查看: 3911|回復(fù): 1
簡單的單片機矩陣鍵盤設(shè)計+Proteus仿真
ID:836200 發(fā)表于 2020-12-22 09:46 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
這是一個比較簡單的矩陣鍵盤顯示為1~16,
萌新路過,大佬勿噴,若有問題,還請指出,十分感謝
附件里包括源碼和proteus仿真,若有需要可以下載
proteus仿真
代碼如下
  1. #include <REGX52.H>
  2. sbit key = P3^3;
  3. sbit LSA = P2^0;
  4. sbit LSB = P2^1;
  5. #define TIM_ZJ 5
  6. char num = -1,num2 = 0;
  7. unsigned char code dis[]={0x3f,0x06,0x5b,0x4f,0x66,   // 0 1 2 3 4
  8.                           0x6d,0x7d,0x07,0x7f,0x6f,0x00}; // 5 6 7 8 9
  9. unsigned char code keycode[16] = {0x77,0x7b,0x7d,0x7e,0xb7,
  10.        0xbb,0xbd,0xbe,0xd7,0xdb,
  11.        0xdd,0xde,0xe7,0xeb,0xed,0xee};
  12. void delay(unsigned int aaaa)   //10us
  13. {
  14.     while(aaaa--);
  15. }
  16. void dis_play()
  17. {
  18.         LSA = 1;
  19.         LSB = 0;
  20.         P0 = dis[num2%10];
  21.         if(num2 == 0)
  22.         {
  23.                 P0 = 0x00;
  24.         }
  25.         delay(100);
  26.         P0 = 0x00;
  27.         LSA = 0;
  28.         LSB = 1;
  29.         P0 = dis[num2/10];
  30.         if(num2 < 10)
  31.         {
  32.                 P0 = 0x00;
  33.         }
  34.         delay(100);
  35.         P0 = 0x00;
  36. }
  37. char matrix_buttons(void)
  38. {
  39.         unsigned char scan1,scan2,key,j;
  40.
  41.         char matrix_value = -1;
  42.
  43.         P1 = 0xf0;
  44.         if(P1 != 0xf0)
  45.         {
  46.                 delay(TIM_ZJ);
  47.                 if(P1 != 0xf0)
  48.                 {
  49.                         scan1 = P1;
  50.                         P1 = 0x0f;
  51.                         scan2 = P1;
  52.                         key = scan1 | scan2;
  53.
  54.                         for(j = 0; j < 16; j++)
  55.                         {
  56.                                 if(key == keycode[j])
  57.                                 {
  58.                                         matrix_value = j + 1;
  59.                                 }
  60.                         }
  61.                 }
  62.                 P1 = 0x0f;
  63.                 while(P1 != 0x0f) dis_play();
  64.                 delay(TIM_ZJ);
  65.                 while(P1 != 0x0f) dis_play();
  66.         }
  67.         return (matrix_value);
  68. }
  69. void main()
  70. {
  71.         while(1)
  72.         {
  73.                 num = matrix_buttons();
  74.                 if(num != -1)
  75.                 {
  76.                         num2 = num;
  77.                 }
  78.                 dis_play();
  79.         }
  80. }
全部資料51hei下載地址:
矩陣鍵盤.zip (99.84 KB, 下載次數(shù): 72)
參與人數(shù) 1黑幣 +50 收起 理由
ID:938345 發(fā)表于 2021-6-15 23:51 | 只看該作者
這個代碼是完整的嗎
