只需一步,快速開(kāi)始
查看: 3741|回復(fù): 0
esp8266通訊手機(jī)APP控制云臺(tái)舵機(jī)源程序
直接上源碼文件
單片機(jī)源程序如下:
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint  unsigned int
  5. #define false 0
  6. #define true  1
  7. #define High  1
  8. #define Low          0
  9. //舵機(jī)控制引腳
  10. sbit SERVO_SB1 = P1^0;            //上臂1
  11. sbit SERVO_SB2 = P1^1;            //上臂2
  12. sbit LED = P1^2;
  13. sbit KEY1 = P2^0;
  14. sbit KEY2 = P2^1;
  15. sbit KEY3 = P2^2;
  16. sbit KEY4 = P2^3;
  17. sbit KEY5 = P2^4;
  18. sbit KEY6 = P2^5;
  19. uchar ComDat;
  20. //調(diào)節(jié)范圍5-19,對(duì)應(yīng)舵機(jī)的0-180度
  21. uchar pwm_val_SJ  =0;                          //上夾子
  22. uchar pwm_val_SB1  =0;                          //上夾子1臂
  23. uchar pwm_val_SB2  =0;                          //上夾子2臂
  24. uchar push_val_SJ =0;
  25. uchar push_val_SB1 =0;
  26. uchar push_val_SB2 =0;
  27. uchar SB1_Val = 0;
  28. uchar SB2_Val = 0;
  29. bit Comflag = false;
  30. //void Uart_byte(unsigned char adata)
  31. //{
  32. //        TI=0;
  33. //        SBUF=adata;
  34. //        while(!TI);
  35. //        TI=0;
  36. //}
  37. void InitUART(void)
  38. {
  39.     TMOD = 0x21;
  40.     SCON = 0x50;
  41.     TH1 = 0xFA;
  42.     TL1 = TH1;
  43.     PCON = 0x80;
  44.     ES = 1;
  45.     TR1 = 1;
  46. }
  47. void PWM_INIT()
  48. {
  49.         TH0= 0XFF;                  //1ms定時(shí)
  50.         TL0= 0XA4;
  51.         TR0= 1;
  52.         ET0= 1;
  53.         EA = 1;
  54. }
  55. void Delay_1ms(uint t)
  56. {
  57.         unsigned int i,j;
  58.         for(i=0; i<t;  i++)
  59.     for(j=0; j<150; j++);
  60. }
  61. void Uart_byte(unsigned char adata)
  62. {
  63.         TI=0;
  64.         SBUF=adata;
  65.         while(!TI);
  66.         TI=0;
  67. }
  68. void sendstring(unsigned char *string)
  69. {
  70. while(*string!='\0')
  71.     {
  72.                 Uart_byte(*string);
  73.                 string++;
  74.     }
  75. }
  76. void ESP8266_Init()
  77. {
  78.         sendstring("AT\r\n");
  79.         Delay_1ms(200);
  80.         sendstring("AT+CWMODE=3\r\n");
  81.         Delay_1ms(300);
  82.
  83.         sendstring("AT+CIPMUX=1\r\n");
  84.         Delay_1ms(300);
  85.         sendstring("AT+CIPSERVER=1,8080\r\n");
  86.         Delay_1ms(300);
  87. }
  88. void main()
  89. {
  90.     uchar DJ1 = 5,DJ2 = 19;
  91.         InitUART();
  92.         PWM_INIT();
  93.         ESP8266_Init();
  94.         pwm_val_SB1 = 0;
  95.         push_val_SB1 = DJ1;
  96.         pwm_val_SB2 = 0;
  97.         push_val_SB2 = DJ2;
  98.         while(1){
  99.            if(Comflag == 1){
  100.               Comflag = 0;
  101.                         if(ComDat == 0xAA){
  102.                                 DJ1 ++;
  103.                                 if(DJ1>=19){
  104.                                    DJ1 = 19;
  105.
  106.                                 }
  107.                                 SB1_Val = DJ1;
  108.                                 //Uart_byte(SB1_Val);
  109.                                 push_val_SB1  = SB1_Val;
  110.
  111.                         }
  112.                         else if(ComDat == 0xBB){
  113.                                 DJ1 --;
  114.                                 if(DJ1<=5){
  115.                                    DJ1 = 5;
  116.
  117.                                 }
  118.                                 SB1_Val = DJ1;
  119.                                 //Uart_byte(SB2_Val);
  120.                                 push_val_SB1  = SB1_Val;
  121.
  122.                         }
  123.                                                 if(ComDat == 0xCC){
  124.                                 DJ2 ++;
  125.                                 if(DJ2>=19){
  126.                                    DJ2 = 19;
  127.
  128.                                 }
  129.                                 SB2_Val = DJ2;
  130.                                 //Uart_byte(SB1_Val);
  131.                                 push_val_SB2  = SB2_Val;
  132.
  133.                         }
  134.                         else if(ComDat == 0xDD){
  135.                                 DJ2 --;
  136.                                 if(DJ2<=5){
  137.                                    DJ2 = 5;
  138.
  139.                                 }
  140.                                 SB2_Val = DJ2;
  141.                                 //Uart_byte(SB2_Val);
  142.                                 push_val_SB2  = SB2_Val;
  143.
  144.                         }
  145.
  146.            }
  147.            if(KEY1 ==0){
  148.                      Delay_1ms(5);
  149.                   if(KEY1 ==0){
  150.                         DJ1 ++;
  151.                         if(DJ1>=19){
  152.                            DJ1 = 19;
  153.                         }
  154.                         SB1_Val = DJ1;
  155.                         //Uart_byte(SB1_Val);
  156.                         push_val_SB1  = SB1_Val;
  157.                         while(!KEY1);
  158.                   }
  159.            }
  160.            if(KEY2 ==0){
  161.                      Delay_1ms(5);
  162.                   if(KEY2 ==0){
  163.                         DJ1 --;
  164.                         if(DJ1<=5){
  165.                            DJ1 = 5;
  166.                         }
  167.                         SB1_Val = DJ1;
  168.                         //Uart_byte(SB1_Val);
  169.                         push_val_SB1  = SB1_Val;
  170.                         while(!KEY2);
  171.                   }
  172.            }
  173.            if(KEY3 ==0){
  174.                      Delay_1ms(5);
  175.                   if(KEY3 ==0){
  176.                         DJ2 ++;
  177.                         if(DJ2>=19){
  178.                            DJ2 = 19;
  179.                         }
  180.                         SB2_Val = DJ2;
  181.                         //Uart_byte(SB2_Val);
  182.                         push_val_SB2  = SB2_Val;
  183.                         while(!KEY3);
  184.                   }
  185.            }
  186.            if(KEY4 ==0){
  187.                      Delay_1ms(5);
  188.                   if(KEY4 ==0){
  189.                         DJ2 --;
  190.                         if(DJ2<=5){
  191.                            DJ2 = 5;
  192.                         }
  193.                         SB2_Val = DJ2;
  194.                         //Uart_byte(SB2_Val);
  195.                         push_val_SB2  = SB2_Val;
  196.                         while(!KEY4);
  197.                   }
  198.            }
  199.         }
  200. }
  201. /***************************************************/
  202. ///*TIMER0中斷服務(wù)子函數(shù)產(chǎn)生PWM信號(hào)*/
  203.         void timer0()interrupt 1
  204. {
  205.         TH0=0XFF;          //1Ms定時(shí)
  206.         TL0=0XA4;
  207.         pwm_val_SB1++;;
  208.         if(pwm_val_SB1<=push_val_SB1)
  209.            SERVO_SB1 = High;
  210.         else
  211.            SERVO_SB1 = Low;
  212.         if(pwm_val_SB1>=200){
  213.            pwm_val_SB1=0;
  214.         }
  215.         pwm_val_SB2++;;
  216.         if(pwm_val_SB2<=push_val_SB2)
  217.            SERVO_SB2 = High;
  218.         else
  219.            SERVO_SB2 = Low;
  220.         if(pwm_val_SB2>=200){
  221.            pwm_val_SB2=0;
  222.         }
  223. }
  224. void UARTInterrupt(void) interrupt 4
  225. {
  226. ////   static int i=0;
  227. //   if(RI==1)
  228. //   {
  229. //     RI=0;
  230. //         if(SBUF==0xaa)        LED=0;          //開(kāi)燈
  231. //         else if(SBUF==0xbb)LED=1;          //關(guān)燈
  232. //
  233. //   }
  234.         if(RI) {
  235.                 RI = 0;
  236.                 ComDat = SBUF;
  237.                 Comflag = true;
  238.         }
  239. }
以上資料51hei提供下載:
NO12.zip (46.67 KB, 下載次數(shù): 31)
28215.pdf (212.44 KB, 下載次數(shù): 21)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏2 分享淘帖 頂 踩
