsigned char pwm_left_val = 0;//
unsigned char pwm_t;//周期
unsigned char posit=0;
unsigned int Dbuf;//
bit flag = 0;
//毫秒級延時
void delay(unsigned int z)
unsigned int x,y;
for(x = z; x > 0; x--)
for(y = 114; y > 0 ; y--);
void Display(void) //掃描數碼管
DU = 0;
if(posit==0)
{P0=(discode[disbuff[posit]]);}
{P0=discode[disbuff[posit]];}
DU = 1;
DU = 0;
WE = 0;
P0=positon[posit];
WE=1;
WE=0;
if(++posit>=2)
posit=0;
//定時器0中斷
void timer0() interrupt 1
pwm_t++;
if(pwm_t == 255)
pwm_t = P1 = 0;
if(pwm_left_val == pwm_t)
P1 = 0XFF;
void timer1() interrupt 3 //T1中斷用來掃描數碼管和計2MS啟動模塊
TH1=0xf8; //2ms
TL1=0xCC;
if(flag == 0)
disbuff[0]=Dbuf % 100 / 10;
disbuff[1]=Dbuf % 10;
Display();
EA = 1;//總中斷允許
unsigned char i, delay_sec;
TMOD |= 0x02;//T0 8位自動重裝模塊
TH0 = 225;
TL0 = 225;//11.0592M晶振下占空比最大比值是256,輸出100HZ
TR0 = 1;//啟動定時器0
ET0 = 1;//允許定時器0中?
for(i=0; i < 4; i++)
while(pwm_left_val != 255)
++pwm_left_val;
delay(1);
while(pwm_left_val != 0)
--pwm_left_val;
delay(1);
ET0 = 0;
TR0 = 0;
P1 = 0XFF;
delay(2000);
TMOD |= 0x10;//T1 16位定時
TH1=0xf8; //2ms
TL1=0xCC;
ET1=1; //允許T1中斷
TR1=1; //開啟定時器1
delay_sec = 10;
Red = 0;
do{
Dbuf = delay_sec;
delay(1000);
}while(--delay_sec);
Red = 1;
delay_sec = 10;//10sec
Green = 0;
do{
if(delay_sec <= 3)//綠燈閃爍
Green = 0;
Dbuf = delay_sec;
delay(500);
flag = 1;
disbuff[0] = 11;
disbuff[1] = 11;
Green = 1;
delay(500);
flag = 0;
Dbuf = delay_sec;
delay(1000);
Green = 1;
delay_sec = 3;//
Yellow = 0;
do{
Dbuf = delay_sec;
delay(1000);
Yellow = 1;
