Table 5.2-1: NR operating bands in FR1 | Uplink (UL) operating band
BS receive / UE transmit FUL_low – FUL_high | Downlink (DL) operating band
BS transmit / UE receive FDL_low – FDL_high | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | n84 | | | | | | | | | | | | NOTE 1: UE that complies with the NR Band n50 minimum requirements in this specification shall also comply with the NR Band n51 minimum requirements. NOTE 2: UE that complies with the NR Band n75 minimum requirements in this specification shall also comply with the NR Band n76 minimum requirements. NOTE 3: Uplink transmission is not allowed at this band for UE with external vehicle-mounted antennas. NOTE 4: A UE that complies with the NR Band n65 minimum requirements in this specification shall also comply with the NR Band n1 minimum requirements. NOTE 5: Unless otherwise stated, the applicability of requirements for Band [n90] is in accordance with that for Band n41; a UE supporting Band [n90] shall meet the requirements for Band n41. |
NR is designed to operate in the FR2 operating bands defined in Table 5.2-1. Table 5.2-1: NR operating bands in FR2 | Uplink (UL) operating band
BS receive
UE transmit | Downlink (DL) operating band
BS transmit
UE receive | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
