只需一步,快速開(kāi)始
查看: 2791|回復(fù): 0
一個(gè)按鍵控制LED開(kāi)關(guān)和延時(shí)進(jìn)行模式切換 Proteus仿真程序
ID:853104 發(fā)表于 2020-12-22 11:58 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
單片機(jī)源程序如下:
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. sbit s1=P3^4;
  5. sbit led=P3^3;//
  6. /*****************按鍵掃描用的**********************/
  7. #define  short_key 5
  8. #define  short_small_key  4
  9. #define  long_key  100
  10. bit button1_shortflag=0;
  11. bit button1_longflag=0;
  12.   uchar flag=2;
  13.   void time_init()
  14.   {
  15.   TMOD=0x01;//方式1
  16.   TH0=-10000/256;
  17.   TL0=-10000%256;//10ms
  18.   ET0=1;//開(kāi)定時(shí)器0中斷
  19.   TR0=1;//開(kāi)定時(shí)器
  20.   EA=1;//開(kāi)總中斷
  21.   }
  22. /****************************************/
  23. void getkey_number()
  24. {
  25. static uchar button1_time=0;
  26. static uchar button1_time1=0;
  27.         if(s1==0)
  28.         {
  29.            button1_time>=short_key?(button1_time=short_key):button1_time++;//
  30.                  button1_time1>=long_key?(button1_time1=long_key):button1_time1++;//
  31.         }
  32.     else
  33.                 {
  34.                         if(button1_time1==long_key)
  35.                         {   button1_time1=0;
  36.                             button1_time=0;
  37.                                  button1_longflag=1;
  38.                         }
  39.                  if(button1_time==short_key)
  40.                  {
  41.                           button1_time=0;
  42.                          button1_time1=0;
  43.                          button1_shortflag=1;
  44.                  }
  45.                 }
  46. }
  47. void main()
  48. {
  49.         static uchar k;
  50. time_init();//定時(shí)器開(kāi)啟
  51.    while(1)
  52.    {
  53.
  54. if(button1_shortflag==1)
  55. {
  56.         button1_shortflag=0;
  57.         flag=2;
  58.         if(led==0) led=1;
  59.         else led=0;
  60. }
  61. if(button1_longflag==1)
  62. {
  63. button1_longflag=0;
  64.         if(++k>=2) k=0;
  65.    if(k==0) {flag=1;}
  66.                  else  {flag=0;}
  67. }
  68.    }
  69. }
  70. /****************************************/
  71. void time0() interrupt 1
  72. {
  73. static uchar time=0;
  74.         static uchar m;
  75. TR0=0;
  76. /*************用于按鍵掃描******************/
  77. if(++time>=2)
  78. {  time=0;
  79.   getkey_number();
  80. }
  81. if(flag!=2)
  82. {
  83. if(flag==0)
  84. {
  85.         if(++m>=40)
  86.         {
  87.         m=0; led=!led;
  88.         }
  89. }
  90.         if(flag==1)
  91.         {
  92.         led=0;
  93.         }
  94. }
  95.   TH0=-10000/256;
  96.   TL0=-10000%256;
  97.   TR0=1;
  98. }
仿真程序51hei提供下載:
一個(gè)按鍵控制LED開(kāi)關(guān)和延時(shí)切換模式.rar (96.23 KB, 下載次數(shù): 13)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏4 分享淘帖 頂 踩
