查看: 3558|回復: 0
基于Arduino的心率計程序與接線圖
電路原理圖如下:
Arduino源碼如下:
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#include "Wire.h"
#include "Adafruit_GFX.h"
#include "OakOLED.h"
#define REPORTING_PERIOD_MS 1000
OakOLED oled;
PulseOximeter pox;
uint32_t tsLastReport = 0;
const unsigned char bitmap [] PROGMEM={
0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x18, 0x00, 0x0f, 0xe0, 0x7f, 0x00, 0x3f, 0xf9, 0xff, 0xc0,
0x7f, 0xf9, 0xff, 0xc0, 0x7f, 0xff, 0xff, 0xe0, 0x7f, 0xff, 0xff, 0xe0, 0xff, 0xff, 0xff, 0xf0,
0xff, 0xf7, 0xff, 0xf0, 0xff, 0xe7, 0xff, 0xf0, 0xff, 0xe7, 0xff, 0xf0, 0x7f, 0xdb, 0xff, 0xe0,
0x7f, 0x9b, 0xff, 0xe0, 0x00, 0x3b, 0xc0, 0x00, 0x3f, 0xf9, 0x9f, 0xc0, 0x3f, 0xfd, 0xbf, 0xc0,
0x1f, 0xfd, 0xbf, 0x80, 0x0f, 0xfd, 0x7f, 0x00, 0x07, 0xfe, 0x7e, 0x00, 0x03, 0xfe, 0xfc, 0x00,
0x01, 0xff, 0xf8, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x3f, 0xc0, 0x00,
0x00, 0x0f, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
void setup()
  Serial.begin(9600);
  oled.begin();
  oled.clearDisplay();
  oled.setTextSize(1);
  oled.setTextColor(1);
  oled.setCursor(0, 0);
  oled.println("Initializing pulse oximeter..");
  oled.display();
  Serial.print("Initializing pulse oximeter..");
  if (!pox.begin()) {
    Serial.println("FAILED");
    oled.println("FAILED");
    oled.display();
    for(;;);
  } else {
    oled.println("SUCCESS");
    oled.display();
    Serial.println("SUCCESS");
  pox.setOnBeatDetectedCallback(onBeatDetected);
void loop()
  pox.update();
  if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
    Serial.print("Heart BPM:");
    Serial.print(pox.getHeartRate());
    Serial.print("-----");
    Serial.print("Oxygen Percent:");
    Serial.print(pox.getSpO2());
    Serial.println("\n");
    oled.setCursor(0,16);
    oled.println(pox.getHeartRate());
    oled.println("Heart BPM");
    oled.setCursor(0, 30);
    oled.println("Spo2");
    oled.setCursor(0,45);
    oled.println(pox.getSpO2());
    oled.display();
    tsLastReport = millis();
void onBeatDetected()
  Serial.println("Beat!");
  oled.drawBitmap( 60, 20, bitmap, 28, 28, 1);
  oled.display();
全部資料51hei下載地址:
ArduinoPulseOximeterM30100-master.zip (506.86 KB, 下載次數: 13)
