只需一步,快速開(kāi)始
查看: 3212|回復(fù): 4
STM32L151單片機(jī)ADC在喚醒后無(wú)法正常運(yùn)行 卡死在while
回帖獎(jiǎng)勵(lì) 5 黑幣 回復(fù)本帖可獲得 5 黑幣獎(jiǎng)勵(lì)! 每人限 1 次
ID:621862 發(fā)表于 2020-12-24 13:54 | 顯示全部樓層 |閱讀模式
void  Adc_Init(void)
                ADC_InitTypeDef ADC_InitStructure;
                /*----------------- ADC1 configuration with DMA enabled --------------------*/
    /* Enable the HSI oscillator */
    RCC_HSICmd(ENABLE);
    /* Enable GPIOB clock */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    /* Configure PB.0 (ADC Channe8) in analog mode */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    /* Check that HSI oscillator is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
    /* Enable ADC1 clock */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    /* ADC1 configuration */
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConvEdge_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfConversion = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
    /* ADC1 regular channel18 configuration */
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_4Cycles);
    /* Enable ADC1 */
                ADC_TempSensorVrefintCmd(ENABLE);
    ADC_Cmd(ADC1, ENABLE);
                /* Wait until the ADC1 is ready */
    while(ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS) == RESET)
                        Uart1_SendStr(".");
                        delay_ms(1000);
                ADC_SoftwareStartConv(ADC1);
u16 Get_Adc(u8 ch)
          //設(shè)置指定ADC的規(guī)則組通道,一個(gè)序列,采樣時(shí)間
        ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_96Cycles );        //ADC1,ADC通道,采樣時(shí)間為239.5周期
  delay_ms(50);
        ADC_SoftwareStartConv(ADC1);                //使能指定的ADC1的軟件轉(zhuǎn)換啟動(dòng)功能
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC )){
            ADC_ClearFlag (ADC1,ADC_FLAG_EOC);
        return ADC_GetConversionValue(ADC1);        //返回最近一次ADC1規(guī)則組的轉(zhuǎn)換結(jié)果
  卡死在while 這里了
ID:540513 發(fā)表于 2020-12-29 13:35 | 顯示全部樓層
初始化觸發(fā)方式目前使用的是外部觸發(fā),可以更換為軟件觸發(fā)試試
ID:310808 發(fā)表于 2023-8-8 15:50 | 顯示全部樓層
時(shí)鐘和引腳不對(duì)應(yīng)
ID:1063563 發(fā)表于 2023-8-10 08:09 | 顯示全部樓層
是不是在等待模擬量的標(biāo)志位,才卡在哪里等待。
ID:372579 發(fā)表于 2023-8-12 09:09 | 顯示全部樓層
最好仿真下看看
