查看: 2669|回復: 0
51單片機計時程序與仿真電路圖程序
ID:849631 發表于 2020-11-26 15:22 | 顯示全部樓層 |閱讀模式
仿真電路圖(沒畫最小系統)
仿真電路圖(沒畫最小系統)
#include<reg51.h>
unsigned char  seg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff};
//共陽極斷碼表
unsigned char num=0,count=0;
sbit K0=P3^2;
sbit K1=P3^3;
int i=0;
void dis_play();
void intittimer();
   intittimer();
      dis_play();
void intittimer()
  TMOD=0x01;
  TH0=(65536-50000)/256;  //50ms=50000us
  TL0=(65536-50000)%256;
  ET0=1;
  EA=1;
  TR0=0;
  IT0=1;
  EX0=1;
  IT1=1;
  EX1=1;
void dis_play()
  if(num==100)
    num=0;
  P2=seg[num/10];
  P1=seg[num%10];
void a() interrupt 0
   TR0=~TR0;
   num=num;
void b()interrupt 2
  TR0=0;
  num=0;
void timer_isr()  interrupt 1
  TH0=(65536-50000)/256;  //50ms=50000us  256=2^8  初值>>8
  count++;
  if(count==20)
     num++;
     count=0;
秒表.zip (36.84 KB, 下載次數: 10)
