查看: 3910|回復: 0
自制Arduino庫-基于時間值的無延時處理
       我們知道,Arduino里要多個LED燈能基于不同的延時值來亮滅,用普通的Delay是無法達到效果。一般要么上系統,要么用分時的方法,而本人基于數組和Millis()函數自制一個庫,實現類似于時間繼電器延時ON和OFF的功能,很方便能使用。以下為本人原創,網友可自行研究改進
一、先看庫的頭文件
#ifndef_DelayRun_h
#define_DelayRun_h
#defineMAX_DELAY  10
#defineIF_DELAY_OFF(a,b,c) if(DelayRun.delay_off(a,b,c))
#defineIF_DELAY_ON(a,b,c) if(DelayRun.delay_on(a,b,c))
#defineIF_DELAYUS_OFF(a,b,c) if(DelayRun.delayus_off(a,b,c))
#defineIF_DELAYUS_ON(a,b,c) if(DelayRun.delayus_on(a,b,c))
#defineIF_RUN_ONCE(a,b) if(DelayRun.once_func(a,b))
#defineIF_RUN_NORMAL(a) if(DelayRun.normal_func(a))
#defineWHILE_DELAY_OFF(a,b,c) while(DelayRun.delay_off(a,b,c))
#defineWHILE_DELAY_ON(a,b,c) while(DelayRun.delay_on(a,b,c))
#defineWHILE_DELAYUS_OFF(a,b,c) while(DelayRun.delayus_off(a,b,c))
#defineWHILE_DELAYUS_ON(a,b,c) while(DelayRun.delayus_on(a,b,c))
*Definitions
class DelayRunClass
  public:
    static void init_delay(uint8_t rstindex,uint8_t setindex);
    static uint8_t delay_on(uint32_t delaytime,uint8_t index,uint8_t setindex);
    static uint8_t delay_off(uint32_t delaytime,uint8_t index,uint8_t setindex);
    static uint8_t delayus_on(uint32_t delaytime,uint8_t index,uint8_t setindex);
    static uint8_t delayus_off(uint32_t delaytime,uint8_t index,uint8_t setindex);
    static uint8_t normal_func(uint8_t index);
    static uint8_t once_func(uint8_t index,uint8_t setindex);
extern DelayRunClass DelayRun;
extern uint8_t runstate[MAX_DELAY];
#endif
[size=13.3333px]二、庫的實現
//For Arduino 1.0
#if ARDUINO>= 100
    #include<Arduino.h>
#else
    #include<WProgram.h>
#endif
#include "DelayRun.h"
uint32_t delaytick[MAX_DELAY];
//自定義延時程序
void DelayRunClass::init_delay(uint8_t rstindex,uint8_tsetindex)
  runstate[rstindex]=0;
  runstate[setindex]=1;
uint8_tDelayRunClass::delay_on(uint32_t delaytime,uint8_t index,uint8_t setindex)
  if(runstate[index]==0)
    return 0;
  if(delaytick[index]==0)
    delaytick[index]=millis()+delaytime;
  if(millis()>=delaytick[index])
    delaytick[index]=0;
    runstate[index]=0;
    return 1;
    return 0;
uint8_tDelayRunClass::delay_off(uint32_t delaytime,uint8_t index,uint8_t  setindex)
    return 0;
  if(millis()<=delaytick[index])
    return 1;
    delaytick[index]=0;
    runstate[index]=0;
    return 0;
uint8_tDelayRunClass::delayus_on(uint32_t delaytime,uint8_t index,uint8_t setindex)
    return 0;
    delaytick[index]=micros()+delaytime;
  if(micros()>=delaytick[index])
    delaytick[index]=0;
    runstate[index]=0;
    return 1;
    return 0;
uint8_tDelayRunClass::delayus_off(uint32_t delaytime,uint8_t index,uint8_t  setindex)
    return 0;
  if(micros()<=delaytick[index])
    return 1;
    delaytick[index]=0;
    runstate[index]=0;
    return 0;
uint8_tDelayRunClass::normal_func(uint8_t index)
  if(runstate[index]==1)
    return 1;
    return 0;
uint8_tDelayRunClass::once_func(uint8_t index,uint8_t setindex)
    runstate[index]=0;
    return 1;
    return 0;
DelayRunClassDelayRun;
三、把制作的庫放在ArduinoIDE的Libraries文件庫里,然后在自己的Arduino里使用,見如下Sample
本示例實現數字口2、3不同的時基閃滅,互不干擾,4為按鍵,按下后,5延時LOW
#include <DelayRun.h>
//IF_DELAY_OFF(a,b,c)  if(DelayRun.delay_off(a,b,c))
//IF_DELAY_ON(a,b,c)  if(DelayRun.delay_on(a,b,c))
//IF_DELAYUS_OFF(a,b,c)  if(DelayRun.delayus_off(a,b,c))
//IF_DELAYUS_ON(a,b,c)  if(DelayRun.delayus_on(a,b,c))
//IF_RUN_ONCE(a,b)  if(DelayRun.once_func(a,b))
//IF_RUN_NORMAL(a)  if(DelayRun.normal_func(a))
//WHILE_DELAY_OFF(a,b,c)  while(DelayRun.delay_off(a,b,c))
//WHILE_DELAY_ON(a,b,c)  while(DelayRun.delay_on(a,b,c))
//WHILE_DELAYUS_OFF(a,b,c)  while(DelayRun.delayus_off(a,b,c))
//WHILE_DELAYUS_ON(a,b,c)  while(DelayRun.delayus_on(a,b,c))
uint8_t key2;
void setup() {
  // put your setup code here, to run once:
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(4,INPUT);
  pinMode(5,OUTPUT);
  runstate[0]=1;
  runstate[2]=1;
  runstate[4]=1;
void loop() {
  // put your main code here, to run repeatedly:
  //if(DelayRun.delay_off(1000,0,1))
  IF_DELAY_OFF(1000,0,1)
    digitalWrite(2,HIGH);
  IF_DELAY_OFF(1000,1,0)
    digitalWrite(2,LOW);
  IF_DELAY_OFF(300,2,3)
    digitalWrite(3,HIGH);
  IF_DELAY_OFF(300,3,2)
    digitalWrite(3,LOW);
  if(digitalRead(4)==LOW)
    delay(10);
      key2=1;
  if(key2)
     IF_RUN_ONCE(4,5)
      digitalWrite(5,HIGH);
     IF_DELAY_ON(1000,5,4)
      digitalWrite(5,LOW);
      key2=0;
上效果圖見GIF
全部資料51hei下載地址:
DelayRun.rar (6.47 KB, 下載次數: 11)
收藏收藏4 分享淘帖 頂1 踩
