查看: 4475|回復(fù): 1
關(guān)于單片機(jī)8x8點(diǎn)陣屏移動(dòng)顯示0-F等十六個(gè)字符的仿真和程序
ID:827939 發(fā)表于 2020-11-22 20:30 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. typedef unsigned char u8;
  4. typedef unsigned int u16;
  5. sbit R3 = P1^2;    //
  6. sbit R2 = P1^1;    //
  7. sbit R1 = P1^0;    //
  8. sbit DS   = P1^4;  //
  9. sbit SHCP = P1^5;  //
  10. sbit STCP = P1^6;  //
  11. code u8 g[16][8]={
  12.                                   {0x00,0x38,0x44,0x44,0x44,0x44,0x38,0x00},//0
  13.                                   {0x00,0x08,0x18,0x08,0x08,0x08,0x1C,0x00},//1
  14.                                   {0x00,0x3C,0x04,0x04,0x3C,0x20,0x20,0x3C},//2
  15.                                   {0x00,0x3C,0x04,0x04,0x3C,0x04,0x04,0x3C},//3
  16.                                   {0x04,0x0C,0x14,0x24,0x44,0xFF,0x04,0x04},//4
  17.                                   {0x00,0x1E,0x10,0x10,0x1E,0x02,0x02,0x1E},//5
  18.                                   {0x00,0x3C,0x20,0x20,0x3E,0x22,0x22,0x3E},//6
  19.                                   {0x00,0x1E,0x02,0x04,0x08,0x08,0x08,0x08},//7
  20.                                   {0x1C,0x22,0x22,0x22,0x1C,0x22,0x22,0x1C},//8
  21.                                   {0x3C,0x24,0x24,0x3C,0x04,0x04,0x3C,0x00},//9
  22.                                   {0x00,0x10,0x28,0x44,0x7C,0x44,0x44,0x00},//A
  23.                                   {0x00,0x38,0x24,0x24,0x38,0x24,0x24,0x38},//B
  24.                                   {0x1C,0x22,0x20,0x20,0x20,0x22,0x1C,0x00},//C
  25.                                   {0x00,0x38,0x24,0x24,0x24,0x24,0x38,0x00},//D
  26.                                   {0x00,0x3C,0x20,0x20,0x3C,0x20,0x20,0x3C},//E
  27.                                   {0x00,0x3C,0x20,0x3C,0x20,0x20,0x20,0x00}        //F
  28.                                   };
  29. void wrong(u16 i)  //調(diào)試用
  30. {
  31.         if(i)
  32.                 P0=0xff;
  33. }
  34. void delay1ms(void)   //100ms延時(shí)
  35. {
  36.     unsigned char a,b;
  37.     for(b=199;b>0;b--)
  38.         for(a=1;a>0;a--);
  39. }
  40. void row(u8 r)  //選擇點(diǎn)亮第幾行
  41. {
  42.         switch(r)
  43.         {
  44.                 case 1:{R3=1;R2=1;R1=1;};break;
  45.                 case 2:{R3=1;R2=1;R1=0;};break;
  46.                 case 3:{R3=1;R2=0;R1=1;};break;
  47.                 case 4:{R3=1;R2=0;R1=0;};break;
  48.                 case 5:{R3=0;R2=1;R1=1;};break;
  49.                 case 6:{R3=0;R2=1;R1=0;};break;
  50.                 case 7:{R3=0;R2=0;R1=1;};break;
  51.                 case 8:{R3=0;R2=0;R1=0;};break;
  52.
  53.                 default :wrong(1);break;
  54.         }
  55. }
  56. void send(u8 d) //選擇該行顯示的內(nèi)容
  57. {
  58.         u8 i;
  59.
  60.         SHCP = 0;
  61.         STCP = 0;
  62.
  63.         for(i=0;i<8;i++)
  64.         {
  65.                 DS = d>>7;
  66.                 d<<=1;
  67.                 SHCP = 1;
  68.                 _nop_();
  69.                 _nop_();
  70.                 SHCP = 0;
  71.         }
  72.         STCP = 1;
  73.         _nop_();
  74.         _nop_();
  75.         STCP = 0;
  76. }
  77. void main()
  78. {
  79.         u8 i;
  80.         unsigned int k,m;
  81.         while(1)
  82.         {
  83.                 for(k=0;k<16;k++)
  84.                 {
  85.                         for(m=0;m<100;m++)
  86.                         {
  87.
  88.                                 for(i=0;i<8;i++)
  89.                                 {
  90.                                         send(g[k][i]);
  91.                                         row(i+1);    //i+1表示第幾行
  92.                                         delay1ms();  //延時(shí)
  93.                                         send(0);     //消隱,和延時(shí)一起使?
  94.                                 }
  95.                         }
  96.                 }
  97.         }
  98. }
8x8led點(diǎn)陣 顯示0-f等字符.zip (73.15 KB, 下載次數(shù): 39)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:827939 發(fā)表于 2020-11-22 20:31 | 只看該作者
是可以移動(dòng)顯示0-F等字符的,
