OLED屏有多種類型,其中的參數屏要比單色屏和雙色屏更具色彩表現力,在設計小游戲時,彩色屏將是不錯的下載,假如用單色屏來完成俄羅斯方塊的話,那就只剩下方塊了,相對來講彩色屏會更具優勢。 目前來看,似乎還沒見到有I2C接口的彩色屏,因此就只有多犧牲幾個I/O口來驅動彩色屏了! 在彩色屏與U CH32V103連接上,其關系如下: CLK--PA2 DIN--PA3 RST--PB3 DC --PB4 CS --PB5 BLK--PB6 定義引腳輸出高低電平的語句為: #define OLED_SCLK_Set() GPIO_WriteBit(GPIOA, GPIO_Pin_2,Bit_SET) #define OLED_SCLK_Clr() GPIO_WriteBit(GPIOA, GPIO_Pin_2,Bit_RESET) #define OLED_SDIN_Set() GPIO_WriteBit(GPIOA, GPIO_Pin_3,Bit_SET) #define OLED_SDIN_Clr() GPIO_WriteBit(GPIOA, GPIO_Pin_3,Bit_RESET) #define OLED_RST_Set() GPIO_WriteBit(GPIOB, GPIO_Pin_3,Bit_SET) #define OLED_RST_Clr() GPIO_WriteBit(GPIOB, GPIO_Pin_3,Bit_RESET) #define OLED_DC_Set() GPIO_WriteBit(GPIOB, GPIO_Pin_4,Bit_SET) #define OLED_DC_Clr() GPIO_WriteBit(GPIOB, GPIO_Pin_4,Bit_RESET) #define OLED_CS_Set() GPIO_WriteBit(GPIOB, GPIO_Pin_5,Bit_SET) #define OLED_CS_Clr() GPIO_WriteBit(GPIOB, GPIO_Pin_5,Bit_RESET) #define OLED_BLK_Set() GPIO_WriteBit(GPIOB, GPIO_Pin_6,Bit_SET) #define OLED_BLK_Clr() GPIO_WriteBit(GPIOB, GPIO_Pin_6,Bit_RESET) 相關引腳輸出功能的配置函數為: - void App_OledInit(void)
- GPIO_InitTypeDef GPIO_InitStructure; //定義一個GPIO_InitTypeDef類型的結構體
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能與LED相關的GPIO端口時鐘
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6; //配置GPIO引腳
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //設置GPIO模式為推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //設置GPIO口輸出速度
- GPIO_Init(GPIOB, &GPIO_InitStructure); //調用庫函數,初始化GPIOA
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能與LED相關的GPIO端口時鐘
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3; //配置GPIO引腳
- GPIO_Init(GPIOA, &GPIO_InitStructure); //調用庫函數,初始化GPIOA
- GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3); //設置引腳輸出高電平
圖片顯示的函數為: - void LCD_ShowPicturea(u16 x1,u16 y1,u16 x2,u16 y2)
- int i;
- LCD_Address_Set(x1,y1,x2,y2);
- for(i=0;i<12800;i++)
- LCD_WR_DATA8(gImage_moled[i*2]);
- LCD_WR_DATA8(gImage_moled[i*2+1]);
實現顯示效果的主程序為: - int main(void)
- u8 i=0;
- u8 j=0;
- Delay_Init(); //延時函數初始化
- LED_Init(); //LED初始化
- App_OledInit();
- OLED_Init();
- Delay_Ms(200);
- LCD_Clear(BLACK);
- BACK_COLOR=BLACK;
- LCD_ShowString(10,0,"CH32V103 TEST",RED);
- LCD_ShowString(10,20,"OLED Display",RED);
- LCD_ShowString(10,40,"jinglixixi",RED);
- LCD_ShowString(10,60,"2020.10.28",RED);
- Delay_Ms(2000);
- LCD_Clear(BLACK);
- LCD_ShowChinese(28,0,0,32,YELLOW);
- LCD_ShowChinese(60,0,1,32,YELLOW);
- LCD_ShowChinese(92,0,2,32,YELLOW);
- LCD_ShowChinese(20,40,0,16,YELLOW);
- LCD_ShowChinese(36,40,1,16,YELLOW);
- LCD_ShowChinese(52,40,2,16,YELLOW);
- LCD_ShowChinese(68,40,3,16,YELLOW);
- LCD_ShowChinese(84,40,4,16,YELLOW);
- LCD_ShowChinese(100,40,5,16,YELLOW);
- LCD_ShowChinese(116,40,6,16,YELLOW);
- LCD_ShowString(20,60,"0.96 TFT SPI",YELLOW);
- Delay_Ms(2000);
- LCD_Clear(BLACK);
- LCD_ShowString(10,0,"LCD_W:",RED);
- LCD_ShowNum(70,0,LCD_W,3,RED);
- LCD_ShowString(10,20,"LCD_H:",RED);
- LCD_ShowNum(70,20,LCD_H,2,RED);
- for(i=0;i<4;i++)
- LCD_ShowPicture(i*40,40,39+i*40,79);
- Delay_Ms(2000);
- LCD_ShowPicturea(0,0,159,79);
經編譯,程序對系統資源的占用情況如圖1所示。
圖1
程序下載后的運行效果見圖2~圖4所示。 圖2~圖4 若單顯示圖片,則系統資源資源情況為: 圖5
程序下載后面,其運行效果如圖所示。 圖6
