#include "reg52.h"
#include "lcd.h"
#include "temp.h"
#include "i2c.h"
sbit k3=P3^2; //設(shè)置溫度上下限
sbit k1=P3^1; //加
sbit k2=P3^0; //減
sbit led=P2^4; //報警指示燈
sbit beep=P1^5; //蜂鳴器報警
sbit relay=P1^1; // 設(shè)備加熱和繼電器
sbit moto=P1^0; // 電機(jī)散熱
char set_temph=0,a=0;//,set_templ=28; //設(shè)定溫度限默認(rèn)值
u16 temp_val; //檢測的實(shí)際溫度
u8 mode; //溫度模式
void delay(u16 i)
while(i--);
void Temp_DataPros()
char set_temph=a;//,set_templ=28; //設(shè)定溫度上下限默認(rèn)值
short temp;
u8 temp_buf[5];
temp=Ds18b20ReadTemp();
temp_val=temp;
if(temp<0)
temp=-temp;
LCD_Dispstring(3+5,0,"-");
LCD_Dispstring(3+5,0," ");
temp_buf[0]=temp/100+0x30;
temp_buf[1]=temp%100/10+0x30;
temp_buf[2]='.';
temp_buf[3]=temp%100%10+0x30;
temp_buf[4]='\0';
LCD_Dispstring(3+6,0,temp_buf); //顯示檢測的溫度xx.x
set_temph=a;
temp_buf[0]=set_temph/10+0x30;
temp_buf[1]=set_temph%10+0x30;
temp_buf[2]='\0';
LCD_Dispstring(8,1,temp_buf); //顯示設(shè)定的溫度值xx */
#define K1_MODE 1
#define K2_ADD 2
#define K3_DEC 3
//mode: 0-單次掃描 1-連續(xù)掃描
u8 KEY_Scan(u8 mode)
static u8 key=1;
if(key&&(k1==0||k2==0||k3==0))
delay(1000); //消抖
key=0;
if(k3==0)
return K1_MODE;
else if(k1==0)
return K2_ADD;
else if(k2==0)
return K3_DEC;
else if(k1==1&&k2==1&&k3==1)
key=1;
if(mode)
key=1;
return 0;
void sound()
u8 i=50;
while(i--)
beep=!beep;
delay(10);
void KEY_Pros()
u8 key;
u8 temph_buf[3];
key=KEY_Scan(0);
if(key==K1_MODE) //模式選擇
mode++;
LCD_Clear();
if(mode==1)
LCD_Dispstring(4,0,"SET: C");
mode=0;
LCD_Dispstring(3,0,"Temp: C");
LCD_Dispstring(4,1,"SET: C");
if(mode==1) //溫度上限設(shè)置
switch(key)
case K2_ADD: //加
set_temph++;
if(set_temph>=80)set_temph=80;
break;
case K3_DEC: //減
set_temph--;
if(set_temph<=0)set_temph=0;
break;
a=set_temph;
temph_buf[0]=set_temph/10+0x30;
temph_buf[1]=set_temph%10+0x30;
temph_buf[2]='\0';
LCD_Dispstring(8,0,temph_buf);
At24c02Write(0,set_temph);
void TempData_Compare()
if(temp_val>(set_temph+1)*10) //實(shí)際溫度高于上限值 報警 散熱
led=1;
moto=1; //1
relay=0;
sound();
else if(temp_val<(set_temph-1)*10) //實(shí)際溫度低于下限值 報警 加熱
led=1;
moto=0; //0
relay=1;
sound();
else //實(shí)際溫度在下限值和上限值之間 取消報警 取消加熱 取消散熱
moto=1;
led=0;
relay=1;
void kai_display()
if(At24c02Read(255)!=18)
At24c02Write(255,18);
set_temph=At24c02Read(0);
moto=0;
led=0;
relay=0;
LCD_Init();
kai_display();
TempData_Compare();
if(mode==0)
Temp_DataPros();
KEY_Pros();
